[SOLVED] How to specify the properties folder to report [message #917992] |
Thu, 20 September 2012 16:23 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Blaine Mising name![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=sauron1666%40yahoo.es) Messages: 25 Registered: December 2010 |
I saw that properties files can be added to the report. In preview mode it works, but deployin application in tomcat it doesn't read it.
My application starts the viewer in a jps file.
Here is the code:
<birt:viewer id="birtViewer"
pattern="frameset"
reportDesign="${pathReportAttribute}.rptdesign"
format="html"
rtl="${rtl}"
locale="${locale}"
frameborder="No"
scrolling="No"
showParameterPage="true"
</birt:viewer>
Is it possible to specify the properties folder when viewer starts? How?
[Updated on: Fri, 21 September 2012 09:29] Report message to a moderator
Re: How to specify the properties folder to report [message #929222 is a reply to message #928439] |
Mon, 01 October 2012 09:52 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Here you are the jsp code:
pattern="frameset"
resourceFolder="<%=resPath%>"
format="html"
rtl="${rtl}"
locale="${locale}"
frameborder="No"
scrolling="No"
showParameterPage="true">
</birt:viewer>
resPath is the full path but you should take in to account the folder specified in your reports.
For example, if you've configured in your report that resources path is "properties\i18n" folder, and your properties are in "C:\reports\properties\i18n" respPath value should be "C:\reports" and not "C:\reports\properties\i18n".
[Updated on: Mon, 01 October 2012 09:52] Report message to a moderator
FUDForum. Page generated in 0.03793 seconds
