Home » Archived » BIRT » Integrating birt perspective into new rcp-application
- Integrating birt perspective into new rcp-application [message #889831] Tue, 19 June 2012 16:20 Go to next message
I have to integrate the birt-report-design perspective into our rcp-application.
I tried with:
PlatformUI.getWorkbench().openWorkbenchWindow(
"org.eclipse.birt.report.designer.ui.ReportPerspective",null);
But the workbench window which opens looks like in the attached image.
I thought i might have to provide a parameter so i tried to debug the opening of the birt-perspective when its running in eclipse, but didnt find the right place to start.
Do you have any idea what i did wrong?
Thanks in advance
  • Attachment: screen229.png
    (Size: 16.91KB, Downloaded 265 times)
- Re: Integrating birt perspective into new rcp-application [message #889850 is a reply to message #889831] Tue, 19 June 2012 18:18 Go to previous messageGo to next message
Have you tried showPerspective? I pulled this form a test in the source:
package org.eclipse.birt.report.designer.testutil;
import junit.framework.TestCase;
import org.eclipse.birt.report.designer.tests.ITestConstants;
import org.eclipse.core.resources.IFile;
import org.eclipse.core.resources.IProject;
import org.eclipse.ui.IEditorPart;
import org.eclipse.ui.IPerspectiveDescriptor;
import org.eclipse.ui.IViewPart;
import org.eclipse.ui.IViewReference;
import org.eclipse.ui.IWorkbench;
import org.eclipse.ui.IWorkbenchPage;
import org.eclipse.ui.IWorkbenchWindow;
import org.eclipse.ui.PlatformUI;
import org.eclipse.ui.part.FileEditorInput;
* Base class of BIRT GUI Features test
public class BirtUITestCase extends TestCase implements ITestConstants
protected IWorkbench tWorkbench;
protected IWorkbenchWindow tWindow;
protected IWorkbenchPage tPage;
protected IPerspectiveDescriptor tPerspectiveDescriptor;
protected IEditorPart tEditor = null;
* (non-Javadoc)
* @see junit.framework.TestCase#setUp()
protected void setUp( ) throws Exception
tWorkbench = PlatformUI.getWorkbench( );
tWindow = tWorkbench.getActiveWorkbenchWindow( );
tPage = tWindow.getActivePage( );
tPerspectiveDescriptor = tWorkbench.getPerspectiveRegistry( )
.findPerspectiveWithId( PERSPECTIVE_ID );
* Switch to the Report Designer Perspective
protected void showPerspective( ) throws Exception
tWorkbench.showPerspective( PERSPECTIVE_ID, tWindow );
* Opens the ReportEditor
* @return the Report Editor
protected IEditorPart openEditor( ) throws Exception
if ( tEditor == null )
IProject p = FileUtil.createProject( TEST_PROJECT_NAME );
IFile f = FileUtil.createFile( TEST_DESIGN_FILE, p );
tEditor = tPage.openEditor( new FileEditorInput( f ), EDITOR_ID );
return tEditor;
* Saves the opened editor
protected void saveEditor( )
if ( tEditor != null )
tEditor.doSave( null );
* Closes the opened editor without saving changes
protected void closeEditor( )
tPage.closeEditor( tEditor, false );
tEditor = null;
* Gets the ViewPart with the specified id
* @param id
* the id of view part
* @return Returns the view part, or null if not found
protected IViewPart getView( String id )
IViewReference[] v = tPage.getViewReferences( );
int i;
for ( i = 0; i < v.length; i++ )
if ( v[i].getId( ).equals( id ) )
return (IViewPart) v[i].getPart( true );
return null;
Jason
On 6/19/2012 4:20 PM, Sam Mising name wrote:
> I tried with:
> Thanks in advance
- Re: Integrating birt perspective into new rcp-application [message #890140 is a reply to message #889850] Thu, 21 June 2012 05:08 Go to previous messageGo to next message
Thank you for your reply.
Your suggestion didnt help in my case, but i figured out the problem was:
1. The WorkbenchWindowAdvisor of our application did deactivate many parts of the workbench, as in our application you dont recognize it to be based on eclipse rcp.
So i had to implement a Factory in the application where you can set the .class of from the advisor you want to be created.
When the new WorkbenchWindow is created the rcp-framework calls the createAdvisor-method located in the application and so the new advisor is returned.
2. Not all necessary plugins were started.
There is only one problem left:
The navigor shows nothing, but i can right-click and add new projects, then you see an empty entry, but if you restart its empty again even the projects are in the workspace.
If you add a new report you see all projects in the wizard, but again as empty lines.
Images are attached.
Thanks for your help
- Re: Integrating birt perspective into new rcp-application [message #1016200 is a reply to message #890140] Tue, 05 March 2013 08:17 Go to previous message
It's been a while, but I'm experiencing the same problem. Did you find a solution for it? That would be very helpful.
Best regards
Bastian
Previous Topic:YYYY vs yyyy in onrender()
Next Topic:Update BIRT 4.2.1 to BIRT 4.2.2 / Eclipse Juno: Conflicting dependency
Current Time: Thu Apr 24 06:55:18 EDT 2025
Powered by FUDForum. Page generated in 0.04567 seconds
