Home » Archived » Buckminster » Bring back svnkit16! :-)
Bring back svnkit16! :-) [message #931800] |
Wed, 03 October 2012 10:36  |
the latest Buckminster Subversive headless feature imports svnkit17.
However, that version introduced changes that make it incompatible with
older working copy formats (e.g., I can no longer determine latest
revision from a working copy checked out by an older svn command).
Is there any way to publish a different subversive headless feature that
would import svnkit16? Same as the current feature but with a different
id so that the user can choose at installation time to use the one that
imports svnkit16.
Thanks!
Re: Bring back svnkit16! :-) [message #933023 is a reply to message #933016] |
Thu, 04 October 2012 12:55   |
On 2012-04-10 18:48, Thomas Hallgren wrote:
> On 2012-10-04 17:21, Matthew Webber wrote:
>> This problem is not confined to Buckminster Subversive headless. When
>> some of us started using the Eclipse Juno (4.2)
>> IDE, we noticed that Buckminster Subclipse (which we use) requires
>> Subclipse 1.8/SVNKit 1.7, which means it uses a new
>> working copy format (the one used by subversion 1.7). Of course, the
>> svn command line client installed on our machines
>> is 1.6! This means that we canlt use the command line against anything
>> checked out by Buckminster.
>> If you want an svn 1.6-compatible client, the simplest way is to
>> install the Indigo (3.7) rather than the Juno (4.2)
>> flavour of Buckminster. It works ok for us.
>> Matthew
> Makes you wonder though, why the people behind SVN doesn't care about
> backward compatibility. I just took for granted that they did.
> Git anyone?
> - thomas
SVN kills from the other side of the grave...
So glad I am no longer using SVN - constant source of pain and grief.
For the poor souls that still do, can they drop just the buckminster
bundle requiring svnkit17 and install the older SVN support? (My guess
is that won't work, and they are then stuck with an older Buckminster).
- henrik
Re: Bring back svnkit16! :-) [message #933418 is a reply to message #933023] |
Thu, 04 October 2012 22:08   |
Would it be possible to add a feature like the attached? Installing this
new feature instead of the standard headless subversive support seems to
do the trick for me. I can create a bugzilla if there's any interest.
Thanks!
>>> Matthew
>> Git anyone?
>> - thomas
> - henrik
### Eclipse Workspace Patch 1.0
#P org.eclipse.buckminster.site.external
diff --git feature.xml feature.xml
index 3ae27ca..7cdfe7e 100644
--- feature.xml
+++ feature.xml
@@ -25,6 +25,10 @@
id="org.eclipse.buckminster.subversive.headless.feature"
version="0.0.0"/>
+ <includes
+ id="org.eclipse.buckminster.subversive.svnkit16.headless.feature"
+ version="0.0.0"/>
<plugin
id="org.tigris.subversion.subclipse.core"
download-size="0"
@@ -47,6 +51,13 @@
unpack="false"/>
<plugin
+ id="org.polarion.eclipse.team.svn.connector.svnkit16"
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
id="org.polarion.eclipse.team.svn.connector.svnkit17"
download-size="0"
install-size="0"
#P org.eclipse.buckminster.subversive.svnkit16.headless.feature
diff --git .project .project
new file mode 100644
index 0000000..a39fdec
--- /dev/null
+++ .project
@@ -0,0 +1,17 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<projectDescription>
+ <name>org.eclipse.buckminster.subversive.svnkit16.headless.feature</name>
+ <comment></comment>
+ <projects>
+ </projects>
+ <buildSpec>
+ <buildCommand>
+ <name>org.eclipse.pde.FeatureBuilder</name>
+ <arguments>
+ </arguments>
+ </buildCommand>
+ </buildSpec>
+ <natures>
+ <nature>org.eclipse.pde.FeatureNature</nature>
+ </natures>
+</projectDescription>
diff --git build.properties build.properties
index 0000000..64f93a9
--- /dev/null
+++ build.properties
@@ -0,0 +1 @@
+bin.includes = feature.xml
diff --git feature.properties feature.properties
index 0000000..c259703
--- /dev/null
+++ feature.properties
@@ -0,0 +1,19 @@
+# Copyright (c) 2006-2010, Cloudsmith Inc.
+# Copyright (c) 2012 Ecliptical Software Inc.
+# The code, documentation and other materials contained herein have been
+# licensed under the Eclipse Public License - v 1.0 by the copyright holder
+# listed above, as the Initial Contributor under such license. The text of
+# such license is available at www.eclipse.org.
+# feature.properties
+# contains externalized strings for feature.xml
+# "%foo" in feature.xml corresponds to the key "foo" in this file
+# java.io.Properties file (ISO 8859-1 with "\" escapes)
+# This file should be translated.
+# "featureName" property - name of the feature
+featureName=Buckminster - Headless Subversive support for SVNKit 1.6
+# "description" property - description of the feature
+description=Provides Headless Subversion integration for Buckminster using the Subversive using SVNKit 1.6
index 0000000..2587823
--- /dev/null
+++ feature.xml
@@ -0,0 +1,42 @@
+<feature
+ label="%featureName"
+ version="1.5.0.qualifier"
+ provider-name="%providerName"
+ license-feature="org.eclipse.buckminster.license.feature"
+ license-feature-version="1.0.0.qualifier">
+ <description>
+ %description
+ </description>
+ <copyright>
+ %copyright
+ </copyright>
+ <license url="%licenseURL">
+ %license
+ </license>
+ <requires>
+ <import plugin="org.eclipse.team.svn.core"/>
+ <import plugin="org.polarion.eclipse.team.svn.connector.svnkit16"/>
+ <import plugin="org.polarion.eclipse.team.svn.connector"/>
+ </requires>
+ <plugin
+ id="org.eclipse.buckminster.subversive"
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
+ id="org.eclipse.buckminster.subversion"
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+</feature>
\ No newline at end of file
Re: Bring back svnkit16! :-) [message #933422 is a reply to message #933023] |
Thanks!
>>> Matthew
>> Git anyone?
>> - thomas
> - henrik
--- feature.xml
+++ feature.xml
@@ -25,6 +25,10 @@
version="0.0.0"/>
+ <includes
+ version="0.0.0"/>
<plugin
download-size="0"
@@ -47,6 +51,13 @@
unpack="false"/>
<plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
download-size="0"
install-size="0"
--- /dev/null
+++ .project
@@ -0,0 +1,17 @@
+ <projects>
+ </projects>
+ <buildSpec>
+ <buildCommand>
+ <arguments>
+ </arguments>
+ </buildCommand>
+ </buildSpec>
+ <natures>
+ </natures>
--- /dev/null
@@ -0,0 +1 @@
--- /dev/null
@@ -0,0 +1,19 @@
--- /dev/null
+++ feature.xml
@@ -0,0 +1,42 @@
+<feature
+ <description>
+ %description
+ </description>
+ <copyright>
+ %copyright
+ </copyright>
+ %license
+ </license>
+ <requires>
+ </requires>
+ <plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+</feature>
Re: Bring back svnkit16! :-) [message #933426 is a reply to message #933023] |
Thanks!
>>> Matthew
>> Git anyone?
>> - thomas
> - henrik
--- feature.xml
+++ feature.xml
@@ -25,6 +25,10 @@
version="0.0.0"/>
+ <includes
+ version="0.0.0"/>
<plugin
download-size="0"
@@ -47,6 +51,13 @@
unpack="false"/>
<plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
download-size="0"
install-size="0"
--- /dev/null
+++ .project
@@ -0,0 +1,17 @@
+ <projects>
+ </projects>
+ <buildSpec>
+ <buildCommand>
+ <arguments>
+ </arguments>
+ </buildCommand>
+ </buildSpec>
+ <natures>
+ </natures>
--- /dev/null
@@ -0,0 +1 @@
--- /dev/null
@@ -0,0 +1,19 @@
--- /dev/null
+++ feature.xml
@@ -0,0 +1,42 @@
+<feature
+ <description>
+ %description
+ </description>
+ <copyright>
+ %copyright
+ </copyright>
+ %license
+ </license>
+ <requires>
+ </requires>
+ <plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+</feature>
Re: Bring back svnkit16! :-) [message #933430 is a reply to message #933023] |
Thanks!
>>> Matthew
>> Git anyone?
>> - thomas
> - henrik
--- feature.xml
+++ feature.xml
@@ -25,6 +25,10 @@
version="0.0.0"/>
+ <includes
+ version="0.0.0"/>
<plugin
download-size="0"
@@ -47,6 +51,13 @@
unpack="false"/>
<plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
download-size="0"
install-size="0"
--- /dev/null
+++ .project
@@ -0,0 +1,17 @@
+ <projects>
+ </projects>
+ <buildSpec>
+ <buildCommand>
+ <arguments>
+ </arguments>
+ </buildCommand>
+ </buildSpec>
+ <natures>
+ </natures>
--- /dev/null
@@ -0,0 +1 @@
--- /dev/null
@@ -0,0 +1,19 @@
--- /dev/null
+++ feature.xml
@@ -0,0 +1,42 @@
+<feature
+ <description>
+ %description
+ </description>
+ <copyright>
+ %copyright
+ </copyright>
+ %license
+ </license>
+ <requires>
+ </requires>
+ <plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+</feature>
Re: Bring back svnkit16! :-) [message #933434 is a reply to message #933023] |
Thanks!
>>> Matthew
>> Git anyone?
>> - thomas
> - henrik
--- feature.xml
+++ feature.xml
@@ -25,6 +25,10 @@
version="0.0.0"/>
+ <includes
+ version="0.0.0"/>
<plugin
download-size="0"
@@ -47,6 +51,13 @@
unpack="false"/>
<plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
download-size="0"
install-size="0"
--- /dev/null
+++ .project
@@ -0,0 +1,17 @@
+ <projects>
+ </projects>
+ <buildSpec>
+ <buildCommand>
+ <arguments>
+ </arguments>
+ </buildCommand>
+ </buildSpec>
+ <natures>
+ </natures>
--- /dev/null
@@ -0,0 +1 @@
--- /dev/null
@@ -0,0 +1,19 @@
--- /dev/null
+++ feature.xml
@@ -0,0 +1,42 @@
+<feature
+ <description>
+ %description
+ </description>
+ <copyright>
+ %copyright
+ </copyright>
+ %license
+ </license>
+ <requires>
+ </requires>
+ <plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+</feature>
Re: Bring back svnkit16! :-) [message #933438 is a reply to message #933023] |
Thanks!
>>> Matthew
>> Git anyone?
>> - thomas
> - henrik
--- feature.xml
+++ feature.xml
@@ -25,6 +25,10 @@
version="0.0.0"/>
+ <includes
+ version="0.0.0"/>
<plugin
download-size="0"
@@ -47,6 +51,13 @@
unpack="false"/>
<plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
download-size="0"
install-size="0"
--- /dev/null
+++ .project
@@ -0,0 +1,17 @@
+ <projects>
+ </projects>
+ <buildSpec>
+ <buildCommand>
+ <arguments>
+ </arguments>
+ </buildCommand>
+ </buildSpec>
+ <natures>
+ </natures>
--- /dev/null
@@ -0,0 +1 @@
--- /dev/null
@@ -0,0 +1,19 @@
--- /dev/null
+++ feature.xml
@@ -0,0 +1,42 @@
+<feature
+ <description>
+ %description
+ </description>
+ <copyright>
+ %copyright
+ </copyright>
+ %license
+ </license>
+ <requires>
+ </requires>
+ <plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+</feature>
Re: Bring back svnkit16! :-) [message #933442 is a reply to message #933023] |
Thanks!
>>> Matthew
>> Git anyone?
>> - thomas
> - henrik
--- feature.xml
+++ feature.xml
@@ -25,6 +25,10 @@
version="0.0.0"/>
+ <includes
+ version="0.0.0"/>
<plugin
download-size="0"
@@ -47,6 +51,13 @@
unpack="false"/>
<plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
download-size="0"
install-size="0"
--- /dev/null
+++ .project
@@ -0,0 +1,17 @@
+ <projects>
+ </projects>
+ <buildSpec>
+ <buildCommand>
+ <arguments>
+ </arguments>
+ </buildCommand>
+ </buildSpec>
+ <natures>
+ </natures>
--- /dev/null
@@ -0,0 +1 @@
--- /dev/null
@@ -0,0 +1,19 @@
--- /dev/null
+++ feature.xml
@@ -0,0 +1,42 @@
+<feature
+ <description>
+ %description
+ </description>
+ <copyright>
+ %copyright
+ </copyright>
+ %license
+ </license>
+ <requires>
+ </requires>
+ <plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+</feature>
Re: Bring back svnkit16! :-) [message #933472 is a reply to message #933418] |
Thu, 04 October 2012 23:23   |
Hi Peter,
Yes, please attach this to a bugzilla. It seems like a good solution.
- thomas
On 2012-10-05 04:08, Peter Nehrer wrote:
> Would it be possible to add a feature like the attached? Installing this new feature instead of the standard headless
> subversive support seems to do the trick for me. I can create a bugzilla if there's any interest. Thanks!
>>>> Matthew
>>> Git anyone?
>>> - thomas
>> - henrik
Re: Bring back svnkit16! :-) [message #933921 is a reply to message #933472] |
Fri, 05 October 2012 09:09   |
Created https://bugs.eclipse.org/391227. Thanks!
On 10/4/12 11:23 PM, Thomas Hallgren wrote:
> Hi Peter,
> - thomas
>>>>> Matthew
>>>> Git anyone?
>>>> - thomas
>>> - henrik
Re: Bring back svnkit16! :-) [message #937801 is a reply to message #932927] |
Tue, 09 October 2012 05:13  |
> This problem is not confined to Buckminster Subversive headless. When some of us started using the Eclipse Juno (4.2)
> IDE, we noticed that Buckminster Subclipse (which we use) requires Subclipse 1.8/SVNKit 1.7,
For Subclipse, we require org.tigris.subversion.subclipse.core which in turn requires 1.8. Subversive handles this
differently and will allow a choice of 1.6 and 1.7 underneath. The best solution in the IDE is therefore probably to use
Subversive when a mixed environment with 1.6 is required.
Buckminster will install fine in a 4.2 IDE with a Subversive installation which in turn uses SVNKit 1.6.
Thomas Hallgren
Current Time: Mon Mar 10 21:48:17 EDT 2025
Powered by FUDForum. Page generated in 0.03579 seconds
