Home » Language IDEs » PHP Development Tools (PDT) » [Announce] PDT 2.0.1 M200901080831 is available
[Announce] PDT 2.0.1 M200901080831 is available [message #88856] Thu, 08 January 2009 09:02 Go to next message
Originally posted by: pdtBuild.build.eclipse.org
The following build [1] will be available at eclipse.org in the next 30-60 mins.
[1] http://www.eclipse.org/pdt/downloads/?project=pdt&showAl l=1&hlbuild=M200901080831#M200901080831
Updated release notes [2] will be available within to 24hrs.
[2] http://www.eclipse.org/pdt/news/relnotes.php?project=pdt& ;version=M200901080831
Re: [Announce] PDT 2.0.1 M200901080831 is available [message #88874 is a reply to message #88856] Thu, 08 January 2009 13:23 Go to previous messageGo to next message
Thu, 08 Jan 2009 19:02:09 +0500, Build Monkey <pdtBuild@build.eclipse.org> написал:
> 30-60 mins.
> [1]
> [2]
Cool, my problem is solved.
But can anybody tell what version is the lates (i don't understand it): 2.0.1 OR 2.1.0 ?
Re: [Announce] PDT 2.0.1 M200901080831 is available [message #88903 is a reply to message #88874] Thu, 08 January 2009 14:08 Go to previous messageGo to next message
Originally posted by: nickboldt+eclipse+newsgroup.gmail.com
Generally, bug numbers == newer.
2.0.1 are maintenance fixes for 2.0.0, targeted for Eclipse 3.4.
2.1.0 is a work-in-progress, targeted for Eclipse 3.5 and to be released
at the end of June.
So, it depends on if you're using Eclipse 3.4.x or 3.5.x, really.
>> 30-60 mins.
>> [1]
>> [2]
> 2.0.1 OR 2.1.0 ?
Nick Boldt :: http://wiki.eclipse.org/User:Nickb
Re: [Announce] PDT 2.0.1 M200901080831 is available [message #88961 is a reply to message #88903] Thu, 08 January 2009 15:27 Go to previous messageGo to next message
That should have read BIG numbers, not bug numbers.
> at the end of June.
>>> 30-60 mins.
>>> [1]
>>> [2]
Re: [Announce] PDT 2.0.1 M200901080831 is available [message #88975 is a reply to message #88961] Fri, 09 January 2009 05:55 Go to previous messageGo to next message
>> released at the end of June.
>>>> 30-60 mins.
>>>> [1]
>>>> [2]
I was also confused, i thought 2.1.0 supercedes 2.0, but it seems that i
was wrong. You guys should update the project plan, it does not mention
2.1.* at all :)
Re: [Announce] PDT 2.0.1 M200901080831 is available [message #89023 is a reply to message #88975] Fri, 09 January 2009 09:41 Go to previous messageGo to next message
If you look at the PDT homepage (http://www.eclipse.org/pdt/) you should
see:
26th of June, 2009 - PDT 2.1 Release
29th of December, 2008 - PDT 2.0 Release
The project plan is for 2.0; a 2.1 plan has not yet been drafted as the
2.1 cycle only started this week.
And yes, 2.1.0 WILL supercede 2.0.0, if you also plan to move up from
Eclipse 3.4 to 3.5.
>>>>> 30-60 mins.
>>>>> [1]
>>>>> [2]
> 2.1.* at all :)
Re: [Announce] PDT 2.0.1 M200901080831 is available [message #89185 is a reply to message #89023] Fri, 09 January 2009 15:28 Go to previous messageGo to next message
I don t know if I doing something wrong...
I m having the same bug that rapkasta related ( ctrl+click doesnt open
link in folder above ).
I got about the fix M200901080831, SDK (Runtime, Source), Runtime and
Automated Tests, and unziped this on plugins /features folder in my
eclipse folder...
but the problem is not solved...
have I do anything more ????
what I doing wrong ?
thanks
Re: [Announce] PDT 2.0.1 M200901080831 is available [message #89200 is a reply to message #89023] Fri, 09 January 2009 15:44 Go to previous messageGo to next message
I am having the same problem that rapkasta cited.
but I download the M200901080831 fix, SDK (Runtime, Source), Runtime and
Automated Tests, unziped the files in plugins/features folders, but the
problem persists.
I am doing something wrong ? How can I resolve this ?
thanks
Re: [Announce] PDT 2.0.1 M200901080831 is available [message #89216 is a reply to message #89023] Fri, 09 January 2009 15:45 Go to previous messageGo to next message
problem persists.
thanks
> see:
> Eclipse 3.4 to 3.5.
>>>>> <pdtBuild@build.eclipse.org> МапОсал:
>>>>>> 30-60 mins.
>>>>>> [1]
>>>>>> [2]
>> 2.1.* at all :)
Re: [Announce] PDT 2.0.1 M200901080831 is available [message #89230 is a reply to message #89023] Fri, 09 January 2009 15:49 Go to previous messageGo to next message
problem persists.
thanks
Re: [Announce] PDT 2.0.1 M200901080831 is available [message #89420 is a reply to message #89185] Sat, 10 January 2009 09:12 Go to previous messageGo to next message
No Message Body
Re: [Announce] PDT 2.0.1 M200901080831 is available [message #89424 is a reply to message #89230] Sat, 10 January 2009 09:14 Go to previous messageGo to next message
Please, do not write repeat message - people understand what you need by first message :)
Re: [Announce] PDT 2.0.1 M200901080831 is available [message #89527 is a reply to message #89230] Sun, 11 January 2009 00:50 Go to previous messageGo to next message
Originally posted by: michael.zend.com
Weird... it works for me:
http://img519.imageshack.us/my.php?image=22419895jx6.png
Any chance you are still running an old version of PDT?
Thanks!
"Fernando Dias" <fdias.webdev@gmail.com> wrote in message
news:c6f0ce286ebcb1c69f04e54c8c4d1924$1@www.eclipse.org...
> problem persists.
> thanks
Re: [Announce] PDT 2.0.1 M200901080831 is available [message #89571 is a reply to message #89527] Mon, 12 January 2009 06:22 Go to previous messageGo to next message
1st all sorry to repeat the message, I have had problems to do the post,
so I try to do it a lot of things, I know that is not appropriate.
I will be honest, I am trying to check if the PDF is a old version, but I
cant check this correctly.
In about box I have this info:
Eclipse SDK
"Version: 3.4.1
Build id: M20080911-1700"
And I have downloaded the M200901080831 fix, SDK Runtime, Source and
unziped the files in plugins/features folders.
> Thanks!
>> problem persists.
>> thanks
Re: [Announce] PDT 2.0.1 M200901080831 is available [message #89629 is a reply to message #89571] Mon, 12 January 2009 11:01 Go to previous messageGo to next message
If you are unpacking the new PDT into an older PDT all-in-one, you may
have to disable the older features first.
Or better, unpack the new PDT into the same place that the 2.0.0 version
is... put it in eclipse/dropins/, not in eclipse/.
As to determining the installed version of PDT, look at Help > About >
Plugins or Help > Software Updates > Installed Software.
> "Version: 3.4.1
That's the version of Eclipse, not the PDT plugins on top.
> I cant check this correctly.
> Eclipse SDK
> "Version: 3.4.1
>> Thanks!
>>> and Automated Tests, unziped the files in plugins/features folders,
>>> but the problem persists.
>>> thanks
Re: [Announce] PDT 2.0.1 M200901080831 is available [message #89915 is a reply to message #89629] Tue, 13 January 2009 08:09 Go to previous message
I've tried unzip in /eclipse and eclipse/dropins folder, unsuccessful.
I tried to update the plugins in Eclipse, and not working either.
with any chance to work, I create another folder, put the new all in one
there and unzip the new pdt in /eclipse and eclipse/dropins folder. and
now Its working...
Thanks people, for support !
> > "Version: 3.4.1
>> Eclipse SDK
>> "Version: 3.4.1
>>> Thanks!
>>>> thanks
Previous Topic:2.1 Project Plan
Next Topic:PDT 2.0.1 - JS folders
Current Time: Wed Mar 12 17:36:29 EDT 2025
Powered by FUDForum. Page generated in 0.05552 seconds
