Home » Archived » BIRT » Migration to Birt Runtime Engine 4.2.1 error(signer information does not match signer information of other classes in the same package)
Migration to Birt Runtime Engine 4.2.1 error [message #976206] Thu, 08 November 2012 06:52 Go to next message
Hi! I'm migrating to Eclipse Birt Runtime Engine 4.2.1 in my Java EE project with jre6 and Tomcat 6.0, this problem occurs when i deploy the project in Tomcat:
07-nov-2012 19:30:23 org.apache.catalina.core.StandardContext listenerStart
GRAVE: Excepción enviando evento inicializado de contexto a instancia de escuchador de clase org.eclipse.birt.report.listener.ViewerServletContextListener java.lang.SecurityException: class "org.eclipse.birt.report.engine.api.IExtractionOption"'s signer information does not match signer information of other classes in the same package
at java.lang.ClassLoader.checkCerts(ClassLoader.java:806) ...
I have deleted all the old libraries of Birt Runtime Engine 2.2 but the problem persists. The project compiles correctly with no errors.
I tried Classpath Checker and it tells this:
Jar conflicts between C:\Program Files\Java\jre6\lib\rt.jar and \xxxx_webapp\WEB-INF\lib\org.eclipse.birt.runtime_4.2.1.v20120918-1113.jar xxxx_webapp Unknown Classpath Checker Problem
It tells me that the class "org.w3c.dom.DOMConfiguration" is conflicting between rt.jar and org.eclipse.birt.runtime_4.2.1.v20120918-1113.jar
I tried to use jdk1.6 instead of jre6 and jr7 but with no success
Thanks a lot.
Re: Migration to Birt Runtime Engine 4.2.1 error [message #977482 is a reply to message #976206] Fri, 09 November 2012 05:11 Go to previous messageGo to next message
Hi again, i tried to erase IExceptionOption.class of the birt runtime jar, and the error is that Tomcat doesn't find the class IExceptionOption.
I tried to unsign the birt runtime jar, but then, the error is
org.eclipse.birt.core.exception.BirtException: Cant startup the OSGI framework
Any ideas please?
Thanks a lot.
Re: Migration to Birt Runtime Engine 4.2.1 error [message #1011315 is a reply to message #976206] Tue, 19 February 2013 04:53 Go to previous messageGo to next message
we're having the same problem - did you ever manage to resolve it?
thanks
Pete
Re: Migration to Birt Runtime Engine 4.2.1 error [message #1011736 is a reply to message #1011315] Wed, 20 February 2013 02:05 Go to previous message
Hi! Yes, the problem is that Birt uses OSGi runtime prior to 3.x version, and now, it uses POJO. Fortunately, Eclipse guys still distributes the new versions in OSGi runtime too. Then, download the "Report Engine OSGi deployment" from http://download.eclipse.org/birt/downloads/build.php?build=R-R1-4_2_1-201209181113. Everything worked right the first time with this Cool
Good luck!
Previous Topic:Cube doesnt exist
Next Topic:Table setColSpan
Current Time: Wed Apr 16 09:35:20 EDT 2025
Powered by FUDForum. Page generated in 0.04438 seconds
