YYYY vs yyyy in onrender() [message #996895] |
Thu, 03 January 2013 01:18  |
hi,
We have a report with excel format, which has date format set in onRender():
this.setDisplayValue(Formatter.format(this.getValue(),"M/d/YYYY"));
With this format set we have got date displayed as 12/31/2013 instead of 12/31/2012.
This is happening only for the week the new year falls in. I mean only for 12/30 and 12/31 2012.
We get the correct dates if we change our date format to M/d/yyyy.We get 12/31/2012 and 12/30/2012.
So is there any difference between m/dd/yyyy and m/dd/YYYY from BIRT perspective in Formatter.format().
Any info regrding this would be of great help.
KHP
[Updated on: Thu, 03 January 2013 01:53] by Moderator
Re: YYYY vs yyyy in onrender() [message #1016094 is a reply to message #997125] |
Mon, 04 March 2013 18:20  |
I also came across this error using 3.7, in my case it was for the date 1/1/1988, it would show 1/1/1987 but only with the format MM/dd/YYYY. After I updated the format to MM/dd/yyyy the date showed correctly. It also showed correctly when I removed the format. What is the difference between the two? 2012 and 1988 are leap years, sounds like bug, going to check bugzilla after this post.
FUDForum. Page generated in 0.03192 seconds
