Home » Eclipse Projects » EclipseLink » Problem with Transaction Management
Problem with Transaction Management [message #899460] Tue, 31 July 2012 23:59 Go to next message
Fericit Bostan is currently offline Fericit BostanFriend
Member
I'm using EclipseLink 2.4.0 in my project, which is a simple web base application running within Tomcat 7.0. I've deployed and configured Bitronix Transaction Manager into Tomcat per the documentation: http://docs.codehaus.org/display/BTM/Tomcat
and I've defined a datasource in Tomcat's JNDI that I can access via the application, Spring specifically.
I've got my persistence.xml as follows:
<persistence version="2.0"
	xmlns="http://java.sun.com/xml/ns/persistence" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
	xsi:schemaLocation="http://java.sun.com/xml/ns/persistence http://java.sun.com/xml/ns/persistence/persistence_2_0.xsd">
	<persistence-unit name="totaltag-pu" transaction-type="JTA">
		<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
        <jta-data-source>jdbc/totalTagDataSource</jta-data-source>
        <class>com.cadreon.it.totaltag.persistence.entity.AuditableEntity</class>
        <class>com.cadreon.it.totaltag.persistence.entity.Advertiser</class>
        <class>com.cadreon.it.totaltag.persistence.entity.Asset</class>
        <class>com.cadreon.it.totaltag.persistence.entity.DelayedJob</class>
        <class>com.cadreon.it.totaltag.persistence.entity.History</class>
        <class>com.cadreon.it.totaltag.persistence.entity.Market</class>
        <class>com.cadreon.it.totaltag.persistence.entity.PixelProvider</class>
        <class>com.cadreon.it.totaltag.persistence.entity.Pixel</class>
        <class>com.cadreon.it.totaltag.persistence.entity.S3LogLine</class>
        <class>com.cadreon.it.totaltag.persistence.entity.S3Log</class>
        <class>com.cadreon.it.totaltag.persistence.entity.Segment</class>
        <class>com.cadreon.it.totaltag.persistence.entity.TotalTag</class>
        <class>com.cadreon.it.totaltag.persistence.entity.Url</class>
        <class>com.cadreon.it.totaltag.persistence.entity.User</class>
        <class>com.cadreon.it.totaltag.persistence.entity.Variable</class>
        <class>com.cadreon.it.totaltag.persistence.entity.Version</class>
		<shared-cache-mode>ALL</shared-cache-mode>
		<properties>
            <property name="eclipselink.cache.type.default" value="HardWeak" />
            <property name="eclipselink.cache.size.default" value="200" />
            <property name="eclipselink.flush-clear.cache" value="DropInvalidate" />
            <property name="eclipselink.jdbc.native-sql" value="true" />
            <property name="eclipselink.jdbc.cache-statements" value="true" />
            <property name="eclipselink.target-database" value="Auto" />
            <property name="eclipselink.weaving" value="static" />
            <property name="eclipselink.logging.exceptions" value="true" />
            <property name="eclipselink.logging.level" value="FINEST" />
            <property name="eclipselink.debug" value="ALL" />
            <property name="eclipselink.logging.level.sql" value="FINEST" />
            <property name="eclipselink.logging.level.cache" value="FINEST" />
            <property name="eclipselink.session.customizer" value="com.cadreon.it.totaltag.persistence.provider.JPAEclipseLinkSessionCustomizer" />
            <property name="eclipselink.target-server" value="org.eclipse.persistence.platform.server.tomcat.TomcatServer"/>
		</properties>
	</persistence-unit>
</persistence>
I've created a new Session Customizer, per the EclipseLink documentation, and a new ServerPlatform class.
public class TomcatServer extends ServerPlatformBase {
    private static final String SERVER_NAME_AND_VERSION =  "Tomcat v7.0";
    public TomcatServer(DatabaseSession newDatabaseSession) {
        super(newDatabaseSession);
     * (non-Javadoc)
     * @see org.eclipse.persistence.platform.server.ServerPlatformBase#getExternalTransactionControllerClass()
    @SuppressWarnings("rawtypes")
    public Class getExternalTransactionControllerClass() {
        if (externalTransactionControllerClass == null) {
            externalTransactionControllerClass = TomcatTransactionController.class;
        return externalTransactionControllerClass;
    /* (non-Javadoc)
     * @see org.eclipse.persistence.platform.server.ServerPlatformBase#getServerNameAndVersion()
    protected void initializeServerNameAndVersion() {
        this.serverNameAndVersion = SERVER_NAME_AND_VERSION;
My TransactionController class simply performed the lookup, via JNDI, to locate the TransactionManager:
public class TomcatTransactionController extends JTATransactionController {
    private static Logger logger = LoggerFactory.getLogger(TomcatTransactionController.class);
    public TomcatTransactionController() {
        super();
    public TomcatTransactionController(TransactionManager transactionManager) {
        super(transactionManager);
    /* (non-Javadoc)
     * @see org.eclipse.persistence.transaction.JTATransactionController#acquireTransactionManager()
    protected TransactionManager acquireTransactionManager() throws Exception {
        logger.debug("ENTERING: acquireTransactionManager");
        TransactionManager mgr = super.acquireTransactionManager();
        if(mgr == null) {
            try {
                // Bitronix binds to java:comp/UserTransaction within Tomcat.
                mgr = (TransactionManager) jndiLookup("java:comp/UserTransaction");
                setTransactionManager(mgr);
            catch(Exception e) {
               logger.error(e.getMessage());
        logger.debug("EXITING: acquireTransactionManager");
        return mgr;
All the code executes as expected and seems to behave properly but when I attempt to access the database I get an exception from Bitronix, which tells me that I am attempting to access the datasource outside of a transaction.
Caused by: java.sql.SQLException: error enlisting a JdbcConnectionHandle of a JdbcPooledConnection from datasource jdbc/totalTagDataSource in state ACCESSIBLE with usage count 1 wrapping com.mysql.jdbc.jdbc2.optional.JDBC4MysqlXAConnection@66869470 on com.mysql.jdbc.jdbc2.optional.JDBC4ConnectionWrapper@1ae3e881
	at bitronix.tm.resource.jdbc.JdbcConnectionHandle.enlistResource(JdbcConnectionHandle.java:87)
	at bitronix.tm.resource.jdbc.JdbcConnectionHandle.prepareStatement(JdbcConnectionHandle.java:242)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at bitronix.tm.resource.jdbc.BaseProxyHandlerClass.invoke(BaseProxyHandlerClass.java:64)
	at $Proxy29.prepareStatement(Unknown Source)
	at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.prepareStatement(DatabaseAccessor.java:1481)
	at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.prepareStatement(DatabaseAccessor.java:1430)
	at org.eclipse.persistence.internal.databaseaccess.DatabaseCall.prepareStatement(DatabaseCall.java:705)
	at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:587)
	... 84 more
Caused by: bitronix.tm.internal.BitronixSystemException: resource 'jdbc/totalTagDataSource' cannot be used outside XA transaction scope. Set allowLocalTransactions to true if you want to allow this and you know your resource supports this.
	at bitronix.tm.resource.common.TransactionContextHelper.enlistInCurrentTransaction(TransactionContextHelper.java:78)
	at bitronix.tm.resource.jdbc.JdbcConnectionHandle.enlistResource(JdbcConnectionHandle.java:85)
	... 95 more
I've defined my transactionManager in Spring as I would usually do and I've annotated my classes so that Spring will perform its transactionManager per the documentation:
	<context:annotation-config />
	<context:component-scan base-package="com.cadreon.it.totaltag" />
	<tx:jta-transaction-manager/>
	<tx:annotation-driven />
	<bean id="emf"
		class="org.springframework.orm.jpa.LocalContainerEntityManagerFactoryBean">
		<property name="persistenceXmlLocation" value="classpath:META-INF/persistence.xml" />
	</bean>
But no matter what I try it appears that no transaction is started when accessing the DataSource. Is there something I am missing in EclipseLink or did I not implement something that I should have to allow for EclipseLink to participate in the Global TX?
Thanks for the assistance..
Chris
Re: Problem with Transaction Management [message #899671 is a reply to message #899460] Wed, 01 August 2012 18:08 Go to previous messageGo to next message
James Sutherland is currently offline James SutherlandFriend
Are you sure that Spring is starting a JTA transaction through your transaction manager before you are accessing JPA?
It seems that it does not. Try starting a JTA transaction directly.
James : Wiki : Book : Blog : Twitter
Re: Problem with Transaction Management [message #900225 is a reply to message #899671] Sun, 05 August 2012 19:12 Go to previous messageGo to next message
Member
I managed to identify the issue. It seems that I had a reference to embedded-glassfish container that was causing some class loading issues. Once I removed it as a dependency, I was able to identify the issues with the Spring TX configuration as well as some code that someone checked in that was attempting to perform DB access outside of a global TX. After correcting this the application loads and transactions behave normally.
Thanks for the help...
Re: Problem with Transaction Management [message #1130149 is a reply to message #900225] Wed, 09 October 2013 09:03 Go to previous message
Dheeraj Gupta is currently offline Dheeraj GuptaFriend
Again facing the same exception "Internal Exception: java.sql.SQLException: error enlisting a JdbcConnectionHandle of a JdbcPooledConnection from datasource jdbc/totalTagDataSource in state ACCESSIBLE with usage count 1 wrapping". It seems that this exception is not consistent and we are getting this particularly when there are a large number of records to be processed.
Any pointers?
Previous Topic:second level cache without persistence.xml
Next Topic:How to create POJOs with JAXB and JPA Annotations from XSD?
Current Time: Wed Feb 05 05:51:18 GMT 2025
Powered by FUDForum. Page generated in 0.03591 seconds
