Home » Archived » M2M (model-to-model transformation) » [ATL] reference model elements of other rules
- [ATL] reference model elements of other rules [message #99019] Thu, 05 February 2009 11:18 Go to next message
I have a refinement transformation for 2 input and output models (with
different meta-models). One of the models has to reference a model element
of the other model that is created in the same transformation. Consider
the following example:
rule Rule1 {
from i : MM1!ModelElement1
to o : MM1!ModelElement1
attribute <- attribute1
attribute1 : MM1!ModelElement2
stringAttribute <- 'aString'
rule Rule2 {
from i : MM2!ModelElement2
to o : MM2!ModelElement2
attribute <- ??? -- should reference the model element "attribute1" of
Rule1
Is there a solution for this problem? I tried to use the resolveTemp()
function, but it did not work...
Michael
- Re: [ATL] reference model elements of other rules [message #99035 is a reply to message #99019] Thu, 05 February 2009 12:35 Go to previous messageGo to next message
Normally you should use resolveTemp did you use like this ?
attribute <-
thisModule.resolveTemp(myHelperGettingTheElementTypedMM1!Mod elElement1,'attribute1')
becareful with your rule it matches MM1!ModelElement1 so you should get
the element in any case by a helper maybe :
MM1!ModelElement1.allInstances()->select(...)
Michael Thiele a écrit :
> Hello,
> element of the other model that is created in the same transformation.
> Consider the following example:
> rule Rule1 {
> rule Rule2 {
> of Rule1
> Best regards,
> Michael
- Re: [ATL] reference model elements of other rules [message #99126 is a reply to message #99035] Fri, 06 February 2009 10:11 Go to previous message
Thanks Tristan! That's what I needed. I haven't thought of the helper to
get the MM1!ModelElement1.
Previous Topic:[ATL] Multiple output files with cross-references
Next Topic:[Announce] EMF Transform proposal
Current Time: Sun May 04 09:43:48 EDT 2025
Powered by FUDForum. Page generated in 0.05993 seconds
