Home » Modeling » EMF » How to programmatic create EClass attribute of non-simple type
How to programmatic create EClass attribute of non-simple type [message #388250] |
Fri, 01 October 2004 11:39 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jla.pine.dk
I've found out how to programmatic create ECore classes and attributes
of simple types like this:
EClass personClass = EcoreFactory.eINSTANCE.createEClass();
personClass.setName("Person");
EAttribute personAttr = EcoreFactory.eINSTANCE.createEAttribute();
personAttr.setName("name");
personAttr.setEType(EcorePackage.eINSTANCE.getEString());
personClass.getEStructuralFeatures().add(personAttr);
The above works find, but how do I set a non-simple type (EClass) for an
attribute?
I've tried the following:
// Create Address class
EClass addressClass = EcoreFactory.eINSTANCE.createEClass();
addressClass.setName("Address");
EAttribute eAttr = EcoreFactory.eINSTANCE.createEAttribute();
eAttr.setName("Street");
eAttr.setEType(EcorePackage.eINSTANCE.getEString());
addressClass.getEStructuralFeatures().add(eAttr);
// Create attribute of Address type
personAttr.setName("Address");
personAttr.setEType(addressClass); <-- wrong?
However, when serializing the SDO datagraph a ClassCastException is
thrown from XMLSaveImpl:
Caused by: java.lang.ClassCastException
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl$Lookup.featureKin d(XMLSaveImpl.java:1849)
Hmmmm... it seems that XMLSaveImpl expects a EDataType or EReference...??
Yes, I have no idea how this ECore stuff works :(
Help greatly appreciated!
Jesper
Re: How to programmatic create EClass attribute of non-simple type [message #388251 is a reply to message #388250] |
Fri, 01 October 2004 11:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Ed Merks![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ed.merks%40gmail.com) Messages: 33171 Registered: July 2009 |
Jesper,
It looks like you have a good grasp and have only missed a small but
essential point. An EStructuralFeature's type is an EClassifier, but
there are two kinds of EStructuralFeatures, an EAttribute and an
EReference, where the former's EClassifier must be an EDataType (or
EEnum which extends EDataType) and the later's EClassifier must be an
EClass. So depending on whether your feature's type is to be an
EDataType or an EClass, you should create either an EAttribute or an
EReference.
Jesper Ladegaard wrote:
> an attribute?
> at
> Regards
> Jesper
Ed Merks
Re: How to programmatic create EClass attribute of non-simple type [message #388252 is a reply to message #388251] |
Fri, 01 October 2004 13:08 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thanks a lot!
But now to the next problem... how do I set the DataObject?
I've tried using EDataObject.setDataObject(...) like this:
EDataObject person =
(EDataObject)eFactory.create((EClass)ePackage.getEClassifier ( "Person");
EDataObject address =
(EDataObject)eFactory.create((EClass)ePackage.getEClassifier ( "Address");
person.setDataObject("address", address);
But when I serialize the datagraph the following exception is thrown:
Caused by: org.eclipse.emf.ecore.resource.Resource$IOWrappedException:
The object 'org.eclipse.emf.ecore.sdo.impl.EDataObjectImpl@954549
(eClass: org.eclipse.emf.ecore.impl.EClassImpl@1f7dab1 (name: Address)
(instanceClassName: null) (abstract: false, interface: false))' is not
contained in a resource.
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:190)
Is it the object (instance) or the EClass it complains about?
I guess it's the object instance, but how do I include it in my DataGraph?
Jesper
Ed Merks wrote:
> Jesper,
> EReference.
>> an attribute?
>> at
>> Regards
>> Jesper
Re: How to programmatic create EClass attribute of non-simple type [message #388253 is a reply to message #388252] |
Fri, 01 October 2004 13:14 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Jesper,
Probably the EReference you created for the "address" feature needs to
have isContainment true, i.e., it needs to be "black diamond". The
default will be isContainment false, which will be a "cross" reference
rather than a containment reference, and any object referenced by such a
cross reference will need to be contained by some other reference in
order to be properly contained by the data graph.
> Thanks a lot!
> at
> DataGraph?
> Regards
> Jesper
> Ed Merks wrote:
>> Jesper,
>> EReference.
>>> Hi,
>>> attributes of simple types like this:
>>> for an attribute?
>>> at
>>> EReference...??
>>> Regards
>>> Jesper
Ed Merks
Re: How to programmatic create EClass attribute of non-simple type [message #388254 is a reply to message #388253] |
Fri, 01 October 2004 13:18 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Makes sense.
And it works too :-)
Thanks a lot!
Jesper
> Jesper,
>> Thanks a lot!
>> at
>> DataGraph?
>> Regards
>> Jesper
>> Ed Merks wrote:
>>> Jesper,
>>> EReference.
>>>> Hi,
>>>> for an attribute?
>>>> at
>>>> EReference...??
>>>> Regards
>>>> Jesper
Current Time: Fri Jul 05 18:29:40 GMT 2024
Powered by FUDForum. Page generated in 0.03105 seconds
