Home » Archived » M2M (model-to-model transformation) » [ATL] Using XSD as Metamodel
[ATL] Using XSD as Metamodel [message #869487] Thu, 03 May 2012 13:20 Go to next message
Tex Iano is currently offline Tex IanoFriend
Member
is it possible to use an XSD as metamodel in ATL (programmatically within a Java application) or is it necessary to create an ecore from the XSD?
Tex
Re: [ATL] Using XSD as Metamodel [message #869550 is a reply to message #869487] Thu, 03 May 2012 15:08 Go to previous messageGo to next message
> the XSD?
I don't know if this helps you, but you can do that with QVTo. With QVTo
you can simply load an Xsd using the XsdEcoreBuilder and pass the (then
in-memory Ecore) Model to the engine.
Marius
Re: [ATL] Using XSD as Metamodel [message #869555 is a reply to message #869550] Thu, 03 May 2012 15:23 Go to previous messageGo to next message
Member
And can I do model to model transformations with QVTo? Is it ready for production use or still in early test phases?
I want to transform my model to UML. Here I have the Eclipse UML2. Can I use QVTo for this?
Tex
Re: [ATL] Using XSD as Metamodel [message #869567 is a reply to message #869555] Thu, 03 May 2012 15:50 Go to previous messageGo to next message
Member
Just did my first QVTo transformation. Man this was easy Smile Thanks
Tex
Re: [ATL] Using XSD as Metamodel [message #869582 is a reply to message #869567] Thu, 03 May 2012 16:24 Go to previous messageGo to next message
Member
Unfortunately I am now at the same situation as before:
I have my metamodel as XSD and my instance. I want to perform the transformation from Java directly. And now the problem is: when loading the model with:
		Resource inResource = resourceSet.getResource(
				URI.createURI("samples/testfile.wsdl"), true);
I get the error:
Exception in thread "main" java.lang.RuntimeException: Cannot create a resource for 'samples/testfile.wsdl'; a registered resource factory is needed
Ok, but how to register?
		Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("wsdl",
In order to load the XSD I can use:
		Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("xsd",
			new XSDResourceFactoryImpl());
But I don't have this for my Metamodel (which is wsdl in this case, but could be something more custom). Do I have to generate the Ecore, then GenModel etc.?
Tex
QVTo status (was Re: [ATL] Using XSD as Metamodel) [message #869588 is a reply to message #869555] Thu, 03 May 2012 16:32 Go to previous message
QVTo was developed by Borland and has been useable and stable for a
couple of years.
Since Borland's demise, QVTo has had limited maintenance; sufficient to
keep it in the Eclipse release train.
There are a number of parties with significant interest in QVTo so
expect observable development to pick up again in a year or so, possibly
after a minor internal API hiccough to align with and exploit Xtext and
the automated tooling for the revised UML-aligned implementation of OCL.
Today, if you like QVTo; great. If you have a problem; it's Open Source;
you can fix it or discuss the problem with others.
Contact me if you are interested in participating actively.
Ed Willink
> Regards,
> Tex
Previous Topic:[QVTo] Access qName local part
Next Topic:M2M is moving to MMT
Current Time: Sun Dec 22 06:27:00 GMT 2024
Powered by FUDForum. Page generated in 0.04146 seconds
