installing BPEL designer [message #8570] |
Mon, 25 June 2007 19:06 |
Originally posted by: lario*NOSPAM*.inherit.com
I have followed the directions from http://www.eclipse.org/bpel/install.php.
I checked out and compiled :
a.. org.eclipse.bpel.common.model
b.. org.eclipse.bpel.common.ui
c.. org.eclipse.bpel.model
d.. org.eclipse.bpel.ui
e.. org.eclipse.bpel.runtimes
from :pserver:anonymous@dev.eclipse.org:/cvsroot/technology. I placed the
jars in the plugin directory. I have also loaded WTP (Web Tools Platform)
1.5.x .
When I attemped to open OASISSampleProcess.bpel from the examples, I get the
following error:
"Unable to create this part due to an internal error. Reason for the
failure: The editor class could not be instantiated. This usually indicates
that the editor's class name was mistyped in plug.xml."
I checked the .log file and here is the error:
!ENTRY org.eclipse.osgi 2 0 2007-06-25 13:39:01.953
!MESSAGE The activator org.eclipse.bpel.ui.BPELUIPlugin for bundle
org.eclipse.bpel.ui is invalid
!STACK 0
org.osgi.framework.BundleException: The activator
org.eclipse.bpel.ui.BPELUIPlugin for bundle org.eclipse.bpel.ui is invalid
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
at
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:234)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
at
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:787)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at
org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:243)
at
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:239)
at
org.eclipse.ui.internal.registry.EditorDescriptor.createEdit or(EditorDescriptor.java:231)
at
org.eclipse.ui.internal.EditorManager.createPart(EditorManag er.java:841)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:608)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:422)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
at
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:259)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2639)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2570)
at
org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPag e.java:2562)
at
org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2547)
at
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2542)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2526)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2517)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:644)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:603)
at
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:285)
at
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:138)
at
org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:19 4)
at
org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:17 5)
at
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:268)
at
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:244)
at
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:318)
at
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 5.open(PackageExplorerPart.java:588)
at
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:820)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:850)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:45)
at
org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:15 3)
at
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:818)
at
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1079)
at
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1178)
at
org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
at
org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
at
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
at
org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3673)
at
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3284)
at
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2337)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2301)
at
org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 76)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:463)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:458)
at
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:101)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:146)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:356)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:171)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown
Source)
at
org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 476)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:416)
at org.eclipse.equinox.launcher.Main.run(Main.java:1141)
Caused by: java.lang.ClassNotFoundException:
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:434)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:134)
... 72 more
Root exception:
java.lang.ClassNotFoundException: org.eclipse.bpel.ui.BPELUIPlugin
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Source)
at
!ENTRY org.eclipse.ui 4 0 2007-06-25 13:39:01.968
!MESSAGE Unable to create editor ID org.eclipse.bpel.ui.bpeleditor: The
editor class could not be instantiated. This usually indicates that the
editor's class name was mistyped in plugin.xml.
!STACK 0
java.lang.ClassNotFoundException: org.eclipse.bpel.ui.BPELEditor
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Source)
at
FUDForum. Page generated in 0.04445 seconds
