Home » Language IDEs » ServerTools (WTP) » Associate Custom Content Type with XML Validator.
Associate Custom Content Type with XML Validator. [message #898993] Mon, 30 July 2012 04:47 Go to next message
rohit chawla is currently offline rohit chawlaFriend
Just want to know what should come in place of question marks ?? in the following plugin.xml, in order to validate my custom content-type xml2 (xml types) with normal xml validator???
Write now, I am able to open xml2 in XML editor, but not able to validate.
<?eclipse version="3.4"?>
<plugin>
    <extension point="org.eclipse.wst.sse.ui.sourcevalidation">
		<validator
			scope="total"
			class="???"
			id="???">
			<contentTypeIdentifier id="com.xyz.ide.core.contentType.dummy">
				<partitionType id="org.eclipse.wst.xml.XML_DEFAULT">
				</partitionType>
			</contentTypeIdentifier>
		</validator>
	</extension>
	 <extension
         point="org.eclipse.core.runtime.contentTypes">
         <content-type
            base-type="org.eclipse.core.runtime.xml"
            file-extensions="xml2"
            name="xml2"
            priority="normal"
            default-charset="UTF-8"/>
   </extension>
</plugin>
[Updated on: Mon, 30 July 2012 04:50]
Report message to a moderator
Re: Associate Custom Content Type with XML Validator. [message #898994 is a reply to message #898993] Mon, 30 July 2012 05:44 Go to previous messageGo to next message
If anyone knows a different way of doing it, please share..thanks
Re: Associate Custom Content Type with XML Validator. [message #899143 is a reply to message #898994] Mon, 30 July 2012 16:30 Go to previous messageGo to next message
Also, if I manually go and add content type through Window->Preferences->Content Type....
That way the validation is still performed.
I am missing some small thing Sad
Re: Associate Custom Content Type with XML Validator. [message #899153 is a reply to message #898993] Mon, 30 July 2012 16:58 Go to previous messageGo to next message
Nick Sandonato is currently offline Nick SandonatoFriend
The source (as-you-type) validator class that you're looking for is org.eclipse.wst.xml.ui.internal.validation.DelegatingSourceValidatorForXML. Your id can be whatever you'd like it to be.
Re: Associate Custom Content Type with XML Validator. [message #899166 is a reply to message #899153] Mon, 30 July 2012 18:13 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
Just so long as you don't use an ID that exists elsewhere.
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Associate Custom Content Type with XML Validator. [message #899193 is a reply to message #899166] Tue, 31 July 2012 01:16 Go to previous messageGo to next message
No Message Body
Re: Associate Custom Content Type with XML Validator. [message #899194 is a reply to message #899193] Tue, 31 July 2012 01:19 Go to previous messageGo to next message
Still no luck guys, I changed to what you specified. Still there is no xml validation??
<plugin>
		<validator
			scope="total"
			 class="org.eclipse.wst.xml.ui.internal.validation.DelegatingSourceValidatorForXML"
			id="org.eclipse.wst.xml.ui.internal.validation.DelegatingSourceValidatorForXML">
				</partitionType>
				<partitionType id="org.eclipse.wst.xml.XML_COMMENT"/>
				<partitionType id="org.eclipse.wst.sse.ST_DEFAULT"/>
		</validator>
	</extension>
   <extension
         <content-type
            name="xml2"
            priority="normal"
   </extension>
</plugin>
Re: Associate Custom Content Type with XML Validator. [message #905848 is a reply to message #898993] Fri, 31 August 2012 07:29 Go to previous message
Leonid Ripeynih is currently offline Leonid RipeynihFriend
Have you found a solution?
Previous Topic:How to make Content assist working when editors are inside Composite?
Next Topic:Forcing StructuredTextEditor to recognize XML
Current Time: Wed Feb 05 14:05:44 GMT 2025
Powered by FUDForum. Page generated in 0.03124 seconds
