Home » Archived » Buckminster » Bring back svnkit16! :-)
Re: Bring back svnkit16! :-) [message #933016 is a reply to message #932927] |
Thu, 04 October 2012 16:48 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
On 2012-10-04 17:21, Matthew Webber wrote:
> This problem is not confined to Buckminster Subversive headless. When some of us started using the Eclipse Juno (4.2)
> IDE, we noticed that Buckminster Subclipse (which we use) requires Subclipse 1.8/SVNKit 1.7, which means it uses a new
> working copy format (the one used by subversion 1.7). Of course, the svn command line client installed on our machines
> is 1.6! This means that we canlt use the command line against anything checked out by Buckminster.
> If you want an svn 1.6-compatible client, the simplest way is to install the Indigo (3.7) rather than the Juno (4.2)
> flavour of Buckminster. It works ok for us.
> Matthew
Makes you wonder though, why the people behind SVN doesn't care about backward compatibility. I just took for granted
that they did.
Git anyone?
- thomas
Re: Bring back svnkit16! :-) [message #933023 is a reply to message #933016] |
Thu, 04 October 2012 16:55 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Henrik Lindberg![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=henrik.lindberg%40puppet.com) Messages: 2509 Registered: July 2009 |
>> Matthew
> backward compatibility. I just took for granted that they did.
> Git anyone?
> - thomas
SVN kills from the other side of the grave...
So glad I am no longer using SVN - constant source of pain and grief.
For the poor souls that still do, can they drop just the buckminster
bundle requiring svnkit17 and install the older SVN support? (My guess
is that won't work, and they are then stuck with an older Buckminster).
- henrik
Re: Bring back svnkit16! :-) [message #933418 is a reply to message #933023] |
Fri, 05 October 2012 02:08 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Peter Nehrer![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=pnehrer%40eclipticalsoftware.com) Messages: 241 Registered: July 2009 |
Would it be possible to add a feature like the attached? Installing this
new feature instead of the standard headless subversive support seems to
do the trick for me. I can create a bugzilla if there's any interest.
Thanks!
>>> Matthew
>> Git anyone?
>> - thomas
> - henrik
### Eclipse Workspace Patch 1.0
#P org.eclipse.buckminster.site.external
diff --git feature.xml feature.xml
index 3ae27ca..7cdfe7e 100644
--- feature.xml
+++ feature.xml
@@ -25,6 +25,10 @@
id="org.eclipse.buckminster.subversive.headless.feature"
version="0.0.0"/>
+ <includes
+ id="org.eclipse.buckminster.subversive.svnkit16.headless.feature"
+ version="0.0.0"/>
<plugin
id="org.tigris.subversion.subclipse.core"
download-size="0"
@@ -47,6 +51,13 @@
unpack="false"/>
<plugin
+ id="org.polarion.eclipse.team.svn.connector.svnkit16"
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
id="org.polarion.eclipse.team.svn.connector.svnkit17"
download-size="0"
install-size="0"
#P org.eclipse.buckminster.subversive.svnkit16.headless.feature
diff --git .project .project
new file mode 100644
index 0000000..a39fdec
--- /dev/null
+++ .project
@@ -0,0 +1,17 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<projectDescription>
+ <name>org.eclipse.buckminster.subversive.svnkit16.headless.feature</name>
+ <comment></comment>
+ <projects>
+ </projects>
+ <buildSpec>
+ <buildCommand>
+ <name>org.eclipse.pde.FeatureBuilder</name>
+ <arguments>
+ </arguments>
+ </buildCommand>
+ </buildSpec>
+ <natures>
+ <nature>org.eclipse.pde.FeatureNature</nature>
+ </natures>
+</projectDescription>
diff --git build.properties build.properties
index 0000000..64f93a9
--- /dev/null
+++ build.properties
@@ -0,0 +1 @@
+bin.includes = feature.xml
diff --git feature.properties feature.properties
index 0000000..c259703
--- /dev/null
+++ feature.properties
@@ -0,0 +1,19 @@
+# Copyright (c) 2006-2010, Cloudsmith Inc.
+# Copyright (c) 2012 Ecliptical Software Inc.
+# The code, documentation and other materials contained herein have been
+# licensed under the Eclipse Public License - v 1.0 by the copyright holder
+# listed above, as the Initial Contributor under such license. The text of
+# such license is available at www.eclipse.org.
+# feature.properties
+# contains externalized strings for feature.xml
+# "%foo" in feature.xml corresponds to the key "foo" in this file
+# java.io.Properties file (ISO 8859-1 with "\" escapes)
+# This file should be translated.
+# "featureName" property - name of the feature
+featureName=Buckminster - Headless Subversive support for SVNKit 1.6
+# "description" property - description of the feature
+description=Provides Headless Subversion integration for Buckminster using the Subversive using SVNKit 1.6
index 0000000..2587823
--- /dev/null
+++ feature.xml
@@ -0,0 +1,42 @@
+<feature
+ label="%featureName"
+ version="1.5.0.qualifier"
+ provider-name="%providerName"
+ license-feature="org.eclipse.buckminster.license.feature"
+ license-feature-version="1.0.0.qualifier">
+ <description>
+ %description
+ </description>
+ <copyright>
+ %copyright
+ </copyright>
+ <license url="%licenseURL">
+ %license
+ </license>
+ <requires>
+ <import plugin="org.eclipse.team.svn.core"/>
+ <import plugin="org.polarion.eclipse.team.svn.connector.svnkit16"/>
+ <import plugin="org.polarion.eclipse.team.svn.connector"/>
+ </requires>
+ <plugin
+ id="org.eclipse.buckminster.subversive"
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
+ id="org.eclipse.buckminster.subversion"
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+</feature>
\ No newline at end of file
Re: Bring back svnkit16! :-) [message #933422 is a reply to message #933023] |
Thanks!
>>> Matthew
>> Git anyone?
>> - thomas
> - henrik
--- feature.xml
+++ feature.xml
@@ -25,6 +25,10 @@
version="0.0.0"/>
+ <includes
+ version="0.0.0"/>
<plugin
download-size="0"
@@ -47,6 +51,13 @@
unpack="false"/>
<plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
download-size="0"
install-size="0"
--- /dev/null
+++ .project
@@ -0,0 +1,17 @@
+ <projects>
+ </projects>
+ <buildSpec>
+ <buildCommand>
+ <arguments>
+ </arguments>
+ </buildCommand>
+ </buildSpec>
+ <natures>
+ </natures>
--- /dev/null
@@ -0,0 +1 @@
--- /dev/null
@@ -0,0 +1,19 @@
--- /dev/null
+++ feature.xml
@@ -0,0 +1,42 @@
+<feature
+ <description>
+ %description
+ </description>
+ <copyright>
+ %copyright
+ </copyright>
+ %license
+ </license>
+ <requires>
+ </requires>
+ <plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+</feature>
Re: Bring back svnkit16! :-) [message #933426 is a reply to message #933023] |
Thanks!
>>> Matthew
>> Git anyone?
>> - thomas
> - henrik
--- feature.xml
+++ feature.xml
@@ -25,6 +25,10 @@
version="0.0.0"/>
+ <includes
+ version="0.0.0"/>
<plugin
download-size="0"
@@ -47,6 +51,13 @@
unpack="false"/>
<plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
download-size="0"
install-size="0"
--- /dev/null
+++ .project
@@ -0,0 +1,17 @@
+ <projects>
+ </projects>
+ <buildSpec>
+ <buildCommand>
+ <arguments>
+ </arguments>
+ </buildCommand>
+ </buildSpec>
+ <natures>
+ </natures>
--- /dev/null
@@ -0,0 +1 @@
--- /dev/null
@@ -0,0 +1,19 @@
--- /dev/null
+++ feature.xml
@@ -0,0 +1,42 @@
+<feature
+ <description>
+ %description
+ </description>
+ <copyright>
+ %copyright
+ </copyright>
+ %license
+ </license>
+ <requires>
+ </requires>
+ <plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+</feature>
Re: Bring back svnkit16! :-) [message #933430 is a reply to message #933023] |
Thanks!
>>> Matthew
>> Git anyone?
>> - thomas
> - henrik
--- feature.xml
+++ feature.xml
@@ -25,6 +25,10 @@
version="0.0.0"/>
+ <includes
+ version="0.0.0"/>
<plugin
download-size="0"
@@ -47,6 +51,13 @@
unpack="false"/>
<plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
download-size="0"
install-size="0"
--- /dev/null
+++ .project
@@ -0,0 +1,17 @@
+ <projects>
+ </projects>
+ <buildSpec>
+ <buildCommand>
+ <arguments>
+ </arguments>
+ </buildCommand>
+ </buildSpec>
+ <natures>
+ </natures>
--- /dev/null
@@ -0,0 +1 @@
--- /dev/null
@@ -0,0 +1,19 @@
--- /dev/null
+++ feature.xml
@@ -0,0 +1,42 @@
+<feature
+ <description>
+ %description
+ </description>
+ <copyright>
+ %copyright
+ </copyright>
+ %license
+ </license>
+ <requires>
+ </requires>
+ <plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+</feature>
Re: Bring back svnkit16! :-) [message #933434 is a reply to message #933023] |
Thanks!
>>> Matthew
>> Git anyone?
>> - thomas
> - henrik
--- feature.xml
+++ feature.xml
@@ -25,6 +25,10 @@
version="0.0.0"/>
+ <includes
+ version="0.0.0"/>
<plugin
download-size="0"
@@ -47,6 +51,13 @@
unpack="false"/>
<plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
download-size="0"
install-size="0"
--- /dev/null
+++ .project
@@ -0,0 +1,17 @@
+ <projects>
+ </projects>
+ <buildSpec>
+ <buildCommand>
+ <arguments>
+ </arguments>
+ </buildCommand>
+ </buildSpec>
+ <natures>
+ </natures>
--- /dev/null
@@ -0,0 +1 @@
--- /dev/null
@@ -0,0 +1,19 @@
--- /dev/null
+++ feature.xml
@@ -0,0 +1,42 @@
+<feature
+ <description>
+ %description
+ </description>
+ <copyright>
+ %copyright
+ </copyright>
+ %license
+ </license>
+ <requires>
+ </requires>
+ <plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+</feature>
Re: Bring back svnkit16! :-) [message #933438 is a reply to message #933023] |
Thanks!
>>> Matthew
>> Git anyone?
>> - thomas
> - henrik
--- feature.xml
+++ feature.xml
@@ -25,6 +25,10 @@
version="0.0.0"/>
+ <includes
+ version="0.0.0"/>
<plugin
download-size="0"
@@ -47,6 +51,13 @@
unpack="false"/>
<plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
download-size="0"
install-size="0"
--- /dev/null
+++ .project
@@ -0,0 +1,17 @@
+ <projects>
+ </projects>
+ <buildSpec>
+ <buildCommand>
+ <arguments>
+ </arguments>
+ </buildCommand>
+ </buildSpec>
+ <natures>
+ </natures>
--- /dev/null
@@ -0,0 +1 @@
--- /dev/null
@@ -0,0 +1,19 @@
--- /dev/null
+++ feature.xml
@@ -0,0 +1,42 @@
+<feature
+ <description>
+ %description
+ </description>
+ <copyright>
+ %copyright
+ </copyright>
+ %license
+ </license>
+ <requires>
+ </requires>
+ <plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+</feature>
Re: Bring back svnkit16! :-) [message #933442 is a reply to message #933023] |
Thanks!
>>> Matthew
>> Git anyone?
>> - thomas
> - henrik
--- feature.xml
+++ feature.xml
@@ -25,6 +25,10 @@
version="0.0.0"/>
+ <includes
+ version="0.0.0"/>
<plugin
download-size="0"
@@ -47,6 +51,13 @@
unpack="false"/>
<plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
download-size="0"
install-size="0"
--- /dev/null
+++ .project
@@ -0,0 +1,17 @@
+ <projects>
+ </projects>
+ <buildSpec>
+ <buildCommand>
+ <arguments>
+ </arguments>
+ </buildCommand>
+ </buildSpec>
+ <natures>
+ </natures>
--- /dev/null
@@ -0,0 +1 @@
--- /dev/null
@@ -0,0 +1,19 @@
--- /dev/null
+++ feature.xml
@@ -0,0 +1,42 @@
+<feature
+ <description>
+ %description
+ </description>
+ <copyright>
+ %copyright
+ </copyright>
+ %license
+ </license>
+ <requires>
+ </requires>
+ <plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+ <plugin
+ download-size="0"
+ install-size="0"
+ version="0.0.0"
+ unpack="false"/>
+</feature>
Re: Bring back svnkit16! :-) [message #933472 is a reply to message #933418] |
Fri, 05 October 2012 03:23 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Peter,
Yes, please attach this to a bugzilla. It seems like a good solution.
- thomas
On 2012-10-05 04:08, Peter Nehrer wrote:
> Would it be possible to add a feature like the attached? Installing this new feature instead of the standard headless
> subversive support seems to do the trick for me. I can create a bugzilla if there's any interest. Thanks!
>>>> Matthew
>>> Git anyone?
>>> - thomas
>> - henrik
Re: Bring back svnkit16! :-) [message #933921 is a reply to message #933472] |
Fri, 05 October 2012 13:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Created https://bugs.eclipse.org/391227. Thanks!
On 10/4/12 11:23 PM, Thomas Hallgren wrote:
> Hi Peter,
> - thomas
>>>>> Matthew
>>>> Git anyone?
>>>> - thomas
>>> - henrik
Re: Bring back svnkit16! :-) [message #937801 is a reply to message #932927] |
Tue, 09 October 2012 09:13 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
For Subclipse, we require org.tigris.subversion.subclipse.core which in turn requires 1.8. Subversive handles this
differently and will allow a choice of 1.6 and 1.7 underneath. The best solution in the IDE is therefore probably to use
Subversive when a mixed environment with 1.6 is required.
Buckminster will install fine in a 4.2 IDE with a Subversive installation which in turn uses SVNKit 1.6.
Thomas Hallgren
Current Time: Sat Jul 27 12:49:58 GMT 2024
Powered by FUDForum. Page generated in 0.04742 seconds
