Re: Use Xtend instead of Java in more places in the generated DSL implementation [message #903081 is a reply to message #902771] |
Tue, 21 August 2012 20:45 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Hi Peter,
you may want to follow https://bugs.eclipse.org/bugs/show_bug.cgi?id=346092
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 20.08.12 13:47, schrieb Peter Friese:
> are there any plans to make more use of Xtend instead of Java for the
> typical DSL infrastructure classes such as scope and completion
> providers? For some of the classes, we can turn off generation of the
> respective stub via a switch in GenerateMyLanguage.mwe, but not all
> generator fragments support this switch. Of course, the workaround here
> is to just create an Xtend class and register it in the proper runtime /
> UI module. However, it would be awesome to be able to use Xtend
> out-of-the-box.
> Cheers,
> Peter
FUDForum. Page generated in 0.03934 seconds
