Home » Archived » M2M (model-to-model transformation) » References in ATL output
References in ATL output [message #86340] |
Thu, 10 July 2008 21:48 |
kaab Messages: 43 Registered: July 2009 |
Member |
We are trying to generate a KDM file with an STM input for the java
language.
The Transformation output looks good but we had problems setting the
references inside of our output.
We use a function to create PrimitiveTypes :
rule CreatePrimitiveTypes()
to
B : kdm!BooleanType (
name <- 'boolean'
C : kdm!CharType
name <- 'char'
F : kdm!FloatType
name <- 'float'
Fd : kdm!FloatType
name <- 'double'
I : kdm!IntegerType
name <- 'int'
Il : kdm!IntegerType
name <- 'long'
v : kdm!VoidType
name <- 'void'
Vn : kdm!VoidType
name <- 'null'
kdmLanguageUnit : kdm!LanguageUnit(
name <- 'Primitive Java datatypes',
codeElement <- B,
codeElement <- C,
codeElement <- F,
codeElement <- Fd,
codeElement <- I,
codeElement <- Il,
codeElement <- v,
codeElement <- Vn
do
kdmLanguageUnit;
Now we would like to link our generated elements which are Primitve to the
elements created by this rule.
For example :
We have a rule that create Methods parameters :
lazy rule CreateParameters {
from stmConcreteNode : STM!StConcreteNode (
stmConcreteNode.concreteId = 'FieldDeclaration'
to
kdmParameter:kdm!ParameterUnit (
name <-
stmConcreteNode.getParameter('./StConcreteNode[2]/StToken[1] /@image')
type <- ???????? (Need to be linked to boolean)
Right now our output looks like this :
<codeElement xsi:type="code:MethodUnit" name="myMethod1">
<codeElement xsi:type="code:Signature" name="myMethod1">
<parameterUnit name="param"/>
<parameterUnit name="index"/>
<parameterUnit kind="return" type="????"/>
</codeElement>
</codeElement>
And we would like it to look like this :
type="//@model.1/@codeElement.0/@codeElement.3"/>
</codeElement>
</codeElement>
Thanks in advance for your answers,
Re: References in ATL output [message #86364 is a reply to message #86340] |
Fri, 11 July 2008 08:38 |
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Hi Amid,
Hamid Kaab a écrit :
> language. The Transformation output looks good but we had problems
> setting the references inside of our output.
> to
> name <- 'boolean'
> C : kdm!CharType
> name <- 'char'
> F : kdm!FloatType
> name <- 'float'
> Fd : kdm!FloatType
> name <- 'double'
> I : kdm!IntegerType
> name <- 'int'
> name <- 'long'
> v : kdm!VoidType
> name <- 'void'
> Vn : kdm!VoidType
> name <- 'null'
> codeElement <- B,
> codeElement <- C,
> codeElement <- F,
> codeElement <- Fd,
> codeElement <- I,
> codeElement <- Il,
> codeElement <- v,
> codeElement <- Vn
> do
> kdmLanguageUnit;
> the elements created by this rule.
> For example :
> to
> name <-
There are different ways to achieve this.
Using a declarative way (preferable):
* Don't use a called rule like the "CreatePrimitiveTypes()" one to
initiate the basic types but do it in a normal matched rule concerning
the root element of your input model, something like:
rule createKDMModel {
from
root : stm!???
to
m : kdm!KDMModel (
name <- 'boolean'
* Then, you can retrieve from any other matched rule your type by
calling the "resolveTemp" method
type <- thisModule.resolveTemp(rootSTM,'B')
where "rootSTM" is the root element of your STM model
* Note that in order to not make your rules to complicated, you can
create an helper that computes this and then call it each time you need
to get a type
More generally, from a development and maintainability point of view,
it's highly recommended to use as much as possible declarative in your
ATL transformations. By experience, we know that almost all cases have a
declarative solution. Try to limit the use of imperative to very
specific cases where it's really required.
Using an imperative way:
* You can create an helper attribute:
helper def: booleanType : kdm!BooleanType =
OclUndefined;
* You can initialize it in the "do" section of your
"CreatePrimitiveTypes()" called rule:
thisModule.booleanType <- B;
* Finally, you can use in your matched rules (only if you're sure
that the "CreatePrimitiveTypes()" has already been called from an
"entrypoint" called rule for instance):
type <- thisModule.booleanType
> </codeElement>
> </codeElement>
> </codeElement>
> </codeElement>
Hugo
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
http://www.sciences.univ-nantes.fr/lina/atl/
Current Time: Fri Sep 27 04:02:42 GMT 2024
Powered by FUDForum. Page generated in 0.04276 seconds
