Home » Archived » BIRT » params variable in chart
params variable in chart [message #96815] |
Tue, 06 December 2005 14:58 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: stefano.comarin.primeur.com
I just downloaded 2.0M3 and tried to load a report with a chart created
with 2.0M2, but when I double-click the chart I get the following error
message:
$NO-RB$ Invalid Javascript expression. Source: ParamBinding(StartDate),
line: 0, Expression:
params["StartDate"]
Script engine error: ReferenceError: "params" is not defined.
This worked perfectly in 2.0M2.
I can still preview the report so it seems just a Designer problem.
Stefano
Re: params variable in chart [message #96942 is a reply to message #96859] |
Wed, 07 December 2005 10:25 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
This is a simple design that has the same problem (the other was very
complex):
<!-- Written by Eclipse BIRT 1.0 -->
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 1.0.1
Build <20051201-1157></property>
<property name="units">in</property>
<parameters>
<scalar-parameter name="workdept" id="6">
<text-property name="displayName">Enter
workdept</text-property>
<property name="valueType">static</property>
<property name="dataType">string</property>
<property name="format">Unformatted</property>
<property name="controlType">text-box</property>
<expression name="defaultValue">'E11'</expression>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Sample" id="4">
<property
name="odaDriverClass">com.ibm.db2.jcc.DB2Driver</property >
<property
name="odaURL">jdbc:db2://w2kbi:50000/sample</property>
<property name="odaUser">Administrator</property>
<encrypted-property
name="odaPassword">cHJpbWV1cg==</encrypted-property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Employee" id="5">
<property name="dataSource">Sample</property>
<list-property name="parameters">
<structure>
<property name="name">workdept</property>
<property name="position">1</property>
<property name="allowNull">true</property>
<property name="isInput">true</property>
<property name="isOutput">false</property>
</structure>
</list-property>
<property name="queryText">select empno,salary
from employee
where workdept = ?
order by salary
fetch first 5 rows only</property>
</oda-data-set>
</data-sets>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<extended-item extensionName="Chart" id="7">
<property name="height">4.854in</property>
<property name="width">5.989in</property>
<property name="dataSet">Employee</property>
<list-property name="paramBindings">
<structure>
<property name="paramName">workdept</property>
<expression
name="expression">params["workdept"]</expression>
</structure>
</list-property>
<xml-property
name="xmlRepresentation"><![CDATA[<model:ChartWithAxes
xmlns:attribute="http://www.birt.eclipse.org/ChartModelAttribute"
xmlns:data="http://www.birt.eclipse.org/ChartModelData"
xmlns:layout="http://www.birt.eclipse.org/ChartModelLayout"
xmlns:model="http://www.birt.eclipse.org/ChartModel"
xmlns:type="http://www.birt.eclipse.org/ChartModelType">
<Type>Bar Chart</Type>
<SubType>Stacked</SubType>
<Block>
<Children xsi:type="layout:TitleBlock">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
<Height>0.0</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Bottom>3.0</Bottom>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Rowspan>-1</Rowspan>
<Columnspan>-1</Columnspan>
<Outline>
<Style>Solid</Style>
<Thickness>1</Thickness>
<Color>
<Transparency>255</Transparency>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
<Visible>false</Visible>
</Outline>
<Visible>true</Visible>
<Label>
<Caption>
<Value>Bar Chart Title</Value>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
<horizontalAlignment>Center</horizontalAlignment>
<verticalAlignment>Center</verticalAlignment>
</Alignment>
</Font>
</Caption>
<Background xsi:type="attribute:ColorDefinition">
<Transparency>0</Transparency>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Bottom>0.0</Bottom>
<Right>3.0</Right>
</Insets>
</Label>
</Children>
<Children xsi:type="layout:Plot">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<HorizontalSpacing>5</HorizontalSpacing>
<VerticalSpacing>5</VerticalSpacing>
<ClientArea>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Thickness>0</Thickness>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Children xsi:type="layout:Legend">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Bottom>2.0</Bottom>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value><undefined></Value>
<Font>
<Alignment/>
</Font>
</Text>
<Orientation>Vertical</Orientation>
<Direction>Top_Bottom</Direction>
<Position>Right</Position>
<ItemType>Series</ItemType>
<Title>
<Caption>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Above</TitlePosition>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>431.25</Width>
<Height>349.5</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
</Block>
<Dimension>Two_Dimensional</Dimension>
<Units>Points</Units>
<SeriesThickness>10.0</SeriesThickness>
<SampleData>
<BaseSampleData>
<DataSetRepresentation>A, B, C</DataSetRepresentation>
</BaseSampleData>
<OrthogonalSampleData>
<DataSetRepresentation>5,4,12</DataSetRepresentation>
<SeriesDefinitionIndex>0</SeriesDefinitionIndex>
</OrthogonalSampleData>
</SampleData>
<Interactivity/>
<Axes>
<Type>Text</Type>
<Title>
<Caption>
<Value>X-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Below</TitlePosition>
<AssociatedAxes>
<Type>Linear</Type>
<Title>
<Caption>
<Value>Y-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
<Rotation>90.0</Rotation>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Left</TitlePosition>
<SeriesDefinitions>
<Query>
<Definition></Definition>
</Query>
<SeriesPalette>
<Entries xsi:type="attribute:ColorDefinition">
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<Series xsi:type="type:BarSeries">
<Label>
<Caption>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row["SALARY"]</Definition>
</DataDefinition>
<SeriesIdentifier><undefined></SeriesIdentifier>
<DataPoint>
<Components>
<Type>Orthogonal_Value</Type>
</Components>
<Separator>, </Separator>
</DataPoint>
<LabelPosition>Outside</LabelPosition>
<Stacked>true</Stacked>
<Riser>Rectangle</Riser>
</Series>
<Grouping>
<Enabled>false</Enabled>
<GroupingInterval>2</GroupingInterval>
<GroupType>Text</GroupType>
<AggregateExpression>Sum</AggregateExpression>
</Grouping>
</SeriesDefinitions>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<LabelPosition>Left</LabelPosition>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickStyle>Across</TickStyle>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
<MinorGridsPerUnit>5</MinorGridsPerUnit>
</Scale>
<Origin>
<Type>Min</Type>
<Value xsi:type="data:NumberDataElement">
<Value>0.0</Value>
</Value>
</Origin>
<PrimaryAxis>true</PrimaryAxis>
<Percent>false</Percent>
</AssociatedAxes>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<Series>
<Label>
<Caption>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row["EMPNO"]</Definition>
</DataDefinition>
<DataPoint>
<Components>
</Components>
</DataPoint>
<Stacked>false</Stacked>
</Series>
<Grouping>
</Grouping>
<Orientation>Horizontal</Orientation>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<LabelPosition>Below</LabelPosition>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
</Scale>
<Origin>
<Type>Min</Type>
<Value>0.0</Value>
</Value>
</Origin>
<CategoryAxis>true</CategoryAxis>
</Axes>
<Rotation/>
</model:ChartWithAxes>
]]></xml-property>
<property name="outputFormat">SVG</property>
</extended-item>
</body>
</report>
Stefano
David Michonneau wrote:
> Can you attach your design so I can take a look?
> David
> "Stefano Comarin" <stefano.comarin@primeur.com> wrote in message
> news:0c2ca0ee8439c7c64a99d8b20d990558$1@www.eclipse.org...
>>Hi,
>>message:
>>params["StartDate"]
>>Thanks,
>>Stefano
Re: params variable in chart [message #97140 is a reply to message #96942] |
Wed, 07 December 2005 17:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
David Michonneau![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=dmichonneau%40actuate.com) Messages: 1145 Registered: July 2009 |
Stefano,
This has nothing to do with charts, I can reproduce the problem by clicking
on the DataSet in the Data Explorer. I suggest you either file a bugzilla
entry or post a new entry in the newsgroups.
David
news:dn6dhg$j1a$1@news.eclipse.org...
> complex):
> id="1">
> <property name="createdBy">Eclipse BIRT Designer Version 1.0.1 Build
> <parameters>
> </scalar-parameter>
> </parameters>
> <data-sources>
> <oda-data-source
> <property
> <property
> <encrypted-property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> </list-property>
> from employee
> where workdept = ?
> order by salary
> </oda-data-set>
> </data-sets>
> <page-setup>
> <page-footer>
> <text id="3">
> <text-property name="content"><![CDATA[<value-of>new
> </text>
> </page-footer>
> </page-setup>
> <body>
> <structure>
> <expression
> </structure>
> </list-property>
> <xml-property
> <Block>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Label>
> <Caption>
> <Font>
> <Size>16.0</Size>
> <Bold>true</Bold>
> <Alignment>
> </Alignment>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> </Children>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <ClientArea>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>0.0</Left>
> <Right>0.0</Right>
> </Insets>
> </ClientArea>
> </Children>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <ClientArea>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>2.0</Top>
> <Left>2.0</Left>
> <Right>2.0</Right>
> </Insets>
> </ClientArea>
> <Text>
> <Font>
> <Alignment/>
> </Font>
> </Text>
> <Title>
> <Caption>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> </Children>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> </Block>
> <SampleData>
> <BaseSampleData>
> </BaseSampleData>
> </SampleData>
> <Interactivity/>
> <Axes>
> <Type>Text</Type>
> <Title>
> <Caption>
> <Font>
> <Size>14.0</Size>
> <Bold>true</Bold>
> <Alignment>
> </Alignment>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> <AssociatedAxes>
> <Type>Linear</Type>
> <Title>
> <Caption>
> <Font>
> <Size>14.0</Size>
> <Bold>true</Bold>
> <Alignment>
> </Alignment>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> <SeriesDefinitions>
> <Query>
> </Query>
> <SeriesPalette>
> <Red>80</Red>
> <Green>166</Green>
> <Blue>218</Blue>
> </Entries>
> <Red>242</Red>
> <Green>88</Green>
> <Blue>106</Blue>
> </Entries>
> <Red>232</Red>
> <Green>172</Green>
> <Blue>57</Blue>
> </Entries>
> <Red>128</Red>
> <Green>255</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>64</Red>
> <Green>128</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>170</Red>
> <Green>85</Green>
> <Blue>85</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>0</Blue>
> </Entries>
> </SeriesPalette>
> <Label>
> <Caption>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> <DataDefinition>
> </DataDefinition>
> <DataPoint>
> <Components>
> </Components>
> </DataPoint>
> </Series>
> <Grouping>
> </Grouping>
> <LineAttributes>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </LineAttributes>
> <Label>
> <Caption>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> <MajorGrid>
> <LineAttributes>
> <Color>
> <Red>196</Red>
> <Green>196</Green>
> <Blue>196</Blue>
> </Color>
> </LineAttributes>
> <TickAttributes>
> <Color>
> <Red>196</Red>
> <Green>196</Green>
> <Blue>196</Blue>
> </Color>
> </TickAttributes>
> </MajorGrid>
> <MinorGrid>
> <LineAttributes>
> <Color>
> <Red>225</Red>
> <Green>225</Green>
> <Blue>225</Blue>
> </Color>
> </LineAttributes>
> <TickAttributes>
> <Color>
> <Red>225</Red>
> <Green>225</Green>
> <Blue>225</Blue>
> </Color>
> </TickAttributes>
> </MinorGrid>
> <Scale>
> </Scale>
> <Origin>
> <Type>Min</Type>
> <Value>0.0</Value>
> </Value>
> </Origin>
> </AssociatedAxes>
> <SeriesDefinitions>
> <Query>
> </Query>
> <SeriesPalette>
> <Red>80</Red>
> <Green>166</Green>
> <Blue>218</Blue>
> </Entries>
> <Red>242</Red>
> <Green>88</Green>
> <Blue>106</Blue>
> </Entries>
> <Red>232</Red>
> <Green>172</Green>
> <Blue>57</Blue>
> </Entries>
> <Red>128</Red>
> <Green>255</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>64</Red>
> <Green>128</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>170</Red>
> <Green>85</Green>
> <Blue>85</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>0</Blue>
> </Entries>
> </SeriesPalette>
> <Series>
> <Label>
> <Caption>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> <DataDefinition>
> </DataDefinition>
> <DataPoint>
> <Components>
> </Components>
> </DataPoint>
> </Series>
> <Grouping>
> </Grouping>
> <LineAttributes>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </LineAttributes>
> <Label>
> <Caption>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> <MajorGrid>
> <LineAttributes>
> <Color>
> <Red>196</Red>
> <Green>196</Green>
> <Blue>196</Blue>
> </Color>
> </LineAttributes>
> <TickAttributes>
> <Color>
> <Red>196</Red>
> <Green>196</Green>
> <Blue>196</Blue>
> </Color>
> </TickAttributes>
> </MajorGrid>
> <MinorGrid>
> <LineAttributes>
> <Color>
> <Red>225</Red>
> <Green>225</Green>
> <Blue>225</Blue>
> </Color>
> </LineAttributes>
> <TickAttributes>
> <Color>
> <Red>225</Red>
> <Green>225</Green>
> <Blue>225</Blue>
> </Color>
> </TickAttributes>
> </MinorGrid>
> <Scale>
> </Scale>
> <Origin>
> <Type>Min</Type>
> <Value>0.0</Value>
> </Value>
> </Origin>
> </Axes>
> <Rotation/>
> ]]></xml-property>
> </extended-item>
> </body>
> </report>
> Stefano
>> Hi,
>> Thanks,
>> David
>>>Hi,
>>>message:
>>>params["StartDate"]
>>>Thanks,
>>>Stefano
Re: params variable in chart [message #97887 is a reply to message #97140] |
Fri, 09 December 2005 14:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I searched the bug list and it seems to be bug #93780 that should be
fixed in 2.0 final.
Stefano
> Stefano,
> David
>>Hi,
>>complex):
>><?xml version="1.0" encoding="UTF-8"?>
>>id="1">
>> <parameters>
>> </scalar-parameter>
>> </parameters>
>> <data-sources>
>> <oda-data-source
>> <property
>> <property
>> <encrypted-property
>> </oda-data-source>
>> </data-sources>
>> <data-sets>
>> <oda-data-set
>> <structure>
>> </structure>
>> </list-property>
>>from employee
>>where workdept = ?
>>order by salary
>> </oda-data-set>
>> </data-sets>
>> <page-setup>
>> <page-footer>
>> <text id="3">
>> </text>
>> </page-footer>
>> </page-setup>
>> <body>
>> <structure>
>> <expression
>> </structure>
>> </list-property>
>> <xml-property
>> <Block>
>> <Bounds>
>> <Left>0.0</Left>
>> <Top>0.0</Top>
>> <Width>0.0</Width>
>> </Bounds>
>> <Insets>
>> <Top>3.0</Top>
>> <Left>3.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> <Row>-1</Row>
>> <Column>-1</Column>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Label>
>> <Caption>
>> <Font>
>> <Size>16.0</Size>
>> <Bold>true</Bold>
>> <Alignment>
>> </Alignment>
>> </Font>
>> </Caption>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Background>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>2.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> </Label>
>> </Children>
>> <Bounds>
>> <Left>0.0</Left>
>> <Top>0.0</Top>
>> <Width>0.0</Width>
>> </Bounds>
>> <Insets>
>> <Top>3.0</Top>
>> <Left>3.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> <Row>-1</Row>
>> <Column>-1</Column>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <ClientArea>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Background>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>0.0</Left>
>> <Right>0.0</Right>
>> </Insets>
>> </ClientArea>
>> </Children>
>> <Bounds>
>> <Left>0.0</Left>
>> <Top>0.0</Top>
>> <Width>0.0</Width>
>> </Bounds>
>> <Insets>
>> <Top>3.0</Top>
>> <Left>3.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> <Row>-1</Row>
>> <Column>-1</Column>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <ClientArea>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>2.0</Top>
>> <Left>2.0</Left>
>> <Right>2.0</Right>
>> </Insets>
>> </ClientArea>
>> <Text>
>> <Font>
>> <Alignment/>
>> </Font>
>> </Text>
>> <Title>
>> <Caption>
>> <Font>
>> <Alignment/>
>> </Font>
>> </Caption>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Background>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>2.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> </Title>
>> </Children>
>> <Bounds>
>> <Left>0.0</Left>
>> <Top>0.0</Top>
>> </Bounds>
>> <Insets>
>> <Top>3.0</Top>
>> <Left>3.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> <Row>-1</Row>
>> <Column>-1</Column>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Background>
>> </Block>
>> <SampleData>
>> <BaseSampleData>
>> </BaseSampleData>
>> </SampleData>
>> <Interactivity/>
>> <Axes>
>> <Type>Text</Type>
>> <Title>
>> <Caption>
>> <Font>
>> <Size>14.0</Size>
>> <Bold>true</Bold>
>> <Alignment>
>> </Alignment>
>> </Font>
>> </Caption>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Background>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>2.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> </Title>
>> <AssociatedAxes>
>> <Type>Linear</Type>
>> <Title>
>> <Caption>
>> <Font>
>> <Size>14.0</Size>
>> <Bold>true</Bold>
>> <Alignment>
>> </Alignment>
>> </Font>
>> </Caption>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Background>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>2.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> </Title>
>> <SeriesDefinitions>
>> <Query>
>> </Query>
>> <SeriesPalette>
>> <Red>80</Red>
>> <Green>166</Green>
>> <Blue>218</Blue>
>> </Entries>
>> <Red>242</Red>
>> <Green>88</Green>
>> <Blue>106</Blue>
>> </Entries>
>> <Red>232</Red>
>> <Green>172</Green>
>> <Blue>57</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>255</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>64</Red>
>> <Green>128</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>128</Green>
>> <Blue>192</Blue>
>> </Entries>
>> <Red>170</Red>
>> <Green>85</Green>
>> <Blue>85</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>128</Green>
>> <Blue>0</Blue>
>> </Entries>
>> </SeriesPalette>
>> <Label>
>> <Caption>
>> <Font>
>> <Alignment/>
>> </Font>
>> </Caption>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Background>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>2.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> </Label>
>> <DataDefinition>
>> </DataDefinition>
>> <DataPoint>
>> <Components>
>> </Components>
>> </DataPoint>
>> </Series>
>> <Grouping>
>> </Grouping>
>> <LineAttributes>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </LineAttributes>
>> <Label>
>> <Caption>
>> <Font>
>> <Alignment/>
>> </Font>
>> </Caption>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Background>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>2.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> </Label>
>> <MajorGrid>
>> <LineAttributes>
>> <Color>
>> <Red>196</Red>
>> <Green>196</Green>
>> <Blue>196</Blue>
>> </Color>
>> </LineAttributes>
>> <TickAttributes>
>> <Color>
>> <Red>196</Red>
>> <Green>196</Green>
>> <Blue>196</Blue>
>> </Color>
>> </TickAttributes>
>> </MajorGrid>
>> <MinorGrid>
>> <LineAttributes>
>> <Color>
>> <Red>225</Red>
>> <Green>225</Green>
>> <Blue>225</Blue>
>> </Color>
>> </LineAttributes>
>> <TickAttributes>
>> <Color>
>> <Red>225</Red>
>> <Green>225</Green>
>> <Blue>225</Blue>
>> </Color>
>> </TickAttributes>
>> </MinorGrid>
>> <Scale>
>> </Scale>
>> <Origin>
>> <Type>Min</Type>
>> <Value>0.0</Value>
>> </Value>
>> </Origin>
>> </AssociatedAxes>
>> <SeriesDefinitions>
>> <Query>
>> </Query>
>> <SeriesPalette>
>> <Red>80</Red>
>> <Green>166</Green>
>> <Blue>218</Blue>
>> </Entries>
>> <Red>242</Red>
>> <Green>88</Green>
>> <Blue>106</Blue>
>> </Entries>
>> <Red>232</Red>
>> <Green>172</Green>
>> <Blue>57</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>255</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>64</Red>
>> <Green>128</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>128</Green>
>> <Blue>192</Blue>
>> </Entries>
>> <Red>170</Red>
>> <Green>85</Green>
>> <Blue>85</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>128</Green>
>> <Blue>0</Blue>
>> </Entries>
>> </SeriesPalette>
>> <Series>
>> <Label>
>> <Caption>
>> <Font>
>> <Alignment/>
>> </Font>
>> </Caption>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Background>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>2.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> </Label>
>> <DataDefinition>
>> </DataDefinition>
>> <DataPoint>
>> <Components>
>> </Components>
>> </DataPoint>
>> </Series>
>> <Grouping>
>> </Grouping>
>> <LineAttributes>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </LineAttributes>
>> <Label>
>> <Caption>
>> <Font>
>> <Alignment/>
>> </Font>
>> </Caption>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Background>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>2.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> </Label>
>> <MajorGrid>
>> <LineAttributes>
>> <Color>
>> <Red>196</Red>
>> <Green>196</Green>
>> <Blue>196</Blue>
>> </Color>
>> </LineAttributes>
>> <TickAttributes>
>> <Color>
>> <Red>196</Red>
>> <Green>196</Green>
>> <Blue>196</Blue>
>> </Color>
>> </TickAttributes>
>> </MajorGrid>
>> <MinorGrid>
>> <LineAttributes>
>> <Color>
>> <Red>225</Red>
>> <Green>225</Green>
>> <Blue>225</Blue>
>> </Color>
>> </LineAttributes>
>> <TickAttributes>
>> <Color>
>> <Red>225</Red>
>> <Green>225</Green>
>> <Blue>225</Blue>
>> </Color>
>> </TickAttributes>
>> </MinorGrid>
>> <Scale>
>> </Scale>
>> <Origin>
>> <Type>Min</Type>
>> <Value>0.0</Value>
>> </Value>
>> </Origin>
>> </Axes>
>> <Rotation/>
>>]]></xml-property>
>> </extended-item>
>> </body>
>></report>
>>Thanks,
>>Stefano
>>>Hi,
>>>Thanks,
>>>David
>>>>Hi,
>>>>message:
>>>>params["StartDate"]
>>>>Thanks,
>>>>Stefano
Re: params variable in chart [message #99997 is a reply to message #97140] |
Fri, 16 December 2005 10:25 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Nicolas Guillaumin![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=n.guillaumin%40cite-sciences.fr) Messages: 2 Registered: July 2009 |
I have exactly the same problem: A report with a chart that works great
with 2.0M2, and doesn't work with 2.0M3 at design time (preview works
however).
I think it's related to the new chart builder because I don't have any
problems with my dataset...
Nicolas
Here is my report design:
<list-property name="configVars">
<structure>
<property name="name">strWord</property>
<property name="value">dino%</property>
</structure>
</list-property>
<parameters>
<scalar-parameter name="strWord" id="6">
<text-property name="displayName">Entrez le masque de mot
souhaité</text-property>
<expression name="defaultValue">dino%</expression>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Videostats"
id="4">
<property
name="odaDriverClass">oracle.jdbc.OracleDriver</property>
<property
name="odaURL">jdbc:oracle:thin:@devomkt:1623:dev1</property >
<property name="odaUser">videostats</property>
<encrypted-property
name="odaPassword">dmlkZW9zdGF0cw==</encrypted-property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
name="SimpleTest" id="5">
<property name="dataSource">Videostats</property>
<structure>
<expression name="defaultValue">'dino%'</expression>
</structure>
</list-property>
VIDEOSTATS.CRITERE.VALEUR, count(VIDEOSTATS.RECHERCHE.ID_RECHERCHE) as
NB_RECHERCHES
from VIDEOSTATS.RECHERCHE, VIDEOSTATS.RECHERCHE_CRITERE, VIDEOSTATS.CRITERE
where VIDEOSTATS.RECHERCHE_CRITERE.ID_RECHERCHE =
and VIDEOSTATS.RECHERCHE_CRITERE.ID_CRITERE = VIDEOSTATS.CRITERE.ID_CRITERE
and VIDEOSTATS.CRITERE.TYPE_CRITERE = 'mot'
and VIDEOSTATS.CRITERE.VALEUR like ?
group by VIDEOSTATS.CRITERE.VALEUR
</property>
</oda-data-set>
</data-sets>
<page-setup>
<page-footer>
<text id="3">
<text-property
</text>
</page-footer>
</page-setup>
<body>
<property name="height">8in</property>
<property name="width">6in</property>
<property name="dataSet">SimpleTest</property>
<structure>
<property name="paramName">strWord</property>
<expression
name="expression">params["strWord"]</expression>
</structure>
</list-property>
<xml-property
<Block>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Label>
<Caption>
<Value>=Mots de recherche</Value>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Font>
<Alignment/>
</Font>
</Text>
<Title>
<Caption>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>432.0</Width>
<Height>576.0</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
</Block>
<SampleData>
<BaseSampleData>
</BaseSampleData>
</SampleData>
<Interactivity/>
<Axes>
<Type>Text</Type>
<Title>
<Caption>
<Value>Titre de l'axe des x</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<AssociatedAxes>
<Type>Linear</Type>
<Title>
<Caption>
<Value>Titre de l'axe des y</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<Label>
<Caption>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row["NB_RECHERCHES"]</Definition >
</DataDefinition>
<SeriesIdentifier>=Nombre de recherches</SeriesIdentifier>
<DataPoint>
<Components>
</Components>
</DataPoint>
</Series>
<Grouping>
</Grouping>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
</Scale>
<Origin>
<Type>Min</Type>
<Value>0.0</Value>
</Value>
</Origin>
</AssociatedAxes>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<Series>
<Label>
<Caption>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row["VALEUR"]</Definition>
</DataDefinition>
<SeriesIdentifier>=Mot</SeriesIdentifier>
<DataPoint>
<Components>
</Components>
</DataPoint>
</Series>
<Grouping>
</Grouping>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Font>
<Alignment/>
<Rotation>-90.0</Rotation>
</Font>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
</Scale>
<Origin>
<Type>Min</Type>
<Value>0.0</Value>
</Value>
</Origin>
</Axes>
<Rotation/>
]]></xml-property>
</extended-item>
</body>
</report>
David Michonneau a écrit :
> Stefano,
> David
Current Time: Wed Jul 17 15:12:17 GMT 2024
Powered by FUDForum. Page generated in 0.04321 seconds
