Home » Eclipse Projects » Virgo » Error configuring application listener: ClassNotFoundException
Re: Error configuring application listener: ClassNotFoundException [message #817014 is a reply to message #816971] |
Fri, 09 March 2012 14:33 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Could you try adding the following to your web.xml just before the listener definitions.
<context-param>
<param-name>contextClass</param-name>
<param-value>org.eclipse.virgo.web.dm.ServerOsgiBundleXmlWebApplicationContext</param-value>
</context-param>
You will need to add that package to the imports in your manifest as well.
Thanks, Chris.
Chris Frost, Twitter @cgfrost
Springsource, a divison of VMware.
[Updated on: Fri, 09 March 2012 14:33] Report message to a moderator
Re: Error configuring application listener: ClassNotFoundException [message #820610 is a reply to message #820561] |
Wed, 14 March 2012 10:38 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
David Koch![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=david.koch444%40googlemail.com) Messages: 10 Registered: March 2012 |
Ok, nice. The Bundle-ClassPath property contains all expected jars. The WEB-INF/lib/web-2.1-SNAPSHOT.jar contains the missing class com.myCompany.myApps.ApplicationListener.
osgi> headers 117
Bundle 117
Manifest-Version = 1.0
Bundle-ClassPath = WEB-INF/classes,WEB-INF/lib/aci-communication-2.1-SNAPSHOT.jar,WEB-INF/lib/activemq-core-5.4.2.jar,WE
B-INF/lib/activemq-protobuf-1.1.jar,WEB-INF/lib/aopalliance-1.0.jar,WEB-INF/lib/asm-3.3.1.jar,WEB-INF/lib/avalon-framewo
rk-4.1.5.jar,WEB-INF/lib/cglib-2.2.2.jar,WEB-INF/lib/client-2.5.31.jar,WEB-INF/lib/common-2.1-SNAPSHOT.jar,WEB-INF/lib/c
ommons-codec-1.1.jar,WEB-INF/lib/commons-lang-2.1.jar,WEB-INF/lib/commons-logging-1.1.1.jar,WEB-INF/lib/commons-logging-
api-1.1.jar,WEB-INF/lib/commons-net-2.2.jar,WEB-INF/lib/communication-2.5.31.jar,WEB-INF/lib/configuration-2.1-SNAPSHOT.
jar,WEB-INF/lib/gchart-2.7.jar,WEB-INF/lib/geronimo-j2ee-management_1.1_spec-1.0.1.jar,WEB-INF/lib/geronimo-jms_1.1_spec
-1.1.1.jar,WEB-INF/lib/gui-lib-2.1-SNAPSHOT-sources.jar,WEB-INF/lib/gui-lib-2.1-SNAPSHOT.jar,WEB-INF/lib/guilibrary-2.5.
31.jar,WEB-INF/lib/gxt-2.2.4.jar,WEB-INF/lib/icu4j-4.0.1.jar,WEB-INF/lib/jacorb-2.3.0_02.jar,WEB-INF/lib/jasypt-1.6.jar,
WEB-INF/lib/jcommon-1.0.16.jar,WEB-INF/lib/jfreechart-1.0.13.jar,WEB-INF/lib/json-20090211.jar,WEB-INF/lib/jstl-1.2.jar,
WEB-INF/lib/junit-3.8.1.jar,WEB-INF/lib/kahadb-5.4.2.jar,WEB-INF/lib/log4j-1.2.16.jar,WEB-INF/lib/logkit-1.2.jar,WEB-INF
/lib/org.osgi.core-4.1.0.jar,WEB-INF/lib/security-remoting-1.1.44.jar,WEB-INF/lib/server-2.1-SNAPSHOT.jar,WEB-INF/lib/se
rveradapter-2.5.31.jar,WEB-INF/lib/she-types-2.1-SNAPSHOT.jar,WEB-INF/lib/snmp-2.1-SNAPSHOT.jar,WEB-INF/lib/snmp4j-1.11.
jar,WEB-INF/lib/spring-aop-3.1.0.RELEASE.jar,WEB-INF/lib/spring-asm-3.1.0.RELEASE.jar,WEB-INF/lib/spring-beans-3.1.0.REL
EASE.jar,WEB-INF/lib/spring-context-3.1.0.RELEASE.jar,WEB-INF/lib/spring-context-support-3.1.0.RELEASE.jar,WEB-INF/lib/s
pring-core-3.1.0.RELEASE.jar,WEB-INF/lib/spring-expression-3.1.0.RELEASE.jar,WEB-INF/lib/spring-jms-3.0.3.RELEASE.jar,WE
B-INF/lib/spring-tx-3.0.3.RELEASE.jar,WEB-INF/lib/spring-web-3.1.0.RELEASE.jar,WEB-INF/lib/spring-webmvc-3.1.0.RELEASE.j
ar,WEB-INF/lib/test-util-2.1-SNAPSHOT.jar,WEB-INF/lib/web-2.1-SNAPSHOT.jar,WEB-INF/lib/xmlpull-1.1.3.1.jar,WEB-INF/lib/x
o-2.5.31.jar,WEB-INF/lib/xoshe-1.1.0-DEV-14.jar,WEB-INF/lib/xpp3_min-1.1.4c.jar,WEB-INF/lib/xstream-1.4.2.jar
org-eclipse-gemini-web-DefaultWABHeaders = true
Module-Type = web-bundle
Build-Jdk = 1.7.0_02
Built-By = ll008173
Bundle-ManifestVersion = 2
Created-By = Apache Maven
Bundle-SymbolicName = myApps
Web-ContextPath = myApps
Import-Package = javax.crypto.interfaces;version="[0.0.0, 0.0.0]",org.eclipse.osgi.internal.provisional.verifier;version
="[0.0.0, 0.0.0]",javax.management.timer;version="[0.0.0, 0.0.0]",javax.jws;version="[0.0.0, 2.0.0]",org.eclipse.osgi.ba
seadaptor.hooks;version="[0.0.0, 0.0.0]",javax.rmi.ssl;version="[0.0.0, 0.0.0]",org.osgi.framework.wiring;version="[1.0.
0, 1.0.0]",org.w3c.dom.ranges;version="[0.0.0, 0.0.0]",javax.naming.spi;version="[0.0.0, 0.0.0]",javax.xml.stream;versio
n="[0.0.0, 1.0.1]",javax.swing.filechooser;version="[0.0.0, 0.0.0]",javax.swing.plaf;version="[0.0.0, 0.0.0]",javax.lang
.model;version="[0.0.0, 0.0.0]",javax.lang.model.util;version="[0.0.0, 0.0.0]",org.eclipse.osgi.framework.eventmgr;versi
on="[1.2.0, 1.2.0]",javax.naming.ldap;version="[0.0.0, 0.0.0]",javax.security.auth.kerberos;version="[0.0.0, 0.0.0]",jav
ax.crypto;version="[0.0.0, 0.0.0]",javax.servlet.jsp;version="2.1.0",javax.naming.event;version="[0.0.0, 0.0.0]",javax.p
rint.attribute.standard;version="[0.0.0, 0.0.0]",javax.imageio.plugins.bmp;version="[0.0.0, 0.0.0]",org.eclipse.osgi.bas
eadaptor.bundlefile;version="[0.0.0, 0.0.0]",javax.annotation;version="[0.0.0, 1.0.0]",javax.xml.ws.handler.soap;version
="[0.0.0, 2.1.1]",javax.xml.transform.dom;version="[0.0.0, 0.0.0]",javax.print.attribute;version="[0.0.0, 0.0.0]",javax.
sql.rowset.serial;version="[0.0.0, 0.0.0]",org.w3c.dom.traversal;version="[0.0.0, 0.0.0]",org.eclipse.core.runtime.inter
nal.adaptor;version="[0.0.0, 0.0.0]",org.osgi.framework.hooks.resolver;version="[1.0.0, 1.0.0]",javax.sound.midi;version
="[0.0.0, 0.0.0]",org.eclipse.osgi.service.pluginconversion;version="[1.0.0, 1.0.0]",javax.swing.event;version="[0.0.0,
0.0.0]",javax.xml.ws.spi;version="[0.0.0, 2.1.1]",org.eclipse.osgi.util;version="[1.1.0, 1.1.0]",javax.xml.stream.util;v
ersion="[0.0.0, 1.0.1]",javax.net;version="[0.0.0, 0.0.0]",javax.security.auth.spi;version="[0.0.0, 0.0.0]",javax.manage
ment.loading;version="[0.0.0, 0.0.0]",javax.print;version="[0.0.0, 0.0.0]",javax.xml.crypto.dsig.keyinfo;version="[0.0.0
, 1.0.0]",javax.swing.plaf.multi;version="[0.0.0, 0.0.0]",javax.xml.namespace;version="[0.0.0, 0.0.0]",javax.servlet;ver
sion="2.5.0",org.osgi.service.log;version="[1.3.0, 1.3.0]",org.eclipse.osgi.framework.internal.protocol;version="[0.0.0,
0.0.0]",javax.swing;version="[0.0.0, 0.0.0]",org.eclipse.osgi.internal.loader;version="[0.0.0, 0.0.0]",javax.xml.transf
orm.sax;version="[0.0.0, 0.0.0]",org.eclipse.osgi.service.localization;version="[1.1.0, 1.1.0]",javax.management.relatio
n;version="[0.0.0, 0.0.0]",javax.naming;version="[0.0.0, 0.0.0]",javax.xml.transform.stax;version="[0.0.0, 0.0.0]",org.e
clipse.core.runtime.internal.stats;version="[0.0.0, 0.0.0]",org.omg.stub.java.rmi;version="[0.0.0, 0.0.0]",javax.xml.cry
pto.dsig.dom;version="[0.0.0, 1.0.0]",javax.xml.parsers;version="[0.0.0, 0.0.0]",org.ietf.jgss;version="[0.0.0, 0.0.0]",
javax.xml.xpath;version="[0.0.0, 0.0.0]",javax.xml.bind.attachment;version="[0.0.0, 2.0.0]",org.eclipse.osgi.internal.co
mposite;version="[0.0.0, 0.0.0]",javax.servlet.jsp.el;version="2.1.0",org.eclipse.osgi.framework.console;version="[1.1.0
, 1.1.0]",org.eclipse.osgi.storagemanager;version="[1.0.0, 1.0.0]",javax.xml.crypto.dsig.spec;version="[0.0.0, 1.0.0]",o
rg.eclipse.osgi.internal.permadmin;version="[0.0.0, 0.0.0]",javax.swing.undo;version="[0.0.0, 0.0.0]",javax.swing.text;v
ersion="[0.0.0, 0.0.0]",javax.print.event;version="[0.0.0, 0.0.0]",javax.imageio.spi;version="[0.0.0, 0.0.0]",org.osgi.s
ervice.framework;version="[1.0.0, 1.0.0]",org.w3c.dom.stylesheets;version="[0.0.0, 0.0.0]",javax.script;version="[0.0.0,
1.1.0]",org.w3c.dom.ls;version="[0.0.0, 0.0.0]",org.osgi.framework.launch;version="[1.0.0, 1.0.0]",org.eclipse.osgi.fra
mework.util;version="[0.0.0, 0.0.0]",org.eclipse.osgi.service.environment;version="[1.3.0, 1.3.0]",javax.xml.bind.annota
tion.adapters;version="[0.0.0, 2.0.0]",org.eclipse.osgi.internal.serviceregistry;version="[0.0.0, 0.0.0]",javax.xml.stre
am.events;version="[0.0.0, 1.0.1]",javax.sql;version="[0.0.0, 0.0.0]",org.eclipse.equinox.log.internal;version="[0.0.0,
0.0.0]",javax.transaction;version="[0.0.0, 1.1.0]",javax.rmi;version="[0.0.0, 0.0.0]",org.eclipse.osgi.service.datalocat
ion;version="[1.3.0, 1.3.0]",org.eclipse.osgi.internal.resolver;version="[0.0.0, 0.0.0]",org.eclipse.osgi.baseadaptor;ve
rsion="[0.0.0, 0.0.0]",javax.xml.soap;version="[0.0.0, 1.3.0]",javax.management.modelmbean;version="[0.0.0, 0.0.0]",java
x.xml.bind;version="[0.0.0, 2.0.0]",javax.xml.ws;version="[0.0.0, 2.1.1]",org.w3c.dom.html;version="[0.0.0, 0.0.0]",org.
eclipse.osgi.framework.debug;version="[0.0.0, 0.0.0]",javax.swing.tree;version="[0.0.0, 0.0.0]",javax.sound.midi.spi;ver
sion="[0.0.0, 0.0.0]",org.eclipse.equinox.log;version="[1.0.0, 1.0.0]",org.w3c.dom.css;version="[0.0.0, 0.0.0]",org.ecli
pse.osgi.event;version="[1.0.0, 1.0.0]",org.eclipse.osgi.framework.internal.protocol.reference;version="[0.0.0, 0.0.0]",
org.xml.sax;version="[0.0.0, 0.0.0]",javax.xml.ws.handler;version="[0.0.0, 2.1.1]",org.eclipse.osgi.service.runnable;ver
sion="[1.1.0, 1.1.0]",org.eclipse.osgi.internal.service.security;version="[0.0.0, 0.0.0]",org.eclipse.osgi.framework.ada
ptor;version="[0.0.0, 0.0.0]",javax.sql.rowset;version="[0.0.0, 0.0.0]",org.eclipse.osgi.framework.internal.reliablefile
;version="[0.0.0, 0.0.0]",org.eclipse.core.runtime.adaptor;version="[0.0.0, 0.0.0]",javax.swing.plaf.basic;version="[0.0
.0, 0.0.0]",javax.swing.border;version="[0.0.0, 0.0.0]",javax.management.openmbean;version="[0.0.0, 0.0.0]",javax.securi
ty.auth;version="[0.0.0, 0.0.0]",org.eclipse.osgi.service.security;version="[1.0.0, 1.0.0]",javax.imageio.event;version=
"[0.0.0, 0.0.0]",org.w3c.dom;version="[0.0.0, 0.0.0]",javax.xml.datatype;version="[0.0.0, 0.0.0]",javax.imageio.metadata
;version="[0.0.0, 0.0.0]",javax.management.remote;version="[0.0.0, 0.0.0]",org.omg.CORBA.DynAnyPackage;version="[0.0.0,
0.0.0]",javax.swing.table;version="[0.0.0, 0.0.0]",javax.xml.transform.stream;version="[0.0.0, 0.0.0]",javax.xml.crypto;
version="[0.0.0, 1.0.0]",org.eclipse.osgi.service.resolver;version="[1.5.0, 1.5.0]",javax.annotation.processing;version=
"[0.0.0, 0.0.0]",javax.security.auth.login;version="[0.0.0, 0.0.0]",javax.imageio.stream;version="[0.0.0, 0.0.0]",org.os
gi.framework.hooks.service;version="[1.1.0, 1.1.0]",javax.xml.ws.http;version="[0.0.0, 2.1.1]",javax.jws.soap;version="[
0.0.0, 2.0.0]",javax.xml.bind.helpers;version="[0.0.0, 2.0.0]",javax.imageio;version="[0.0.0, 0.0.0]",javax.swing.text.r
tf;version="[0.0.0, 0.0.0]",javax.security.cert;version="[0.0.0, 0.0.0]",org.eclipse.osgi.service.debug;version="[1.2.0,
1.2.0]",javax.lang.model.element;version="[0.0.0, 0.0.0]",javax.rmi.CORBA;version="[0.0.0, 0.0.0]",javax.xml.ws.soap;ve
rsion="[0.0.0, 2.1.1]",org.w3c.dom.events;version="[0.0.0, 0.0.0]",javax.swing.text.html.parser;version="[0.0.0, 0.0.0]"
,javax.crypto.spec;version="[0.0.0, 0.0.0]",org.eclipse.osgi.internal.module;version="[0.0.0, 0.0.0]",org.eclipse.osgi.s
ignedcontent;version="[1.0.0, 1.0.0]",javax.swing.plaf.metal;version="[0.0.0, 0.0.0]",javax.accessibility;version="[0.0.
0, 0.0.0]",org.eclipse.osgi.framework.internal.protocol.bundleresource;version="[0.0.0, 0.0.0]",org.eclipse.osgi.framewo
rk.internal.core;version="[0.0.0, 0.0.0]",org.eclipse.osgi.framework.log;version="[1.1.0, 1.1.0]",org.eclipse.osgi.inter
nal.baseadaptor;version="[0.0.0, 0.0.0]",org.osgi.framework.startlevel;version="[1.0.0, 1.0.0]",javax.management;version
="[0.0.0, 0.0.0]",org.eclipse.osgi.framework.internal.protocol.bundleentry;version="[0.0.0, 0.0.0]",javax.swing.colorcho
oser;version="[0.0.0, 0.0.0]",javax.naming.directory;version="[0.0.0, 0.0.0]",org.omg.SendingContext;version="[0.0.0, 0.
0.0]",org.w3c.dom.views;version="[0.0.0, 0.0.0]",org.xml.sax.ext;version="[0.0.0, 0.0.0]",javax.xml.bind.util;version="[
0.0.0, 2.0.0]",javax.transaction.xa;version="[0.0.0, 1.1.0]",javax.security.auth.x500;version="[0.0.0, 0.0.0]",javax.ser
vlet.jsp.tagext;version="2.1.0",javax.net.ssl;version="[0.0.0, 0.0.0]",javax.management.monitor;version="[0.0.0, 0.0.0]"
,javax.swing.text.html;version="[0.0.0, 0.0.0]",javax.imageio.plugins.jpeg;version="[0.0.0, 0.0.0]",org.eclipse.osgi.ser
vice.internal.composite;version="[0.0.0, 0.0.0]",org.w3c.dom.bootstrap;version="[0.0.0, 0.0.0]",org.eclipse.osgi.baseada
ptor.loader;version="[0.0.0, 0.0.0]",javax.xml.bind.annotation;version="[0.0.0, 2.0.0]",org.eclipse.osgi.launch;version=
"[1.0.0, 1.0.0]",javax.xml.validation;version="[0.0.0, 0.0.0]",javax.sound.sampled;version="[0.0.0, 0.0.0]",org.xml.sax.
helpers;version="[0.0.0, 0.0.0]",javax.lang.model.type;version="[0.0.0, 0.0.0]",javax.management.remote.rmi;version="[0.
0.0, 0.0.0]",org.eclipse.osgi.internal.loader.buddy;version="[0.0.0, 0.0.0]",javax.sound.sampled.spi;version="[0.0.0, 0.
0.0]",javax.activity;version="[0.0.0, 0.0.0]",javax.sql.rowset.spi;version="[0.0.0, 0.0.0]",org.osgi.util.tracker;versio
n="[1.5.0, 1.5.0]",org.eclipse.osgi.internal.signedcontent;version="[0.0.0, 0.0.0]",javax.security.sasl;version="[0.0.0,
0.0.0]",org.eclipse.osgi.internal.profile;version="[0.0.0, 0.0.0]",javax.security.auth.callback;version="[0.0.0, 0.0.0]
",javax.el;version="1.0.0",org.eclipse.osgi.internal.provisional.service.security;version="[1.0.0, 1.0.0]",javax.tools;v
ersion="[0.0.0, 0.0.0]",javax.xml;version="[0.0.0, 1.0.1]",org.osgi.framework.hooks.bundle;version="[1.0.0, 1.0.0]",java
x.activation;version="[0.0.0, 1.1.1]",org.eclipse.osgi.service.urlconversion;version="[1.0.0, 1.0.0]",javax.xml.transfor
m;version="[0.0.0, 0.0.0]",javax.xml.crypto.dsig;version="[0.0.0, 1.0.0]",org.osgi.framework.hooks.weaving;version="[1.0
.0, 1.0.0]",javax.swing.plaf.synth;version="[0.0.0, 0.0.0]",javax.xml.crypto.dom;version="[0.0.0, 1.0.0]",javax.servlet.
http;version="2.5.0"
Archiver-Version = Plexus Archiver
osgi>
Re: Error configuring application listener: ClassNotFoundException [message #892000 is a reply to message #891998] |
Tue, 26 June 2012 19:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Marcelo Riss![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=marcelo.riss%40gmail.com) Messages: 4 Registered: June 2012 |
Just forgot it:
Now the command headers 117 (which is the number of form tags bundle) at osgi user region console is returning:
Bundle 117
Ant-Version = Apache Ant 1.7.0
Bundle-ClassPath = WEB-INF/classes,WEB-INF/lib/com.springsource.javax.servlet-2.5.0.jar,WEB-INF/lib/com.springsource.org.apache.commons.logging-1.1.1.jar,WEB-INF/lib/org.springframework.core-3.0.0.RELEASE.jar,WEB-INF/lib/com.springsource.javax.servlet.jsp.jstl-1.1.2.jar,WEB-INF/lib/com.springsource.org.apache.taglibs.standard-1.1.2.jar,WEB-INF/lib/org.springframework.web-3.0.0.RELEASE.jar,WEB-INF/lib/org.springframework.asm-3.0.0.RELEASE.jar,WEB-INF/lib/org.springframework.web.servlet-3.0.0.RELEASE.jar,WEB-INF/lib/org.springframework.expression-3.0.0.RELEASE.jar,WEB-INF/lib/org.springframework.beans-3.0.0.RELEASE.jar,WEB-INF/lib/org.springframework.context-3.0.0.RELEASE.jar,WEB-INF/lib/org.springframework.context.support-3.0.0.RELEASE.jar
Created-By = 1.5.0_13-119 (Apple Inc.)
Bundle-SymbolicName = formtags-war-3.0.0.BUILD-20120625213834
Web-ContextPath = formtags-war-3.0.0.BUILD-20120625213834
Import-Package = javax.crypto.interfaces;version="[0.0.0, 0.0.0]",org.omg.CosNaming.NamingContextPackage;version="[0.0.0, 0.0.0]",org.omg.DynamicAny.DynAnyFactoryPackage;version="[0.0.0, 0.0.0]",org.eclipse.osgi.internal.provisional.verifier;version="[0.0.0, 0.0.0]",javax.management.timer;version="[0.0.0, 0.0.0]",javax.jws;version="[0.0.0, 2.0.0]",org.eclipse.osgi.baseadaptor.hooks;version="[0.0.0, 0.0.0]",org.osgi.framework.wiring;version="[1.0.0, 1.0.0]",javax.rmi.ssl;version="[0.0.0, 0.0.0]",org.w3c.dom.ranges;version="[0.0.0, 0.0.0]",javax.naming.spi;version="[0.0.0, 0.0.0]",javax.xml.stream;version="[0.0.0, 1.0.1]",javax.swing.filechooser;version="[0.0.0, 0.0.0]",javax.swing.plaf;version="[0.0.0, 0.0.0]",javax.lang.model;version="[0.0.0, 0.0.0]",javax.lang.model.util;version="[0.0.0, 0.0.0]",org.eclipse.osgi.framework.eventmgr;version="[1.2.0, 1.2.0]",javax.naming.ldap;version="[0.0.0, 0.0.0]",javax.security.auth.kerberos;version="[0.0.0, 0.0.0]",javax.crypto;version="[0.0.0, 0.0.0]",org.omg.PortableServer.CurrentPackage;version="[0.0.0, 0.0.0]",javax.servlet.jsp;version="2.1.0",javax.naming.event;version="[0.0.0, 0.0.0]",javax.print.attribute.standard;version="[0.0.0, 0.0.0]",javax.imageio.plugins.bmp;version="[0.0.0, 0.0.0]",org.eclipse.osgi.baseadaptor.bundlefile;version="[0.0.0, 0.0.0]",org.osgi.service.permissionadmin;version="[1.2.0, 1.2.0]",javax.annotation;version="[0.0.0, 1.0.0]",javax.xml.ws.handler.soap;version="[0.0.0, 2.1.1]",org.osgi.service.url;version="[1.0.0, 1.0.0]",javax.xml.transform.dom;version="[0.0.0, 0.0.0]",javax.print.attribute;version="[0.0.0, 0.0.0]",javax.sql.rowset.serial;version="[0.0.0, 0.0.0]",org.w3c.dom.traversal;version="[0.0.0, 0.0.0]",org.eclipse.core.runtime.internal.adaptor;version="[0.0.0, 0.0.0]",org.osgi.framework.hooks.resolver;version="[1.0.0, 1.0.0]",org.omg.PortableServer.POAManagerPackage;version="[0.0.0, 0.0.0]",javax.sound.midi;version="[0.0.0, 0.0.0]",org.eclipse.osgi.service.pluginconversion;version="[1.0.0, 1.0.0]",javax.swing.event;version="[0.0.0, 0.0.0]",javax.xml.ws.spi;version="[0.0.0, 2.1.1]",org.eclipse.osgi.util;version="[1.1.0, 1.1.0]",javax.xml.stream.util;version="[0.0.0, 1.0.1]",javax.net;version="[0.0.0, 0.0.0]",javax.security.auth.spi;version="[0.0.0, 0.0.0]",javax.management.loading;version="[0.0.0, 0.0.0]",javax.print;version="[0.0.0, 0.0.0]",org.omg.Messaging;version="[0.0.0, 0.0.0]",javax.xml.crypto.dsig.keyinfo;version="[0.0.0, 1.0.0]",org.omg.CORBA.ORBPackage;version="[0.0.0, 0.0.0]",javax.swing.plaf.multi;version="[0.0.0, 0.0.0]",javax.xml.namespace;version="[0.0.0, 0.0.0]",org.osgi.service.startlevel;version="[1.1.0, 1.1.0]",javax.servlet;version="2.5.0",org.osgi.service.log;version="[1.3.0, 1.3.0]",org.eclipse.osgi.framework.internal.protocol;version="[0.0.0, 0.0.0]",javax.swing;version="[0.0.0, 0.0.0]",org.eclipse.osgi.internal.loader;version="[0.0.0, 0.0.0]",javax.xml.transform.sax;version="[0.0.0, 0.0.0]",org.eclipse.osgi.service.localization;version="[1.1.0, 1.1.0]",javax.management.relation;version="[0.0.0, 0.0.0]",javax.naming;version="[0.0.0, 0.0.0]",javax.xml.transform.stax;version="[0.0.0, 0.0.0]",org.eclipse.core.runtime.internal.stats;version="[0.0.0, 0.0.0]",org.omg.stub.java.rmi;version="[0.0.0, 0.0.0]",javax.xml.crypto.dsig.dom;version="[0.0.0, 1.0.0]",javax.xml.parsers;version="[0.0.0, 0.0.0]",org.ietf.jgss;version="[0.0.0, 0.0.0]",javax.xml.xpath;version="[0.0.0, 0.0.0]",javax.xml.bind.attachment;version="[0.0.0, 2.0.0]",org.eclipse.osgi.internal.composite;version="[0.0.0, 0.0.0]",javax.servlet.jsp.el;version="2.1.0",org.eclipse.osgi.framework.console;version="[1.1.0, 1.1.0]",org.osgi.framework;version="[1.6.0, 1.6.0]",org.eclipse.osgi.storagemanager;version="[1.0.0, 1.0.0]",javax.xml.crypto.dsig.spec;version="[0.0.0, 1.0.0]",org.eclipse.osgi.internal.permadmin;version="[0.0.0, 0.0.0]",javax.swing.undo;version="[0.0.0, 0.0.0]",javax.swing.text;version="[0.0.0, 0.0.0]",javax.print.event;version="[0.0.0, 0.0.0]",javax.imageio.spi;version="[0.0.0, 0.0.0]",org.osgi.service.framework;version="[1.0.0, 1.0.0]",org.w3c.dom.stylesheets;version="[0.0.0, 0.0.0]",javax.script;version="[0.0.0, 1.1.0]",org.w3c.dom.ls;version="[0.0.0, 0.0.0]",org.omg.PortableInterceptor;version="[0.0.0, 0.0.0]",org.omg.CORBA.TypeCodePackage;version="[0.0.0, 0.0.0]",org.osgi.framework.launch;version="[1.0.0, 1.0.0]",org.eclipse.osgi.framework.util;version="[0.0.0, 0.0.0]",org.eclipse.osgi.service.environment;version="[1.3.0, 1.3.0]",javax.xml.bind.annotation.adapters;version="[0.0.0, 2.0.0]",org.eclipse.osgi.internal.serviceregistry;version="[0.0.0, 0.0.0]",javax.xml.stream.events;version="[0.0.0, 1.0.1]",javax.sql;version="[0.0.0, 0.0.0]",org.eclipse.equinox.log.internal;version="[0.0.0, 0.0.0]",org.omg.CORBA_2_3;version="[0.0.0, 0.0.0]",javax.transaction;version="[0.0.0, 1.1.0]",javax.rmi;version="[0.0.0, 0.0.0]",org.eclipse.osgi.service.datalocation;version="[1.3.0, 1.3.0]",javax.xml.soap;version="[0.0.0, 1.3.0]",org.eclipse.osgi.baseadaptor;version="[0.0.0, 0.0.0]",org.eclipse.osgi.internal.resolver;version="[0.0.0, 0.0.0]",javax.xml.bind;version="[0.0.0, 2.0.0]",javax.management.modelmbean;version="[0.0.0, 0.0.0]",javax.xml.ws;version="[0.0.0, 2.1.1]",org.w3c.dom.html;version="[0.0.0, 0.0.0]",org.eclipse.osgi.framework.debug;version="[0.0.0, 0.0.0]",javax.swing.tree;version="[0.0.0, 0.0.0]",javax.sound.midi.spi;version="[0.0.0, 0.0.0]",org.eclipse.equinox.log;version="[1.0.0, 1.0.0]",org.w3c.dom.css;version="[0.0.0, 0.0.0]",org.omg.PortableServer;version="[0.0.0, 0.0.0]",org.eclipse.osgi.event;version="[1.0.0, 1.0.0]",org.eclipse.osgi.framework.internal.protocol.reference;version="[0.0.0, 0.0.0]",org.xml.sax;version="[0.0.0, 0.0.0]",javax.xml.ws.handler;version="[0.0.0, 2.1.1]",org.eclipse.osgi.service.runnable;version="[1.1.0, 1.1.0]",org.eclipse.osgi.internal.service.security;version="[0.0.0, 0.0.0]",org.omg.IOP.CodecFactoryPackage;version="[0.0.0, 0.0.0]",org.omg.IOP;version="[0.0.0, 0.0.0]",org.eclipse.osgi.framework.adaptor;version="[0.0.0, 0.0.0]",javax.sql.rowset;version="[0.0.0, 0.0.0]",org.eclipse.osgi.framework.internal.reliablefile;version="[0.0.0, 0.0.0]",org.eclipse.core.runtime.adaptor;version="[0.0.0, 0.0.0]",javax.swing.plaf.basic;version="[0.0.0, 0.0.0]",javax.swing.border;version="[0.0.0, 0.0.0]",javax.management.openmbean;version="[0.0.0, 0.0.0]",org.omg.CORBA.portable;version="[0.0.0, 0.0.0]",org.omg.Dynamic;version="[0.0.0, 0.0.0]",javax.security.auth;version="[0.0.0, 0.0.0]",org.eclipse.osgi.service.security;version="[1.0.0, 1.0.0]",javax.imageio.event;version="[0.0.0, 0.0.0]",org.w3c.dom;version="[0.0.0, 0.0.0]",javax.xml.datatype;version="[0.0.0, 0.0.0]",org.omg.DynamicAny.DynAnyPackage;version="[0.0.0, 0.0.0]",javax.imageio.metadata;version="[0.0.0, 0.0.0]",javax.management.remote;version="[0.0.0, 0.0.0]",org.omg.CORBA.DynAnyPackage;version="[0.0.0, 0.0.0]",javax.swing.table;version="[0.0.0, 0.0.0]",javax.xml.transform.stream;version="[0.0.0, 0.0.0]",javax.xml.crypto;version="[0.0.0, 1.0.0]",org.eclipse.osgi.service.resolver;version="[1.5.0, 1.5.0]",javax.annotation.processing;version="[0.0.0, 0.0.0]",javax.security.auth.login;version="[0.0.0, 0.0.0]",org.omg.CORBA;version="[0.0.0, 0.0.0]",javax.imageio.stream;version="[0.0.0, 0.0.0]",org.osgi.framework.hooks.service;version="[1.1.0, 1.1.0]",org.omg.IOP.CodecPackage;version="[0.0.0, 0.0.0]",javax.xml.ws.http;version="[0.0.0, 2.1.1]",javax.jws.soap;version="[0.0.0, 2.0.0]",javax.xml.bind.helpers;version="[0.0.0, 2.0.0]",javax.imageio;version="[0.0.0, 0.0.0]",org.omg.PortableServer.portable;version="[0.0.0, 0.0.0]",javax.swing.text.rtf;version="[0.0.0, 0.0.0]",javax.security.cert;version="[0.0.0, 0.0.0]",org.eclipse.osgi.service.debug;version="[1.2.0, 1.2.0]",javax.lang.model.element;version="[0.0.0, 0.0.0]",javax.rmi.CORBA;version="[0.0.0, 0.0.0]",javax.xml.ws.soap;version="[0.0.0, 2.1.1]",org.w3c.dom.events;version="[0.0.0, 0.0.0]",org.omg.CosNaming;version="[0.0.0, 0.0.0]",org.omg.CosNaming.NamingContextExtPackage;version="[0.0.0, 0.0.0]",javax.swing.text.html.parser;version="[0.0.0, 0.0.0]",org.osgi.service.condpermadmin;version="[1.1.1, 1.1.1]",javax.crypto.spec;version="[0.0.0, 0.0.0]",org.eclipse.osgi.internal.module;version="[0.0.0, 0.0.0]",org.omg.PortableServer.POAPackage;version="[0.0.0, 0.0.0]",org.eclipse.osgi.signedcontent;version="[1.0.0, 1.0.0]",javax.swing.plaf.metal;version="[0.0.0, 0.0.0]",javax.accessibility;version="[0.0.0, 0.0.0]",org.eclipse.osgi.framework.internal.protocol.bundleresource;version="[0.0.0, 0.0.0]",org.eclipse.osgi.framework.internal.core;version="[0.0.0, 0.0.0]",org.eclipse.osgi.framework.log;version="[1.1.0, 1.1.0]",org.eclipse.osgi.internal.baseadaptor;version="[0.0.0, 0.0.0]",org.osgi.framework.startlevel;version="[1.0.0, 1.0.0]",javax.management;version="[0.0.0, 0.0.0]",org.omg.PortableServer.ServantLocatorPackage;version="[0.0.0, 0.0.0]",org.eclipse.osgi.framework.internal.protocol.bundleentry;version="[0.0.0, 0.0.0]",javax.swing.colorchooser;version="[0.0.0, 0.0.0]",javax.naming.directory;version="[0.0.0, 0.0.0]",org.omg.SendingContext;version="[0.0.0, 0.0.0]",org.w3c.dom.views;version="[0.0.0, 0.0.0]",org.xml.sax.ext;version="[0.0.0, 0.0.0]",javax.xml.bind.util;version="[0.0.0, 2.0.0]",javax.transaction.xa;version="[0.0.0, 1.1.0]",javax.security.auth.x500;version="[0.0.0, 0.0.0]",javax.servlet.jsp.tagext;version="2.1.0",javax.net.ssl;version="[0.0.0, 0.0.0]",javax.management.monitor;version="[0.0.0, 0.0.0]",javax.swing.text.html;version="[0.0.0, 0.0.0]",org.osgi.service.packageadmin;version="[1.2.0, 1.2.0]",javax.imageio.plugins.jpeg;version="[0.0.0, 0.0.0]",org.eclipse.osgi.service.internal.composite;version="[0.0.0, 0.0.0]",org.w3c.dom.bootstrap;version="[0.0.0, 0.0.0]",org.eclipse.osgi.baseadaptor.loader;version="[0.0.0, 0.0.0]",javax.xml.bind.annotation;version="[0.0.0, 2.0.0]",org.eclipse.osgi.launch;version="[1.0.0, 1.0.0]",javax.xml.validation;version="[0.0.0, 0.0.0]",javax.sound.sampled;version="[0.0.0, 0.0.0]",org.xml.sax.helpers;version="[0.0.0, 0.0.0]",javax.lang.model.type;version="[0.0.0, 0.0.0]",javax.management.remote.rmi;version="[0.0.0, 0.0.0]",org.eclipse.osgi.internal.loader.buddy;version="[0.0.0, 0.0.0]",javax.sound.sampled.spi;version="[0.0.0, 0.0.0]",javax.activity;version="[0.0.0, 0.0.0]",javax.sql.rowset.spi;version="[0.0.0, 0.0.0]",org.eclipse.osgi.internal.signedcontent;version="[0.0.0, 0.0.0]",org.osgi.util.tracker;version="[1.5.0, 1.5.0]",org.omg.DynamicAny;version="[0.0.0, 0.0.0]",org.omg.PortableInterceptor.ORBInitInfoPackage;version="[0.0.0, 0.0.0]",org.eclipse.osgi.internal.profile;version="[0.0.0, 0.0.0]",javax.security.sasl;version="[0.0.0, 0.0.0]",javax.security.auth.callback;version="[0.0.0, 0.0.0]",javax.el;version="1.0.0",org.eclipse.osgi.internal.provisional.service.security;version="[1.0.0, 1.0.0]",javax.tools;version="[0.0.0, 0.0.0]",org.osgi.framework.hooks.bundle;version="[1.0.0, 1.0.0]",javax.xml;version="[0.0.0, 1.0.1]",javax.activation;version="[0.0.0, 1.1.1]",org.eclipse.osgi.service.urlconversion;version="[1.0.0, 1.0.0]",javax.xml.transform;version="[0.0.0, 0.0.0]",org.omg.CORBA_2_3.portable;version="[0.0.0, 0.0.0]",javax.xml.crypto.dsig;version="[0.0.0, 1.0.0]",org.osgi.framework.hooks.weaving;version="[1.0.0, 1.0.0]",javax.swing.plaf.synth;version="[0.0.0, 0.0.0]",javax.xml.crypto.dom;version="[0.0.0, 1.0.0]",javax.servlet.http;version="2.5.0"
Current Time: Sat Jul 27 13:21:30 GMT 2024
Powered by FUDForum. Page generated in 0.05585 seconds
