Re: Installing a JDBC driver [message #8897 is a reply to message #7902] |
Thu, 17 February 2005 15:34 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: sschafer.innoventsolutions.com
Thierry,
Could you please post the odaconfig.xml file for the benefit of those of
us who are not up on ODA? Also I found 4 instances of odaconfig.xml:
one in plugins\org.eclipse.birt.report.data.oda.jdbc_0.0.1, and the rest
in the viewer/WEB-INF area. Do they all need to be modified?
Thierry Lach wrote:
> I've been able to add a driver jar to the
> org.eclipse.birt.report.data.oda.jdbc project, and by adding the jar name to
> odaconfig.xml, I've been able to access another jdbc driver.
> It seems to me that this mechanism is not flexible enough as it requires
> some knowledge of eclipse and birt internals. I'd prefer to see a mechanism
> by which the ODA-JDBC driver could be handed a jar file reference by another
> plugin.
> Here's an example plugin.xml:
> <?eclipse version="3.0"?>
> <plugin
> id="org.eclipse.birt.report.data.oda.jdbc.mysql"
> name="MySQL JDBC Driver Plug-in"
> version="1.0.0"
> provider-name="">
> <runtime>
> <library name="mysql-connector-java-3.1.6-bin.jar">
> <export name="*"/>
> </library>
> </runtime>
> <requires>
> <import plugin="org.eclipse.birt.report.data.oda.jdbc"/>
> <import plugin="org.eclipse.birt.report.data.oda.jdbc.ui"/>
> </requires>
> <extension point="org.eclipse.birt.report.data.oda.jdbc.driver">
> <driver jar="mysql-connector-java-3.1.6-bin.jar"/>
> </extension>
> </plugin>
> I'm working on getting this example running.
> "Thierry Lach" <thierry.lach@bbdodetroit.com> wrote in message
> news:cuig3o$7qe$1@www.eclipse.org...
>>How can different JDBC drivers be added to the existing driver?
Re: Installing a JDBC driver [message #12057 is a reply to message #7800] |
Wed, 02 March 2005 00:58 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Linda Chan![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=lchan%40actuate.com) Messages: 845 Registered: July 2009 |
Hi Thierry,
As you had found, to specify a different JDBC driver, simply include its
jar file(s) in the JDBC ODA driver's configuration file (odaconfig.xml).
Below are some more details on various configurable options.
An ODA driver's odaconfig.xml file is by default in the same installation
directory as the ODA driver's plugin.xml, e.g. in the
"org.eclipse.birt.report.data.oda.jdbc" for the JDBC ODA driver. The BIRT
ODA plugin schema has an extension point element for a driver's
"configFileDir". It is optional for specifying the directory of its
odaconfig.xml .
In the JDBC ODA configuration file's
<RunTimeInterface>.<DriverLibraries>.<LibrariesForOS>.<LibraryName >
element, simply replace the sample value of "jtds-0.9.jar" with the name
of your JDBC jar file. Add another <LibraryName> element for each
additional jar file that might be needed.
A copy of the ODA configuration's XML schema definition (ODAConfig.xsd)
can be found in BIRT's Eclipse CVS, under the
source/org.eclipse.birt.data/schema folder. A driver's library files are
by default expected in the same directory as the odaconfig.xml. You can
optionally add a <Location> element to specify the path of all the library
files.
BTW, an ODA driver is intended to also run outside of the Eclipse desk top
environment, such as a J2EE Appl server.
One can use any XML editor to edit the odaconfig.xml directly.
We are looking into providing an UI editor tool that would make it easier
for one to configure any type of ODA driver. The JDBC one is simply an
example of one type of ODA drivers.
Linda
BIRT Data Engine team lead
FUDForum. Page generated in 0.03031 seconds
