Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo-EMF] SessionController - Multiple resources
[Teneo-EMF] SessionController - Multiple resources [message #98135] |
Mon, 01 October 2007 11:33  |
I am just looking at session controller for multiple resources.
http://www.elver.org/hibernate/hibernateresources.html
I was thinking that if I have 2 resources and if I make modifications in
objects from both resources but if save is called on one resource then
it will save only that resource data but it looks that it saves everything.
Just wondering, is there some solution for this?
For example, here is sample hierarchy(containment) of classes/objects:
A0
---A1
--- A2
---A3
res1 created by using uri "from A0"
res2 created by using uri "from A2"
Now, if make modifications say in object A0 and A2, but just save on any
one of the resource, it saves whole data.
Just wondering, if it is expected behaviour or can I do something about it.
Any suggestions?
Thanks.
- Parvez
Re: [Teneo-EMF] SessionController - Multiple resources [message #98196 is a reply to message #98135] |
Mon, 01 October 2007 17:18   |
Hi Parvez,
It is expected behavior (at least for Hibernate). Currently the only way to prevent this is to set
different cascade annotations on the relation from A0 to A1 and A2. But this would then apply to all
cases (also when A0 and A1 and A2 are in the same resource).
There are maybe ways to prevent this by overriding Hibernate's default cascade behavior at runtime
but this is far from easy (afaics) and I probably won't have time to add this behavior in the
foreseeable future. But you can always enter a call for this ofcourse so that it at least is on the
wish list.
gr. Martin
PC wrote:
> A0
> ---A1
> --- A2
> ---A3
> Any suggestions?
> Thanks.
> - Parvez
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo-EMF] SessionController - Multiple resources [message #98899 is a reply to message #98196] |
Wed, 10 October 2007 10:31  |
Thanks for the info Martin.
I have added an enhancement request i.e.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=205925
-Parvez
Martin Taal wrote:
> Hi Parvez,
> to prevent this is to set different cascade annotations on the relation
> from A0 to A1 and A2. But this would then apply to all cases (also when
> cascade behavior at runtime but this is far from easy (afaics) and I
> probably won't have time to add this behavior in the foreseeable future.
> on the wish list.
> gr. Martin
> PC wrote:
>> Hi,
>> in objects from both resources but if save is called on one resource
>> then it will save only that resource data but it looks that it saves
>> everything.
>> A0
>> ---A1
>> --- A2
>> ---A3
>> any one of the resource, it saves whole data.
>> about it.
>> Any suggestions?
>> Thanks.
>> - Parvez
Re: [Teneo-EMF] SessionController - Multiple resources [message #609864 is a reply to message #98135] |
Hi Parvez,
wish list.
gr. Martin
PC wrote:
> A0
> ---A1
> --- A2
> ---A3
> Any suggestions?
> Thanks.
> - Parvez
The Netherlands
Re: [Teneo-EMF] SessionController - Multiple resources [message #609965 is a reply to message #98196] |
-Parvez
Martin Taal wrote:
> Hi Parvez,
> on the wish list.
> gr. Martin
> PC wrote:
>> Hi,
>> everything.
>> A0
>> ---A1
>> --- A2
>> ---A3
>> about it.
>> Any suggestions?
>> Thanks.
>> - Parvez
Current Time: Wed Apr 16 04:35:25 EDT 2025
Powered by FUDForum. Page generated in 0.04619 seconds
