Home » Modeling » GMF (Graphical Modeling Framework) » MouseMotionListener and Link Creation(How to get MML to work during link creation)
MouseMotionListener and Link Creation [message #905045] Wed, 29 August 2012 15:32 Go to next message
Jérémy Flusin is currently offline Jérémy FlusinFriend
Hello everyone,
I'm trying to make my own tooltip on some nodes (called "Input") of my GMF editor. In order to do this, I set a MouseMotionListener to my InputFigure to display my tooltip when the mouse is hovering the node.
Everything works fine, but I would want to display my tooltip during the creation of a link whose target is my Input node. The problem is, none of the listener's methods is called when a link is being created.
How can I proceed ?
PS: I did not use the "setTooltip()" method for the same reason; the tooltip does not appear during the creation of a link.
Re: MouseMotionListener and Link Creation [message #907536 is a reply to message #905045] Tue, 04 September 2012 07:19 Go to previous messageGo to next message
Ralph Gerbig is currently offline Ralph GerbigFriend
as far as I can understand you want to draw a connection between two model elements and show a menu which lets the user select what to create when releasing the mouse at the target. To do so install a customized GraphicalNodeEditPolicy into your edit parts. This class shows such a GraphicalNodeEditPolicy http://code.google.com/a/eclipselabs.org/p/melanie/source/browse/de.uni_mannheim.informatik.swt.common.gmf.inthemiddle/src/de/uni_mannheim/informatik/swt/common/gmf/inthemiddle/gnep/ITMGraphicalNodeEditPolicy.java The method getConnectionMenuContent(CreateConnectionRequest request) is of interest here. An example for a template which installs this policy into an EditPart can be found here: http://code.google.com/a/eclipselabs.org/p/melanie/source/browse/de.uni_mannheim.informatik.swt.models.gmf/templates/aspects/impl/diagram/editparts/NodeEditPart.xpt The part «AROUND createDefaultEditPoliciesBody FOR gmfgen::GenNode-» is of interest in this template. A video that shows the result can be found here: http://code.google.com/a/eclipselabs.org/p/melanie/wiki/FirstSteps#Creat_DSL_Connection
Ralph
Re: MouseMotionListener and Link Creation [message #907545 is a reply to message #905045] Tue, 04 September 2012 07:19 Go to previous message
Ralph
Re: MouseMotionListener and Link Creation [message #907554 is a reply to message #905045] Tue, 04 September 2012 07:19 Go to previous message
Ralph
Re: MouseMotionListener and Link Creation [message #907566 is a reply to message #905045] Tue, 04 September 2012 07:19 Go to previous message
Ralph
Previous Topic:Shared Editing Domain - Errors after saving diagram changes
Next Topic:separate property box while double clicking the node
Current Time: Wed Feb 05 08:56:58 GMT 2025
Powered by FUDForum. Page generated in 0.03431 seconds
