Open Declaration in Classes PDT 2RC2 [message #87127] |
Fri, 19 December 2008 05:02  |
Originally posted by: lpiernik.gmail.com
I have may classes and in PDT 1 when I pressed ctrl over name of the
method ex. $Article->read(); I could jump to read declaration.
In PDT 2 I can't
Within a class ex $this->read(); open declaration works fine...
I'm using clean allinone package.
Help
Luke
Re: Open Declaration in Classes PDT 2RC2 [message #88131 is a reply to message #87428] |
Fri, 02 January 2009 06:22  |
I really Can't get to it what is wrong - even in new official 2.0 PDT.
I'll send to You in a private message - normal email - link to my
project. Hope You'll manage to fix it...
Michael Spector pisze:
> If you exclude something from buildpath, you won't see it in code assist.
> Please show some code examples that can be used for reproduction of the
> issue.
> Thanks!
> "Piernik" <lpiernik@gmail.com> wrote in message
> news:gij65g$lgr$1@build.eclipse.org...
>> All classes are listed in PHP Project Outline.
>> I don't know weather this is important:
>> I have 600 errors - mainlly in imported libraries like
>> - fckeditor
>> - pear
>> - phpmailer
>> - sitemapgenerator
>> Can I somehow exclude them from project? Build path->exclude doesn't
>> effect errors:/
>> Piernik pisze:
>>> No - no exceptions.
>>> I've created new perspective - added this project - no exceptions -
>>> default settings. Added linked folder and somehow - few classes worked
>>> correctlly (completion and so on) - but only 2 of 10...
>>> Those classes are build in the same way as others and works in pdt 1
>>> Any ideas ?:)
>>>> Are there any exceptions thrown?
>>>> There should be no difference either you use a small or a big project.
>>>> news:gig0bh$ko8$2@build.eclipse.org...
>>>>> And saying big project I mean 766 php files and 28000 different files
>>>>> (ex photos which are also in project in a subfolder)
>>>>> Piernik pisze:
>>>>>> I've loaded a smaller project and it works in a part:
>>>>>> public function __construct() {
>>>>>> global $Galeria; // no completion
>>>>>> $Galeria->wgraj_obrazek(); //Galeria - no completion but
>>>>>> wgraj_obrazek completion and hover works.
>>>>>> So I think it dosen't work in the big projects.
>>>>>> I have Vista.
>>>>>> As I said before - works great in PDT 1 and I'm useing clear PDT 2 RC2
>>>>>> allinone copy - no changes in preferences and I'm creating project
>>>>>> adding new folders linked to file system
>>>>>> Cheers
>>>>>>> I can't re-create this with PDT 2.0.0 RC2.
>>>>>>> Can you check the following:
>>>>>>> 1. Create new project, and test it there?
>>>>>>> 2. If (1) doesn't work for you, can you switch to another (new)
>>>>>>> workspace, and test it there?
>>>>>>> Thanks for your help!
>>>>>>> news:gifu1q$5eh$1@build.eclipse.org...
>>>>>>>> It's a big project
>>>>>>>> here is a part:
>>>>>>>> artykuly.php file:
>>>>>>>> require('common.php');
>>>>>>>> $Artykuly->pobierz_dane_artykulu($tytul_znaki);
>>>>>>>> $Statystyki->dodaj_odslone($Artykuly->artykul['id_artykulu'],
>>>>>>>> 'art');
>>>>>>>> Hover on $Artykuly works
>>>>>>>> on ->pobierz_dane_artykulu doesn't
>>>>>>>> Hover on $Statystyki works
>>>>>>>> on ->dodaj_odslone doesn't
>>>>>>>> no compltions available (ctrl+spacebar) for $Artykuly,
>>>>>>>> pobierz_dane_artykulu, $Statystyki, dodaj_odslone...
>>>>>>>> common.php file
>>>>>>>> require_once('namiary.php');
>>>>>>>> require_once('config.php');
>>>>>>>> require_once('funkcje/statystyki.class.php');
>>>>>>>> require_once('funkcje/artykuly_relacje.class.php');
>>>>>>>> $Statystyki=new Statystyki(); //hover works
>>>>>>>> $Artykuly = new Artykuly_relacje(); //hover works
>>>>>>>> funkcje/artykuly_relacje.class.php file
>>>>>>>> class Artykuly_relacje {
>>>>>>>> public $artykuly;
>>>>>>>> global $Statystyki; //hover doesn't work
>>>>>>>> $this->artykul=$row; //hover works
>>>>>>>> $Statystyki->dodaj_odslone(); //hover doesn't work
>>>>>>>> public function pobierz_dane_artykulu($id) {
>>>>>>>> //code
>>>>>>>> funkcje/statystyki.class.php file is build in the same way.
>>>>>>>> Hope it will help.
>>>>>>>>> Can you give us some code example?
>>>>>>>>> How $Article variable was declared?
>>>>>>>>> Thanks!
>>>>>>>>> news:gifrg4$oel$1@build.eclipse.org...
>>>>>>>>>> Hi
>>>>>>>>>> the
>>>>>>>>>> In PDT 2 I can't
>>>>>>>>>> Help
>>>>>>>>>> Luke
FUDForum. Page generated in 0.03487 seconds
