Home » Modeling » GMF (Graphical Modeling Framework) » Change background color of a shape programmatically
Change background color of a shape programmatically [message #896623] Thu, 19 July 2012 07:41 Go to next message
Chris B. is currently offline Chris B.Friend
Member
Hi everyone,
I've added a new item to the context menu of the diagram editor and associated it with an AbstractHandler. When the item is clicked the execute method is invoked. Here i want to change the color of a shape dynamically depending on the shape's state.
This is how my code looks like:
public Object execute(ExecutionEvent event) throws ExecutionException
        EvaluationContext evalContext = (EvaluationContext) event.getApplicationContext();
        Object var = evalContext.getDefaultVariable();
        ArrayList al = new ArrayList((Collection) var);
        Object o = al.get(0);
        if (o instanceof ShapeNodeEditPart)
            ShapeNodeEditPart editPart = (ShapeNodeEditPart) o;
            ShapeImpl notationView = (ShapeImpl) editPart.getNotationView();
            GradientData gdata = new GradientData();
            gdata.setGradientColor1(Color.HSBtoRGB(1.0f, 1.0f, 1.0f));
            gdata.setGradientColor2(0x33);
            notationView.setGradient(gdata);
        return null;
Calling the method results in the following exception:
java.lang.IllegalStateException: Cannot modify resource set without a write transaction
	at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.assertWriting(TransactionChangeRecorder.java:348)
	at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.appendNotification(TransactionChangeRecorder.java:302)
	at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.processObjectNotification(TransactionChangeRecorder.java:284)
	at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.notifyChanged(TransactionChangeRecorder.java:240)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:380)
	at org.eclipse.gmf.runtime.notation.impl.ShapeImpl.setGradient(ShapeImpl.java:589)
	at GraphicalEventModeller.diagram.part.SetBreakpoint.execute(SetBreakpoint.java:67)
	at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
	at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
	at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
	at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
	at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
	at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:820)
	at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:806)
	at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:796)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
I came across this and similar messages several times in GMF. I think i need to execute the code in a read/write transaction but i don't know the approach. Can anybody help me solving this issue and give a sample code how to change appearance properties of shapes programmatically?
regards
Chris
Re: Change background color of a shape programmatically [message #896642 is a reply to message #896623] Thu, 19 July 2012 09:01 Go to previous messageGo to next message
Aurélien Pupier is currently offline Aurélien PupierFriend
you need to use an AbstractTransactionalCommand to execute the code in a read/write transaction.
Aurélien Pupier - Red Hat
Senior Software Engineer in Fuse Tooling team
Re: Change background color of a shape programmatically [message #896669 is a reply to message #896642] Thu, 19 July 2012 10:55 Go to previous messageGo to next message
Member
thanks for your reply. I've created a new AbstractTransactionalCommand and shifted the code to the doExecuteWithResult method. The command is executed but the changes are not applied.What's going wrong? Any suggestions?
regards
Chris
    protected CommandResult doExecuteWithResult(IProgressMonitor monitor, IAdaptable info) throws ExecutionException
        gdata.setGradientColor1(Color.HSBtoRGB(5.0f, 5.0f, 5.0f));
        gdata.setGradientColor2(Color.HSBtoRGB(105.0f, 25.0f, 95.0f));
        return CommandResult.newOKCommandResult();
Re: Change background color of a shape programmatically [message #896672 is a reply to message #896669] Thu, 19 July 2012 10:56 Go to previous messageGo to next message
I think that you need to call a refresh on the editpart.
regards,
Re: Change background color of a shape programmatically [message #896716 is a reply to message #896672] Thu, 19 July 2012 13:22 Go to previous message
Member
Works fine, thank you very much!
regards
Chris
Previous Topic:Problem when delete a node in a subdiagram
Next Topic:templates: change code of inner classes
Current Time: Wed Feb 05 17:53:28 GMT 2025
Powered by FUDForum. Page generated in 0.03031 seconds
