New child menu entry for EMap and custom dialog [message #896093] |
Tue, 17 July 2012 09:02 |
John M. Messages: 198 Registered: July 2010 |
I have modelled a StringToIntegerMap and trying to add a menu item for creating an entry.
My idea was to edit the generated method collectNewChildDescriptors and add following:
newChildDescriptors.add(createChildParameter(Package.Literals.STRING_TO_INTEGER_MAP__VALUE, Factory.eINSTANCE.create(Package.Literals.STRING_TO_INTEGER_MAP)));
But I get a NPE in the ActionBarContributor.
Can I add on that way an item?
[Updated on: Tue, 17 July 2012 15:29] Report message to a moderator
Re: New child menu entry for EMap and custom dialog [message #896216 is a reply to message #896093] |
Tue, 17 July 2012 15:31 |
My command implementation with the InputDialog looks like following:
import org.eclipse.emf.common.command.Command;
import org.eclipse.emf.common.command.CommandWrapper;
import org.eclipse.emf.edit.command.CommandActionDelegate;
import org.eclipse.jface.dialogs.InputDialog;
import org.eclipse.ui.PlatformUI;
public class DefinitionCreateCommand extends CommandWrapper implements CommandActionDelegate {
public DefinitionCreateCommand(Command command) {
super(command);
public void execute() {
InputDialog dialog = new InputDialog(PlatformUI.getWorkbench().getActiveWorkbenchWindow().getShell(), "test",
"test message", "", null);
dialog.open();
public Object getImage() {
return ((CommandActionDelegate) super.command).getImage();
public String getText() {
return ((CommandActionDelegate) super.command).getText();
public String getToolTipText() {
return ((CommandActionDelegate) super.command).getToolTipText();
I have overwritten the method createCreateChildCommand with following content:
return new DefinitionCreateCommand(super.createCreateChildCommand(domain, owner, feature, value, index, collection));
It works so long, but how can I pass the result back?
Re: New child menu entry for EMap and custom dialog [message #896340 is a reply to message #896216] |
Wed, 18 July 2012 06:51 |
Ed Merks Messages: 33218 Registered: July 2009 |
Command.getResult generally does the trick, after the command has been
executed.
> super(command);
> @Override
> "test",
> dialog.open();
> @Override
> @Override
> @Override
> content:
> return new
Ed Merks
FUDForum. Page generated in 0.04938 seconds
