Re: qualifier.replacement does not work in the IDE? [message #997661 is a reply to message #995972] |
Mon, 07 January 2013 12:30 |
Hi Lorenzo,
Sorry for late reply. I don't understand what could cause this error.
You're not doing anything out of the ordinary and the qualifier is
valid. Would it be possible for you to provide a sample that reproduces
the problem that I could look at?
A full stacktrace might be helpful if that's possible to obtain.
- thomas
On 2012-12-31 18:26, Lorenzo Bettini wrote:
> Hi
> when I run buckminster headless qualifier replacement takes place
> automatically with something like
> 1.0.0.201212301738
> in the IDE I use a properties file which contains
> qualifier.replacement.*=generator:buildTimestamp
> generator.buildTimestamp.format=yyyyMMddHHmm
> but when I run site.p2 action in the IDE I get an error
> org.eclipse.core.runtime.CoreException:
> <myeclipsedir>/configuration/org.eclipse.osgi/bundles/557/1/.cp/org/eclipse/buckminster/pde/antscripts/build.xml:300:
> java.lang.IllegalArgumentException: Format
> "format(n[.n=0;[.n=0;[.S=[A-Za-z0-9_-];='';]]])" was unable to parse
> 1.0.0.201212311725
> am I doing something wrong?
> cheers
> Lorenzo
FUDForum. Page generated in 0.04613 seconds
