Home » Eclipse Projects » EclipseLink » Embeddable with ManyToMany relationship(Embeddable with ManyToMany relationship)
Embeddable with ManyToMany relationship [message #658446] Tue, 08 March 2011 09:52 Go to next message
I have an Entity (Foo) that contains an Embeddable (FooBar) which has a ManyToMany relationship to another Entity (Bar) (code below). When I run a query
select f, f.fooBar from Foo f
I get an exception
Exception [EclipseLink-6094] (Eclipse Persistence Services - 2.2.0.v20110202-r8913): org.eclipse.persistence.exceptions.QueryException
Exception Description: The parameter name [ID] in the query's selection criteria does not match any parameter name defined in the query.
More stack trace below.
Is there something wrong with my entities or with my query?
Using EclipseLink 2.2.0 on PostgreSQL 8.4
- Jon
@Entity
public class Foo {
@Id
@GeneratedValue(strategy = GenerationType.TABLE)
private Long id;
@Embedded
private FooBar fooBar;
public Long getId() { return id; }
public void setId(Long id) { this.id = id; }
public FooBar getFooBar() { return fooBar; }
public void setFooBar(FooBar fooBar) { this.fooBar = fooBar; }
@Embeddable
public class FooBar {
@ManyToMany(fetch=FetchType.EAGER)
private Set<Bar> bars;
public Set<Bar> getBars() { return bars; }
public void setBars(Set<Bar> bars) { this.bars = bars; }
@Entity
public class Bar {
@Id
private Long id;
private String name;
public String getName() { return name; }
public void setName(String name) { this.name = name; }
Local Exception Stack:
Query: ReadAllQuery(name="bars" referenceClass=Bar sql="SELECT t1.ID, t1.NAME FROM FOO_BAR t0, BAR t1 WHERE ((t0.Foo_ID = ?) AND (t1.ID = t0.bars_ID))")
at org.eclipse.persistence.exceptions.QueryException.parameterN ameMismatch(QueryException.java:1050)
at org.eclipse.persistence.internal.expressions.ParameterExpres sion.getValue(ParameterExpression.java:246)
at org.eclipse.persistence.internal.databaseaccess.DatabaseCall .translate(DatabaseCall.java:951)
at org.eclipse.persistence.internal.queries.DatasourceCallQuery Mechanism.executeCall(DatasourceCallQueryMechanism.java:206)
at org.eclipse.persistence.internal.queries.DatasourceCallQuery Mechanism.executeCall(DatasourceCallQueryMechanism.java:193)
at org.eclipse.persistence.internal.queries.DatasourceCallQuery Mechanism.executeSelectCall(DatasourceCallQueryMechanism.jav a:264)
at org.eclipse.persistence.internal.queries.DatasourceCallQuery Mechanism.selectAllRows(DatasourceCallQueryMechanism.java:64 7)
at org.eclipse.persistence.internal.queries.ExpressionQueryMech anism.selectAllRowsFromTable(ExpressionQueryMechanism.java:2 558)
at org.eclipse.persistence.internal.queries.ExpressionQueryMech anism.selectAllRows(ExpressionQueryMechanism.java:2517)
at org.eclipse.persistence.queries.ReadAllQuery.executeObjectLe velReadQuery(ReadAllQuery.java:410)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute DatabaseQuery(ObjectLevelReadQuery.java:1080)
at org.eclipse.persistence.queries.DatabaseQuery.execute(Databa seQuery.java:808)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute (ObjectLevelReadQuery.java:1040)
at org.eclipse.persistence.queries.ReadAllQuery.execute(ReadAll Query.java:383)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute InUnitOfWork(ObjectLevelReadQuery.java:1126)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.int ernalExecuteQuery(UnitOfWorkImpl.java:2842)
at org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1521)
at org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1503)
at org.eclipse.persistence.internal.indirection.NoIndirectionPo licy.valueFromQuery(NoIndirectionPolicy.java:323)
at org.eclipse.persistence.mappings.ForeignReferenceMapping.val ueFromRowInternal(ForeignReferenceMapping.java:2061)
at org.eclipse.persistence.mappings.ForeignReferenceMapping.val ueFromRow(ForeignReferenceMapping.java:1950)
at org.eclipse.persistence.mappings.ForeignReferenceMapping.bui ldCloneFromRow(ForeignReferenceMapping.java:274)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.b uildAttributesIntoWorkingCopyClone(ObjectBuilder.java:1415)
at org.eclipse.persistence.mappings.AggregateObjectMapping.buil dAggregateFromRow(AggregateObjectMapping.java:360)
at org.eclipse.persistence.queries.ReportQueryResult.processIte m(ReportQueryResult.java:199)
at org.eclipse.persistence.queries.ReportQueryResult.buildResul t(ReportQueryResult.java:141)
at org.eclipse.persistence.queries.ReportQueryResult.<init>(ReportQueryResult.java:76)
at org.eclipse.persistence.queries.ReportQuery.buildObject(Repo rtQuery.java:594)
at org.eclipse.persistence.queries.ReportQuery.buildObjects(Rep ortQuery.java:645)
at org.eclipse.persistence.queries.ReportQuery.executeDatabaseQ uery(ReportQuery.java:841)
at org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1477)
Re: Embeddable with ManyToMany relationship [message #658685 is a reply to message #658446] Wed, 09 March 2011 08:20 Go to previous message
Looks like a bug when selecting the embeddable, please file a bug for it. The workaround is to not directly select the embeddable when it has a ManyToMany relationship, and instead access it from the returned Foo object, as the query is returning it anyway.
Best Regards,
Chris
Previous Topic:Generating DDL scripts with maven?
Next Topic:NoSuchMethod - sufix _vh
Current Time: Sun Nov 02 00:07:16 EDT 2025
Powered by FUDForum. Page generated in 0.03816 seconds
