Home » Language IDEs » PHP Development Tools (PDT) » problem with Zend Debugger and PDT2
problem with Zend Debugger and PDT2 [message #91301] Thu, 22 January 2009 12:32 Go to next message
Zdenek Machek is currently offline Zdenek MachekFriend
When I try to install Zend Debugger 5.2.15.v20081217 I get an error.
Debugger version 5.2.14. works fine.
I tried to install org.eclipse.equinox.p2.iu v 1.1.0, but it was causing
some other problems.
Any idea what's wrong?
PDT v2.0.0GA.
Cannot complete the request. See the details.
Unsatisfied dependency: [org.zend.php.debug_feature.feature.group
5.2.15.v20081217] requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.php_feature.feature.gr oup/[1.0.2,1.1.0)
Unsatisfied dependency: [org.eclipse.jdt.feature.group
3.4.1.r341_v20080709-0800-7o7tEAfEF_U5qyUgrb2HAp539P97]
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.jdt.core/[3.4.2.v_883_ R34x,3.4.2.v_883_R34x]
Re: problem with Zend Debugger and PDT2 [message #91317 is a reply to message #91301] Thu, 22 January 2009 12:40 Go to previous messageGo to next message
Roy Ganor is currently offline Roy GanorFriend
I'll be happy to assist you if you provide more details about how you
install the Zend Debugger.
Anyway you can use the all in one bundle that works out of the box from:
http://zend.com/pdt
> PDT v2.0.0GA.
> requiredCapability:
Re: problem with Zend Debugger and PDT2 [message #91331 is a reply to message #91317] Thu, 22 January 2009 12:48 Go to previous messageGo to next message
sNop is currently offline sNopFriend
Roy Ganor napsal(a):
> http://zend.com/pdt
the same, there are unresolved dependencies
Re: problem with Zend Debugger and PDT2 [message #91376 is a reply to message #91317] Thu, 22 January 2009 15:02 Go to previous messageGo to next message
Strange is, that I tried even this distribution
pdt-2.0.0GA_debugger-5.2.15.v20081217-all-in-one-win32.zip, but when I
started eclipse, no Zend debuger was loaded and when I tried to install it
from http://downloads.zend.com/pdt same problem.
Java(TM) SE Runtime Environment (build 1.6.0_11-b03)
Re: problem with Zend Debugger and PDT2 [message #91390 is a reply to message #91376] Thu, 22 January 2009 15:17 Go to previous messageGo to next message
Can you attach the full log file? What OS do you use?
(it's really strange, I did this action several times and I've never
encounter such a problem)
Thanks for reporting!
Re: problem with Zend Debugger and PDT2 [message #91407 is a reply to message #91390] Thu, 22 January 2009 15:34 Go to previous messageGo to next message
log attached. WIN XP Prof SP3 EN
!SESSION 2009-01-22 15:23:41.373
eclipse.buildId=M20080911-1700
java.version=1.6.0_11
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.equinox.p2.director 2 0 2009-01-22 15:23:45.405
!MESSAGE Problems resolving provisioning plan.
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2009-01-22 15:23:45.405
!MESSAGE Unable to satisfy dependency from
org.zend.php.debug_feature.feature.group 5.2.15.v20081217 to
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.php_feature.feature.gr oup/[1.0.2,1.1.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.dltk.rse.core
1.0.0.v20081208-2006 to requiredCapability:
osgi.bundle/org.eclipse.rse.core/0.0.0.
osgi.bundle/org.eclipse.rse.subsystems.files.core/0.0.0.
osgi.bundle/org.eclipse.rse.subsystems.shells.core/0.0.0.
osgi.bundle/org.eclipse.rse.efs/0.0.0.
osgi.bundle/org.eclipse.rse.services/0.0.0.
!MESSAGE Unable to satisfy dependency from org.eclipse.dltk.rse.ui
1.0.0.v20080815-1326 to requiredCapability:
osgi.bundle/org.eclipse.rse.ui/0.0.0.
osgi.bundle/org.eclipse.rse.files.ui/0.0.0.
osgi.bundle/org.eclipse.rse.subsystems.files.core/3.0.0.
org.eclipse.emf.codegen.ecore.ui 2.4.1.v200808251517 to
requiredCapability: osgi.bundle/org.eclipse.jdt.core/[3.4.0,4.0.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.emf.codegen.ecore
2.4.1.v200808251517 to requiredCapability:
osgi.bundle/org.eclipse.jdt.launching/[3.4.0,4.0.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.emf.codegen.ui
2.4.0.v200808251517 to requiredCapability:
!MESSAGE Unable to satisfy dependency from org.eclipse.emf.importer.java
org.eclipse.dltk.rse.feature.group 1.0.0.v20080815-1326-2--8s733I4C4F1665E
org.eclipse.equinox.p2.iu/org.eclipse.rse.core.feature.group /[3.0.0,4.0.0).
org.eclipse.emf.codegen.ecore.ui.feature.group 2.4.1.v200808251517 to
requiredCapability: org.eclipse.equinox.p2.iu/org.eclipse.jdt.core/0.0.0.
org.eclipse.emf.codegen.ecore.feature.group 2.4.1.v200808251517 to
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.jdt.launching/0.0.0.
org.eclipse.emf.codegen.ui.feature.group 2.4.0.v200808251517 to
requiredCapability:
org.eclipse.emf.codegen.feature.group 2.4.0.v200808251517 to
requiredCapability:
org.eclipse.emf.converter.feature.group 2.4.1.v200808251517 to
!ENTRY org.eclipse.wst.common.project.facet.core 4 0 2009-01-22
15:24:23.091
!MESSAGE Project facet jst.web has not been defined. It is used in plugin
org.eclipse.wst.jsdt.web.core.
15:24:23.091
!ENTRY org.eclipse.equinox.p2.metadata.repository 2 0 2009-01-22
15:26:58.384
!MESSAGE Error parsing metadata repository
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-01-22 15:26:58.384
!MESSAGE Error at line 10, column 91: Missing required attribute in
"repository": url
!MESSAGE Error at line 10, column 91: Illegal value for attribute "url" of
element "repository": null
!MESSAGE Error at line 11, column 91: Missing required attribute in
"repository": url
!MESSAGE Error at line 11, column 91: Illegal value for attribute "url" of
!MESSAGE Error at line 12, column 90: Missing required attribute in
"repository": url
!MESSAGE Error at line 12, column 90: Illegal value for attribute "url" of
!MESSAGE Error at line 13, column 90: Missing required attribute in
"repository": url
!MESSAGE Error at line 13, column 90: Illegal value for attribute "url" of
!ENTRY org.eclipse.equinox.p2.director 2 0 2009-01-22 15:26:58.587
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2009-01-22 15:26:58.587
requiredCapability:
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.sse.core
1.1.203.v200802140626 to requiredCapability:
osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.sse.ui
1.0.305.v200802142230 to requiredCapability:
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.ui
1.1.200.v200705302225 to requiredCapability:
osgi.bundle/org.eclipse.ui.ide/[3.2.0,3.4.0).
osgi.bundle/org.eclipse.ui/[3.2.0,3.4.0).
osgi.bundle/org.eclipse.core.runtime/[3.2.0,3.4.0).
osgi.bundle/org.eclipse.core.resources/[3.2.0,3.4.0).
osgi.bundle/org.eclipse.search/[3.2.0,3.4.0).
osgi.bundle/org.eclipse.jface.text/[3.2.0,3.4.0).
osgi.bundle/org.eclipse.ui.workbench.texteditor/[3.2.0,3.4.0 ).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.wsdl
1.1.101.v200801152132 to requiredCapability:
osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
osgi.bundle/org.eclipse.xsd/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.core
1.1.101.v200706120315 to requiredCapability:
osgi.bundle/org.eclipse.core.expressions/[3.2.0,3.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.command.env
1.0.205.v200710161954 to requiredCapability:
osgi.bundle/org.eclipse.ant.core/[3.1.100,3.2.0).
1.0.204.v200711140435 to requiredCapability:
osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.ws.ui
1.0.203.v200708222126 to requiredCapability:
org.eclipse.wst.common.modulecore 1.1.105.v200806190339 to
requiredCapability: osgi.bundle/org.eclipse.emf.ecore/[2.2.0,2.4.0).
requiredCapability: osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
requiredCapability: osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4.0).
org.eclipse.wst.common.modulecore 1.1.104.v200802192030 to
org.eclipse.wst.common.environment 1.0.200.v200705302225 to
requiredCapability: osgi.bundle/org.eclipse.core.resources/[3.2.0,3.4.0).
org.eclipse.wst.common.frameworks 1.1.103.v200802192030 to
org.eclipse.wst.common.emfworkbench.integration 1.1.105.v200802192030 to
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2009-01-22 15:26:58.603
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.command.env.ui
1.0.203.v200709052219 to requiredCapability:
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.web
1.1.103.v200802192030 to requiredCapability:
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.common.emf
1.1.104.v200709131115 to requiredCapability:
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.wsi
1.0.105.v200706120315 to requiredCapability:
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.xsd.core
1.1.202.v200710011705 to requiredCapability:
!ENTRY org.eclipse.equinox.p2.director 4 0 2009-01-22 15:26:59.134
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2009-01-22 15:26:59.134
requiredCapability:
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 0 2009-01-22 15:26:59.134
!MESSAGE No solution found because the problem in C
Re: problem with Zend Debugger and PDT2 [message #91422 is a reply to message #91407] Thu, 22 January 2009 15:37 Go to previous messageGo to next message
and last line of the log
C:\DOCUME~1\XX\LOCALS~1\Temp\p2Encoding6949517396888303787.o pb is
unsatisfiable.
Re: problem with Zend Debugger and PDT2 [message #91437 is a reply to message #91376] Thu, 22 January 2009 16:18 Go to previous messageGo to next message
Hi ZM,
I found the root cause of this problem. under
<pdt_folder> /eclipse/features/org.zend.php.debug_feature_5.2.15v20081217
the file feature.xml should be updated in line 25, version should be
"2.0.0".
I fixed in our repository and it should be delivered in the next drop of
Zend Debugger, important to say this problem doesn't effect the debug
capabilities in PDT...
Thanks again,
Roy
Re: problem with Zend Debugger and PDT2 [message #91483 is a reply to message #91437] Fri, 23 January 2009 01:23 Go to previous messageGo to next message
Originally posted by: none.none.com
Fantastic!!
I was having this same problem and I thought it was just me! Kudos for
getting a fix out.
On Thu, 22 Jan 2009 16:18:08 +0000 (UTC), roy@zend.com (Roy Ganor)
wrote:
>Hi ZM,
>"2.0.0".
>Thanks again,
>Roy
Re: problem with Zend Debugger and PDT2 [message #92169 is a reply to message #91437] Wed, 28 January 2009 13:43 Go to previous messageGo to next message
Dejan Mancic is currently offline Dejan MancicFriend
I have the same problem on Windows XP SP2, but I can't find this file
path.
I go to "c:\eclipse\features\", but there I got only PDT folder under
org.eclipse.php_feature_2.0.0.v20081229-1135.
I don't have folder org.zend.php.debug_feature_5.2.15v20081217, because
Zend debugger is not installed at all, because of the mentioned error.
How can I fix this?
Thank you in advance.
Roy Ganor wrote:
> Hi ZM,
> "2.0.0".
> Thanks again,
> Roy
Re: problem with Zend Debugger and PDT2 [message #93201 is a reply to message #91317] Tue, 10 February 2009 19:44 Go to previous messageGo to next message
Bill Graham is currently offline Bill GrahamFriend
I just had the same issue using this link
http://www.zend.com/en/community/pdt to install from Eclipse. Where can a
corrected version be obtained? Thank you.
Re: problem with Zend Debugger and PDT2 [message #93216 is a reply to message #93201] Tue, 10 February 2009 19:59 Go to previous messageGo to next message
Bill Graham napsal(a):
> a corrected version be obtained? Thank you.
download it, in file
eclipse\features\org.zend.php.debug_feature_5.2.15.v20081217 \feature.xml change line 25
like this:
<import feature="org.eclipse.php_feature" version="2.0.0" match="equivalent"/>
You have to change version and it works
Re: problem with Zend Debugger and PDT2 [message #95984 is a reply to message #93216] Wed, 01 April 2009 06:27 Go to previous messageGo to next message
Anup Dhariwal is currently offline Anup DhariwalFriend
I am experiencing this problem as well, even after making the change to
the xml file. I am running 64 bit Debian. Would that make a difference?
Re: problem with Zend Debugger and PDT2 [message #97096 is a reply to message #91317] Fri, 08 May 2009 19:37 Go to previous messageGo to next message
Jonathan is currently offline JonathanFriend
I cannot install the Zend debugger (that is not included with the
all-in-one package)
When I try to update it in Eclipse Platform Version: 3.4.1 by going to
Software Updates and Add-ons » Available Software and try to install from
the http://downloads.zend.com/pdt, I get the following error message: 'The
software items you have selected may not be valid with your current
installation. Would you like to open the Wizard for more details?' Or
something to that effect. The following error message, through the Wizard,
is:
Unsatisfied dependency: [org.eclipse.platform.feature.group
3.4.1.r341_v20080731-9I96EiDElYevwz-p1bP5z-NlAaP7vtX6Utotqsu ]
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.debug.core/[3.4.0.v200 80612,3.4.0.v20080612]
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.help.feature.group/[1. 0.1.R34x_v20080827-7r7xEIxEI6Zu5nEqN7M3UBpglaat,1.0.1.R34x_v 20080827-7r7xEIxEI6Zu5nEqN7M3UBpglaat]
Unsatisfied dependency: [org.eclipse.platform.ide 3.4.0.M20080911-1700]
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.platform.feature.group /[3.4.1.r341_v20080731-9I96EiDElYevwz-p1bP5z-NlAaP7vtX6Utotq su,3.4.1.r341_v20080731-9I96EiDElYevwz-p1bP5z-NlAaP7vtX6Utot qsu]
Unsatisfied dependency: [org.eclipse.help.feature.group
1.0.1.R34x_v20080827-7r7xEIxEI6Zu5nEqN7M3UBpglaat] requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.rcp.feature.group/[3.4 .100.r341_v20080814-989JESIEdAciFYfkZZsBfSwQ2341,3.4.100.r34 1_v20080814-989JESIEdAciFYfkZZsBfSwQ2341]
Unsatisfied dependency: [org.eclipse.rcp.feature.group
3.4.100.r341_v20080814-989JESIEdAciFYfkZZsBfSwQ2341] requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.ui.workbench/[3.4.1.M2 0080827-0800a,3.4.1.M20080827-0800a]
Kind regards,
Jonathan
Re: problem with Zend Debugger and PDT2 [message #97545 is a reply to message #95984] Wed, 27 May 2009 03:17 Go to previous message
Sophia is currently offline SophiaFriend
I don't think so. I am experiencing the same issue in Windows XP, even after
modifying feature.xml.
Any help would be appreciated!
"Anup Dhariwal" <anup1664@yahoo.co.uk> wrote in message
news:ad76557ddee9b12aa659402f21da0c51$1@www.eclipse.org...
Previous Topic:PHP Explorer + cvs
Next Topic:No files in PHP explorer
Current Time: Fri Jan 03 04:30:50 GMT 2025
Powered by FUDForum. Page generated in 0.04511 seconds
