Home » Language IDEs » PHP Development Tools (PDT) » problem with Zend Debugger and PDT2
Re: problem with Zend Debugger and PDT2 [message #91407 is a reply to message #91390] |
Thu, 22 January 2009 15:34 |
Zdenek Machek Messages: 12 Registered: July 2009 |
log attached. WIN XP Prof SP3 EN
!SESSION 2009-01-22 15:23:41.373
eclipse.buildId=M20080911-1700
java.version=1.6.0_11
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.equinox.p2.director 2 0 2009-01-22 15:23:45.405
!MESSAGE Problems resolving provisioning plan.
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2009-01-22 15:23:45.405
!MESSAGE Unable to satisfy dependency from
org.zend.php.debug_feature.feature.group 5.2.15.v20081217 to
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.php_feature.feature.gr oup/[1.0.2,1.1.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.dltk.rse.core
1.0.0.v20081208-2006 to requiredCapability:
osgi.bundle/org.eclipse.rse.core/0.0.0.
osgi.bundle/org.eclipse.rse.subsystems.files.core/0.0.0.
osgi.bundle/org.eclipse.rse.subsystems.shells.core/0.0.0.
osgi.bundle/org.eclipse.rse.efs/0.0.0.
osgi.bundle/org.eclipse.rse.services/0.0.0.
!MESSAGE Unable to satisfy dependency from org.eclipse.dltk.rse.ui
1.0.0.v20080815-1326 to requiredCapability:
osgi.bundle/org.eclipse.rse.ui/0.0.0.
osgi.bundle/org.eclipse.rse.files.ui/0.0.0.
osgi.bundle/org.eclipse.rse.subsystems.files.core/3.0.0.
org.eclipse.emf.codegen.ecore.ui 2.4.1.v200808251517 to
requiredCapability: osgi.bundle/org.eclipse.jdt.core/[3.4.0,4.0.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.emf.codegen.ecore
2.4.1.v200808251517 to requiredCapability:
osgi.bundle/org.eclipse.jdt.launching/[3.4.0,4.0.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.emf.codegen.ui
2.4.0.v200808251517 to requiredCapability:
!MESSAGE Unable to satisfy dependency from org.eclipse.emf.importer.java
org.eclipse.dltk.rse.feature.group 1.0.0.v20080815-1326-2--8s733I4C4F1665E
org.eclipse.equinox.p2.iu/org.eclipse.rse.core.feature.group /[3.0.0,4.0.0).
org.eclipse.emf.codegen.ecore.ui.feature.group 2.4.1.v200808251517 to
requiredCapability: org.eclipse.equinox.p2.iu/org.eclipse.jdt.core/0.0.0.
org.eclipse.emf.codegen.ecore.feature.group 2.4.1.v200808251517 to
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.jdt.launching/0.0.0.
org.eclipse.emf.codegen.ui.feature.group 2.4.0.v200808251517 to
requiredCapability:
org.eclipse.emf.codegen.feature.group 2.4.0.v200808251517 to
requiredCapability:
org.eclipse.emf.converter.feature.group 2.4.1.v200808251517 to
!ENTRY org.eclipse.wst.common.project.facet.core 4 0 2009-01-22
15:24:23.091
!MESSAGE Project facet jst.web has not been defined. It is used in plugin
org.eclipse.wst.jsdt.web.core.
15:24:23.091
!ENTRY org.eclipse.equinox.p2.metadata.repository 2 0 2009-01-22
15:26:58.384
!MESSAGE Error parsing metadata repository
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-01-22 15:26:58.384
!MESSAGE Error at line 10, column 91: Missing required attribute in
"repository": url
!MESSAGE Error at line 10, column 91: Illegal value for attribute "url" of
element "repository": null
!MESSAGE Error at line 11, column 91: Missing required attribute in
"repository": url
!MESSAGE Error at line 11, column 91: Illegal value for attribute "url" of
!MESSAGE Error at line 12, column 90: Missing required attribute in
"repository": url
!MESSAGE Error at line 12, column 90: Illegal value for attribute "url" of
!MESSAGE Error at line 13, column 90: Missing required attribute in
"repository": url
!MESSAGE Error at line 13, column 90: Illegal value for attribute "url" of
!ENTRY org.eclipse.equinox.p2.director 2 0 2009-01-22 15:26:58.587
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2009-01-22 15:26:58.587
requiredCapability:
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.sse.core
1.1.203.v200802140626 to requiredCapability:
osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.sse.ui
1.0.305.v200802142230 to requiredCapability:
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.ui
1.1.200.v200705302225 to requiredCapability:
osgi.bundle/org.eclipse.ui.ide/[3.2.0,3.4.0).
osgi.bundle/org.eclipse.ui/[3.2.0,3.4.0).
osgi.bundle/org.eclipse.core.runtime/[3.2.0,3.4.0).
osgi.bundle/org.eclipse.core.resources/[3.2.0,3.4.0).
osgi.bundle/org.eclipse.search/[3.2.0,3.4.0).
osgi.bundle/org.eclipse.jface.text/[3.2.0,3.4.0).
osgi.bundle/org.eclipse.ui.workbench.texteditor/[3.2.0,3.4.0 ).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.wsdl
1.1.101.v200801152132 to requiredCapability:
osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
osgi.bundle/org.eclipse.xsd/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.core
1.1.101.v200706120315 to requiredCapability:
osgi.bundle/org.eclipse.core.expressions/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.command.env
1.0.205.v200710161954 to requiredCapability:
osgi.bundle/org.eclipse.ant.core/[3.1.100,3.2.0).
1.0.204.v200711140435 to requiredCapability:
osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.ws.ui
1.0.203.v200708222126 to requiredCapability:
org.eclipse.wst.common.modulecore 1.1.105.v200806190339 to
requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
requiredCapability: osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4.0).
org.eclipse.wst.common.modulecore 1.1.104.v200802192030 to
org.eclipse.wst.common.environment 1.0.200.v200705302225 to
requiredCapability: osgi.bundle/org.eclipse.core.resources/[3.2.0,3.4.0).
org.eclipse.wst.common.frameworks 1.1.103.v200802192030 to
org.eclipse.wst.common.emfworkbench.integration 1.1.105.v200802192030 to
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2009-01-22 15:26:58.603
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.command.env.ui
1.0.203.v200709052219 to requiredCapability:
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.web
1.1.103.v200802192030 to requiredCapability:
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.emf
1.1.104.v200709131115 to requiredCapability:
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.wsi
1.0.105.v200706120315 to requiredCapability:
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.xsd.core
1.1.202.v200710011705 to requiredCapability:
!ENTRY org.eclipse.equinox.p2.director 4 0 2009-01-22 15:26:59.134
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2009-01-22 15:26:59.134
requiredCapability:
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 0 2009-01-22 15:26:59.134
!MESSAGE No solution found because the problem in C
Re: problem with Zend Debugger and PDT2 [message #91483 is a reply to message #91437] |
Fri, 23 January 2009 01:23 |
Originally posted by: none.none.com
Fantastic!!
I was having this same problem and I thought it was just me! Kudos for
getting a fix out.
On Thu, 22 Jan 2009 16:18:08 +0000 (UTC), roy@zend.com (Roy Ganor)
wrote:
>Hi ZM,
>I found the root cause of this problem. under
><pdt_folder> /eclipse/features/org.zend.php.debug_feature_5.2.15v20081217
>the file feature.xml should be updated in line 25, version should be
>"2.0.0".
>I fixed in our repository and it should be delivered in the next drop of
>Zend Debugger, important to say this problem doesn't effect the debug
>capabilities in PDT...
>Thanks again,
>Roy
>ZM wrote:
>> Strange is, that I tried even this distribution
>> pdt-2.0.0GA_debugger-5.2.15.v20081217-all-in-one-win32.zip, but when I
>> started eclipse, no Zend debuger was loaded and when I tried to install it
>> from http://downloads.zend.com/pdt same problem.
>> Java(TM) SE Runtime Environment (build 1.6.0_11-b03)
Re: problem with Zend Debugger and PDT2 [message #92169 is a reply to message #91437] |
Wed, 28 January 2009 13:43 |
Dejan Mancic Messages: 1 Registered: July 2009 |
I have the same problem on Windows XP SP2, but I can't find this file
path.
I go to "c:\eclipse\features\", but there I got only PDT folder under
org.eclipse.php_feature_2.0.0.v20081229-1135.
I don't have folder org.zend.php.debug_feature_5.2.15v20081217, because
Zend debugger is not installed at all, because of the mentioned error.
How can I fix this?
Thank you in advance.
Roy Ganor wrote:
> Hi ZM,
> "2.0.0".
> Thanks again,
> Roy
Re: problem with Zend Debugger and PDT2 [message #97096 is a reply to message #91317] |
Fri, 08 May 2009 19:37 |
Jonathan Messages: 2 Registered: July 2009 |
I cannot install the Zend debugger (that is not included with the
all-in-one package)
When I try to update it in Eclipse Platform Version: 3.4.1 by going to
Software Updates and Add-ons » Available Software and try to install from
the http://downloads.zend.com/pdt, I get the following error message: 'The
software items you have selected may not be valid with your current
installation. Would you like to open the Wizard for more details?' Or
something to that effect. The following error message, through the Wizard,
is:
Cannot complete the request. See the details.
Unsatisfied dependency: [org.zend.php.debug_feature.feature.group
5.2.15.v20081217] requiredCapability:
Unsatisfied dependency: [org.eclipse.platform.feature.group
3.4.1.r341_v20080731-9I96EiDElYevwz-p1bP5z-NlAaP7vtX6Utotqsu ]
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.debug.core/[3.4.0.v200 80612,3.4.0.v20080612]
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.help.feature.group/[1. 0.1.R34x_v20080827-7r7xEIxEI6Zu5nEqN7M3UBpglaat,1.0.1.R34x_v 20080827-7r7xEIxEI6Zu5nEqN7M3UBpglaat]
Unsatisfied dependency: [org.eclipse.platform.ide 3.4.0.M20080911-1700]
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.platform.feature.group /[3.4.1.r341_v20080731-9I96EiDElYevwz-p1bP5z-NlAaP7vtX6Utotq su,3.4.1.r341_v20080731-9I96EiDElYevwz-p1bP5z-NlAaP7vtX6Utot qsu]
Unsatisfied dependency: [org.eclipse.help.feature.group
1.0.1.R34x_v20080827-7r7xEIxEI6Zu5nEqN7M3UBpglaat] requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.rcp.feature.group/[3.4 .100.r341_v20080814-989JESIEdAciFYfkZZsBfSwQ2341,3.4.100.r34 1_v20080814-989JESIEdAciFYfkZZsBfSwQ2341]
Unsatisfied dependency: [org.eclipse.rcp.feature.group
3.4.100.r341_v20080814-989JESIEdAciFYfkZZsBfSwQ2341] requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.ui.workbench/[3.4.1.M2 0080827-0800a,3.4.1.M20080827-0800a]
Kind regards,
Jonathan
Current Time: Fri Jan 03 04:00:42 GMT 2025
Powered by FUDForum. Page generated in 0.04708 seconds
