Eclipse and CVS [message #85474] |
Mon, 11 July 2005 22:04 |
Originally posted by: fsa3.optonline.net
Hi All,
I'm pretty new to using Eclipse. I know CVS can integrate pretty
seemlessly with CVS. However, my situation is that I don't have CVS setup
yet. I'm working on small project (me and 2 others) but we all will be
accessing the source code from at least 2 different PC in different
locations (all of which will have Eclipse). That said it seemed like
setting up CVS+Eclipse was a great way to manage things... Does anyone
have any recommendations for a good/simple/no-frills CVS server for
windows that works well with Eclipse?
Trying to set this up as quickly and painlessly as possible.
Frank
Re: Eclipse and CVS [message #85551 is a reply to message #85474] |
Tue, 12 July 2005 08:47 |
Originally posted by: daniel.megert.gmx.net
Frank A. wrote:
> Hi All,
> setup yet. I'm working on small project (me and 2 others) but we all
> will be accessing the source code from at least 2 different PC in
> different locations (all of which will have Eclipse). That said it
> seemed like setting up CVS+Eclipse was a great way to manage
> things... Does anyone have any recommendations for a
> good/simple/no-frills CVS server for windows that works well with
> Eclipse?
If this is production code I strongly suggest to setup a Linux box to
host your CVS repository. If this is not an option you might consider
http://www.wincvs.org
Dani
> Frank
Re: Eclipse and CVS [message #85605 is a reply to message #85474] |
Tue, 12 July 2005 12:44 |
Originally posted by: cj19841015.hotmail.com
Eclipse itself play a client role and as for the server, cvsnt is not bad
choice.
"Frank A." <fsa3@optonline.net> wrote in message
news:3c35f8465d3585eaa60a13b5194e0a0d$1@www.eclipse.org...
> Hi All,
> Frank
Re: Eclipse and CVS [message #87038 is a reply to message #85474] |
Sat, 16 July 2005 12:41 |
Originally posted by: mailforgilbert.gmx.de
Hi, Frank,
when working on Windows you have to choose cvsnt,
a port from unix to Windows and backported again,
as cvs only runs as client on windows.
But if understand correctly, you're looking for
a server.
When only needing a client the cvs perspective
in eclipse is enough.
We use that in production for some years now,
and it works great.
See -> www.cvsnt.org
BTW, if you start a project that is hosted @ sourceforge
you'll get a cvs repository too.
Regards, Gilbert
Frank A. wrote:
Does anyone
> Frank
Re: Eclipse and CVS [message #87099 is a reply to message #87038] |
Sun, 17 July 2005 02:31 |
Thanks for the replies. I'm all setup with CVSNT on an XP Server.
One question if I have a project that I had started in Eclipse (no CVS)
and now want to add to a CVS repository how should I do that? I can't
seem to figure it out. I figured out how to pull a CVS module into
Eclipse but not vice versa.
THanks
Frank
FUDForum. Page generated in 0.09771 seconds
