How to customize bar chart color [message #368614] |
Mon, 15 June 2009 11:09  |
I created a bar chart which showed the severity of vulnerabilities.
It's ordered by severity and colored by Categories. I was able to pick up
colors by clicking "Series Palette". But ideally I would like to tie a
specified color to severity. e.g. If it's critical, the color should be
red...
Just wonder if there is a way to do so.
Thanks a lot for your time and help.
-Alex
Re: How to customize bar chart color [message #368623 is a reply to message #368614] |
Tue, 16 June 2009 10:32   |
Originally posted by: jasonweathersby.windstream.net
Alex,
You should be able to do this in the beforeDrawDataPoint script. Keep
in mind this will mess up the legend unless you change colors for it to
with script. To change the data point color do this:
function beforeDrawDataPoint(dph, fill, icsc)
//Fill implements Fill interface
//ImageImpl
//ColorDefinitionImpl
//GradientImpl
//MultipleFillImpl
val = dph.getOrthogonalValue();
if (val < 0){
fill.set(255, 0, 0);
See attached example
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.17"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.3.2.r232_20090202 Build <2.3.2.v20090218-0730></property>
<property name="units">in</property>
<method name="beforeRender"><![CDATA[var mychartvar = "setbyreport";
reportContext.setGlobalVariable("reportvariable", mychartvar);]]></method>
<data-sources>
<script-data-source name="Data Source" id="2"/>
</data-sources>
<data-sets>
<script-data-set name="Data Set" id="3">
<list-property name="resultSetHints">
<structure>
<property name="position">1</property>
<property name="name">Category</property>
<property name="dataType">any</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">SalesBalance</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">Projection</property>
</structure>
</list-property>
<list-property name="columnHints">
<structure>
<property name="columnName">Category</property>
</structure>
<structure>
<property name="columnName">SalesBalance</property>
</structure>
<structure>
<property name="columnName">Projection</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<method name="open"><![CDATA[i = 0;
sourcedata = new Array( new Array(3),
new Array(3),
new Array(3),
new Array(3),
new Array(3));
sourcedata[0][0] = "Keyboard";
sourcedata[0][1] = 320;
sourcedata[0][2] = 105;
sourcedata[1][0] = "Mouse";
sourcedata[1][1] = 1700;
sourcedata[1][2] = 430;
sourcedata[2][0] = "Memory";
sourcedata[2][1] = -387;
sourcedata[2][2] = 250;
sourcedata[3][0] = "CPU";
sourcedata[3][1] = 890;
sourcedata[3][2] = -100;
sourcedata[4][0] = "Cable";
sourcedata[4][1] = -790;
sourcedata[4][2] = 340;]]></method>
<method name="fetch"><![CDATA[if ( i < 5 )
row["Category"] = sourcedata[i][0];
row["SalesBalance"] = sourcedata[i][1];
row["Projection"]= sourcedata[i][2];
i++;
return true;
return false;]]></method>
</script-data-set>
</data-sets>
<page-setup>
<simple-master-page name="Simple MasterPage" id="4">
<page-footer>
<text id="5">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<extended-item extensionName="Chart" name="NewChart" id="6">
<xml-property
name="xmlRepresentation"><![CDATA[<model:ChartWithAxes
xmlns:attribute="http://www.birt.eclipse.org/ChartModelAttribute"
xmlns:data="http://www.birt.eclipse.org/ChartModelData"
xmlns:layout="http://www.birt.eclipse.org/ChartModelLayout"
xmlns:model="http://www.birt.eclipse.org/ChartModel"
xmlns:type="http://www.birt.eclipse.org/ChartModelType">
<Type>Bar Chart</Type>
<SubType>Stacked</SubType>
<Description>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Description>
<Block>
<Children xsi:type="layout:TitleBlock">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
<Height>0.0</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Bottom>3.0</Bottom>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Rowspan>-1</Rowspan>
<Columnspan>-1</Columnspan>
<Outline>
<Style>Solid</Style>
<Thickness>1</Thickness>
<Color>
<Transparency>255</Transparency>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
<Visible>false</Visible>
</Outline>
<Label>
<Caption>
<Value>Bar Chart Title</Value>
<Font>
<Name>Book Antiqua</Name>
<Size>24.0</Size>
<Bold>true</Bold>
<Italic>false</Italic>
<Strikethrough>false</Strikethrough>
<Underline>false</Underline>
<Alignment>
<horizontalAlignment>Left</horizontalAlignment>
<verticalAlignment>Top</verticalAlignment>
</Alignment>
<Rotation>0.0</Rotation>
</Font>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Caption>
<Background xsi:type="attribute:ColorDefinition">
<Transparency>0</Transparency>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Bottom>0.0</Bottom>
<Right>3.0</Right>
</Insets>
<Visible>true</Visible>
</Label>
</Children>
<Children xsi:type="layout:Plot">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<HorizontalSpacing>5</HorizontalSpacing>
<VerticalSpacing>5</VerticalSpacing>
<ClientArea>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Thickness>0</Thickness>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Children xsi:type="layout:Legend">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Bottom>2.0</Bottom>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value><undefined></Value>
<Font>
<Name>SansSerif</Name>
<Size>12.0</Size>
<Bold>false</Bold>
<Alignment>
</Alignment>
</Font>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Text>
<Orientation>Vertical</Orientation>
<Direction>Top_Bottom</Direction>
<Separator>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Separator>
<Position>Right</Position>
<ItemType>Series</ItemType>
<Title>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>302.25000000240004</Width>
<Height>207.0</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Thickness>4</Thickness>
<Color>
<Red>51</Red>
<Green>51</Green>
<Blue>153</Blue>
</Color>
</Outline>
<Background xsi:type="attribute:Gradient">
<StartColor>
<Red>203</Red>
<Green>228</Green>
<Blue>254</Blue>
</StartColor>
<EndColor>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</EndColor>
<Direction>90.0</Direction>
</Background>
</Block>
<Dimension>Two_Dimensional</Dimension>
<Script>function beforeDrawDataPoint(dph, fill, icsc)
//ImageImpl
//GradientImpl
//MultipleFillImpl
if (val < 0){
function beforeDrawDataPointLabel(dph, label, icsc)
var mylab =
icsc.getExternalContext().getScriptable().getGlobalVariable( "reportvariable");
label.getCaption().setValue(mylab);
}</Script>
<Units>Points</Units>
<SeriesThickness>10.0</SeriesThickness>
<SampleData>
<BaseSampleData>
<DataSetRepresentation>'A','B','C'</DataSetRepresentation>
</BaseSampleData>
<OrthogonalSampleData>
<DataSetRepresentation>5.0,4.0,12.0</DataSetRepresentation >
<SeriesDefinitionIndex>0</SeriesDefinitionIndex>
</OrthogonalSampleData>
<DataSetRepresentation>10.0,8.0,24.0</DataSetRepresentation >
<SeriesDefinitionIndex>1</SeriesDefinitionIndex>
<AncillarySampleData>
<DataSetRepresentation>Series 1</DataSetRepresentation>
</AncillarySampleData>
</SampleData>
<Interactivity/>
<Axes>
<Type>Text</Type>
<Title>
<Caption>
<Value>=</Value>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Below</TitlePosition>
<AssociatedAxes>
<Type>Linear</Type>
<Title>
<Caption>
<Value>=Sales Balance</Value>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
<Rotation>90.0</Rotation>
</Font>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Left</TitlePosition>
<SeriesDefinitions>
<Query>
<Definition></Definition>
</Query>
<SeriesPalette>
<Entries xsi:type="attribute:ColorDefinition">
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>0</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<Series xsi:type="type:BarSeries">
<Label>
<Caption>
<Font>
<Size>12.0</Size>
<Bold>false</Bold>
<Alignment>
</Alignment>
</Font>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row["SalesBalance"]</Definition >
</DataDefinition>
<SeriesIdentifier><undefined></SeriesIdentifier>
<DataPoint>
<Components>
<Type>Orthogonal_Value</Type>
</Components>
<Separator>, </Separator>
</DataPoint>
<LabelPosition>Inside</LabelPosition>
<Stacked>true</Stacked>
<Riser>Rectangle</Riser>
</Series>
<Grouping>
<Enabled>false</Enabled>
<GroupingInterval>2.0</GroupingInterval>
<GroupType>Text</GroupType>
<AggregateExpression>Sum</AggregateExpression>
</Grouping>
<Sorting>Ascending</Sorting>
</SeriesDefinitions>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>0</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
</SeriesPalette>
<Label>
<Caption>
<Font>
<Size>12.0</Size>
<Bold>false</Bold>
<Alignment>
</Alignment>
</Font>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
</DataDefinition>
<DataPoint>
<Components>
</Components>
</DataPoint>
</Series>
<Grouping>
</Grouping>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Font>
<Size>12.0</Size>
<Bold>false</Bold>
<Alignment>
</Alignment>
</Font>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<LabelPosition>Left</LabelPosition>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickStyle>Left</TickStyle>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickStyle>Across</TickStyle>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
<Min xsi:type="data:NumberDataElement">
<Value>-1000.0</Value>
</Min>
<Max xsi:type="data:NumberDataElement">
<Value>2000.0</Value>
</Max>
<Step>500.0</Step>
<MinorGridsPerUnit>5</MinorGridsPerUnit>
</Scale>
<Origin>
<Type>Min</Type>
<Value xsi:type="data:NumberDataElement">
<Value>0.0</Value>
</Value>
</Origin>
<PrimaryAxis>true</PrimaryAxis>
<Percent>false</Percent>
</AssociatedAxes>
<AncillaryAxes>
<Type>Text</Type>
<Title>
<Caption>
<Value>Z-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
<horizontalAlignment>Center</horizontalAlignment>
<verticalAlignment>Center</verticalAlignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<Series>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<SeriesIdentifier></SeriesIdentifier>
<DataPoint>
<Components>
</Components>
</DataPoint>
<LabelPosition>Outside</LabelPosition>
<Stacked>false</Stacked>
</Series>
<Grouping>
</Grouping>
<Orientation>Horizontal</Orientation>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<LabelPosition>Below</LabelPosition>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
</Scale>
<Origin>
<Type>Min</Type>
<Value>0.0</Value>
</Value>
</Origin>
</AncillaryAxes>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>127</Red>
<Green>127</Green>
<Blue>127</Blue>
</Entries>
</SeriesPalette>
<Series>
<Label>
<Caption>
<Font>
<Size>12.0</Size>
<Bold>false</Bold>
<Alignment>
</Alignment>
</Font>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row["Category"]</Definition>
</DataDefinition>
<DataPoint>
<Components>
</Components>
</DataPoint>
</Series>
<Grouping>
</Grouping>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Font>
<Size>12.0</Size>
<Bold>false</Bold>
<Alignment>
</Alignment>
</Font>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
FUDForum. Page generated in 0.06168 seconds
