Home » Language IDEs » PHP Development Tools (PDT) » How to keep an all-in-one up to date?
- How to keep an all-in-one up to date? [message #90427] Thu, 15 January 2009 06:04 Go to next message
What is the recommended procedure to keep an all-in-one PDT installation
up to date? Should I check the downloads provided on
http://www.eclipse.org/pdt/downloads/page periodically and extract some
new *-Update.zip packages somewhere?
Or can "Automatic updates" do this for me? I do have it enabled but it
does for instance not come up with a 2.0.1 update for my 2.0.0GA
all-in-one. Must I setup additional sites or modify the "available
software sites"?
- Re: How to keep an all-in-one up to date? [message #90459 is a reply to message #90427] Thu, 15 January 2009 06:07 Go to previous messageGo to next message
> software sites"?
This is absolutely valid question and i'd like good and deep answer on
that also.
- Re: How to keep an all-in-one up to date? [message #90474 is a reply to message #90459] Thu, 15 January 2009 06:26 Go to previous messageGo to next message
Jasmo Hiltula napsal(a):
>> software sites"?
> that also.
I too, are I builds safe ? or should I use M builds on my working comp ?
On this quetion could answer only some developer.
- Re: How to keep an all-in-one up to date? [message #90488 is a reply to message #90474] Thu, 15 January 2009 06:35 Go to previous messageGo to next message
>>> software sites"?
>> that also.
My advice would be to make a backup of your eclipse directory when
you're satisfied with it and just use the update manager to install
updates. I think you need a separate update site for the non-GA release
Jorrit
- Re: How to keep an all-in-one up to date? [message #90502 is a reply to message #90488] Thu, 15 January 2009 06:37 Go to previous messageGo to next message
Right, since 2.0.1 was not released you won't get it, to get the
integration builds you should use a separate update site (available from
the downloads site).
- Roy
>>>> software sites"?
>>> that also.
- Re: How to keep an all-in-one up to date? [message #90630 is a reply to message #90459] Thu, 15 January 2009 13:22 Go to previous messageGo to next message
Originally posted by: nickboldt+eclipse+newsgroup.gmail.com
You have a few options.
a) Each time a new, updated all-in-one is made available, download it,
unpack it, and point it at your existing workspace. Simple,
self-contained, and no updating required. (Note that anything else
you've installed into your Eclipse, like for debugging or other
scripting support, will need to be reinstalled.)
b) From an existing installed all-in-one, load up the update site you
like best (interim, milestones, or releases -- see
http://www.eclipse.org/pdt/updates/ for the list) and install updates
into your existing Eclipse. Restart when prompted.
c) Download a new, updated Update site zip. Unpack it. From an existing
installed all-in-one, use the Install Manager to install the new plugins
from the unpacked local update site. Restart when prompted.
d) Download a new, updated SDK or runtime zip. Unpack it into your
existing Eclipse's dropins folder, eg., ~/eclipse/dropins/. Restart
eclipse with the -clean flag, and be prepared to wait a bit as it finds
the new dropins and loads them. (The purists might say that you should
remove the old stuff in dropins/eclipse/plugins/*pdt* and
dropins/eclipse/features/*pdt*, but you don't strictly have to.)
Bear in mind that you cannot update from 2.0.0 to 2.1.0, but you can
move from 2.0.0 to 2.0.x. This is because 2.1.0 requires Eclipse 3.5,
whereas 2.0.x require Eclipse 3.4. If you're simply replacing one
all-in-one with another (option (a)) then you can move from 2.0 to 2.1
because the all-in-ones also include the correct version of Eclipse.
HTH,
Nick
>> software sites"?
> that also.
Nick Boldt :: http://wiki.eclipse.org/User:Nickb
- Re: How to keep an all-in-one up to date? [message #90645 is a reply to message #90630] Thu, 15 January 2009 13:31 Go to previous messageGo to next message
Nick Boldt napsal(a):
> HTH,
> Nick
You wrote it very good, could you copy&paste to the PDT's wiki ? I think that is good
source of the informations how to update PDT and what is most important is that you
described all possibilies how to update ;)
thank you
- Re: How to keep an all-in-one up to date? [message #90766 is a reply to message #90630] Fri, 16 January 2009 05:50 Go to previous messageGo to next message
Thanks Nick, that explains a lot!
I agree with sNop that is would be very useful to put this somewhere near
the downloads on the PDT website. I do not use Eclipse for anything else
so I see PDT as "an application" itself, not a bunch of plugins on top of
Eclipse. So imho it would be nice if the PDT website would provide more
brief information on installing and managing a PDT installation without
expecting the user to have any knowledge of Eclipse.
- Re: How to keep an all-in-one up to date? [message #90797 is a reply to message #90645] Fri, 16 January 2009 11:41 Go to previous messageGo to next message
Wikified.
http://wiki.eclipse.org/PDT/FAQ#How_do_I_update_PDT.3F
BTW, the wiki is editable by anyone with a Bugzilla account, and for
that all you need is an email address. We encourage anyone and everyone
to edit the wiki to provide more information, updated information, or
just better information, should you find something missing, incorrect,
or misleading.
Don't be a stranger! Editing the wiki is a great way to give back to the
community and the committers who make Eclipse, and PDT, a possibility.
Nick
>> HTH,
>> Nick
> thank you
- Re: How to keep an all-in-one up to date? [message #90812 is a reply to message #90797] Fri, 16 January 2009 12:26 Go to previous messageGo to next message
> Wikified.
> or misleading.
> Cheers,
> Nick
Hi Nick,
I have created http://wiki.eclipse.org/PDT/how-to-keep-an-all-in-one-up-to- date from your
newsgroup message
But I have problem when i want to update M2.0.1 throught update manager(from local or
remote update site), because M have the same id number, simply eclipse tells me that pdt
is still installed.
Do you know about this bug, i don't know if there is tha same problem with I or N builds
thank you for wiki text
- Re: How to keep an all-in-one up to date? [message #90827 is a reply to message #90812] Fri, 16 January 2009 12:44 Go to previous messageGo to next message
> is still installed.
If the build ID is the same, so are the bits. You'll need a newer build.
I and N builds are for PDT 2.1.
M builds are for PDT 2.0.1.
- Re: How to keep an all-in-one up to date? [message #90858 is a reply to message #90827] Fri, 16 January 2009 13:37 Go to previous messageGo to next message
>> tells me that pdt
>> is still installed.
But how can i update PDT 2.0.0.v20081229-1135 (which is in stable all-in-one packege) to
the latest PDT 2.0.1 M200901150831(which have the same id of package so PDT
2.0.0.v20081229-1135) throught Ganymede update manager ?
I have attached picture, which everythink describe:
http://img231.imageshack.us/img231/5880/updateproblemqb0.jpg
>> with I or N builds
aha
- Re: How to keep an all-in-one up to date? [message #90873 is a reply to message #90858] Fri, 16 January 2009 16:56 Go to previous messageGo to next message
/me looks at screnshot
Ah, I see. The issue here is that the *feature* is not new, but (maybe)
some of the underlying plugins are.
I suspect the best workaround here (for you) is to uninstall the older
PDT feature, restart, then install the newer one.
For the PDT devs, the solution is to commit a change to their features
(even a no-op one) more often so that the change will be tagged, the map
file will be updated and thus the version on the feature will be
incremented so early adopters can update more regularly.
Nick
>>> tells me that pdt
>>> is still installed.
>>> with I or N builds
> aha
- Re: How to keep an all-in-one up to date? [message #90886 is a reply to message #90873] Sat, 17 January 2009 05:01 Go to previous message
> Nick
And wouldn't be better if milestones would be tagged by developers in main repo ?
Previous Topic:PHP inside of Javascript in a .php file
Next Topic:Plugins vs Dropin directory
Current Time: Thu Mar 13 22:55:38 EDT 2025
Powered by FUDForum. Page generated in 0.04886 seconds
