jardesc file question [message #98755] |
Thu, 25 September 2003 07:12 |
Originally posted by: christian.dierberger.dornier.eads.net
i want to generate a jar file of all existing *.java files in a directory
or subdirectory without updating the jardesc file permanently, if new java
files are created. Is there a way to solve these problem. I have tried the
following example, but it didn't works.
<selectedElements exportClassFiles="true" exportJavaFiles="false">
<javaElement handleIdentifier="=Path;ClassPath{*.java"/>
</selectedElements>
Re: jardesc file question [message #98922 is a reply to message #98755] |
Thu, 25 September 2003 13:02 |
Originally posted by: daniel.megert.gmx.net
Christian Dierberger wrote:
> </selectedElements>
> Thanks
Using Java elements in the Jardesc (javaElement=) only works for source
folders and projects since packages don't have sub-packages. If you want
everything which is in a folder then use this syntax:
<folder path="/myProject/myFolder"/>
HTH
Dani
FUDForum. Page generated in 0.03346 seconds
