Re: Newspaper Layout with dynamic row height and grouping [message #1579630 is a reply to message #1561121] |
Fri, 23 January 2015 03:19 |
I created an example for this once that requires counting of characters and average characters per row to make assumptions on the distance down the page. I'll look for that example. I was able to get newspaper layout with grouping to work with this method. I'll post a link if I find it. Otherwise I can help recreate it.
Michael
Developer Evangelist, Silanis
Re: Newspaper Layout with dynamic row height and grouping [message #1579643 is a reply to message #1561121] |
Fri, 23 January 2015 03:27 |
I found a version of it. This was not the latest and was made in BIRT Designer Professional, so you might get an error when running the report, but it still executes. This should give you an idea of a way to do it. This separates the original data set into individual rows in a new data set to allow for the standard method of a newspaper layout to work. Let me know if you have questions on what was done.
Michael
FUDForum. Page generated in 0.02349 seconds
