Home » Archived » Jubula » How to delete the parameters which belongs to the deleted steps
How to delete the parameters which belongs to the deleted steps [message #939784] Thu, 11 October 2012 03:35 Go to next message
Lizzy Liu is currently offline Lizzy LiuFriend
I have add 3 steps for a case, and one of the step, such as step3 has one parameter. I don't need the step3 anymore, so I delete this step, but in the Properties view, there still exist the parameter which belongs to the step3.
So the problem is : How can I remove this useless parameter? Thanks.
Re: How to delete the parameters which belongs to the deleted steps [message #939866 is a reply to message #939784] Thu, 11 October 2012 05:14 Go to previous messageGo to next message
Achim Loerke is currently offline Achim LoerkeFriend
Right click on the Test Case node (in the editor) and select "Edit Parameters". Remove, modify or add as necessary.
Achim
Re: How to delete the parameters which belongs to the deleted steps [message #939928 is a reply to message #939866] Thu, 11 October 2012 06:38 Go to previous message
Thanks.
It works.
Previous Topic:Using multiple users with Oracle XE
Next Topic:[SOLVED] Jubula and eclipse 3.7
Current Time: Sun Dec 22 06:31:06 GMT 2024
Powered by FUDForum. Page generated in 0.04741 seconds
