Home » Eclipse Projects » Eclipse Platform » How can i add an image to the Editor?
Re: How can i add an image to the Editor? [message #85341 is a reply to message #85128] |
Mon, 30 June 2003 14:18 |
Asaf Messages: 59 Registered: July 2009 |
Member |
You probably ment to Eclipse Marker.
I just copied next text from document:
Platform Plug-in Developer Guide
Programmer's Guide
Hope this is helpful.
Asaf
Resource and workspace API
In Introduction to resources, we saw how resources are represented in the
platform and how they map to files
in the file system. Now that we have built several plug-ins for the
platform, we look again at the resources
API and how you can use it for additional functionality in your plug-in.
The resources API allows you to tag resources with special information, find
out about changes to resources,
implement specialized builders that perform transformations on resources,
and save plug-in specific
information along with a resource.
Resource markers
We know that plug-ins can define specialized file extensions and contribute
editors that provide specialized
editing features for these file types. During the course of editing (or
building) a resource, a plug-in may
need to tag resources to communicate problems or other information to the
user. The resource marker
mechanism is used to manage this kind of information.
A marker is like a yellow sticky note stuck to a resource. On the marker you
can record information about a
problem (e.g., location, severity) or a task to be done. Or you can simply
record a location for a marker as a
bookmark.
Users can quickly jump to the marked location within a resource. The
workbench UI supports presentation of
bookmarks, breakpoints, tasks, and problems along the side of the editor.
These markers can also be shown
as items in views, such as the tasks or bookmarks view.
The platform resources API defines methods for creating markers, setting
marker values, and extending the
platform with new marker types. While the platform manages markers, it is
the plug-ins that control their
creation, removal and attribute values.
Markers are intended to be small, lightweight objects. There could be
hundreds, even thousands of markers in
a single project. For example, the Java compiler uses a marker to flag each
problem it finds in source code.
The platform will throw away markers attached to resources that are deleted,
but plug-ins are responsible for
removing their stale markers when they no longer apply to a resource that
still exists.
Marker operations
Manipulating a marker is similar to manipulating a resource. Markers are
handle objects. You can obtain a
marker handle from a resource, but you don't know if it actually exists
until you use exists() protocol or
otherwise try to manipulate it. Once you've established that a marker
exists, you can find out the resource to
which it belongs, query its id, or query named attributes that may have been
assigned to it.
Markers are owned and managed by the platform, which takes care of making
markers persistent and
notifying listeners as markers are added, deleted, or changed. Plug-ins are
responsible for creating any
necessary markers, changing their attributes, and removing them when they
are no longer needed.
Marker creation
Markers are not directly created using a constructor. They are created using
a factory method
(IResource.createMarker()) on the associated resource.
111
IMarker marker = file.createMarker(IMarker.TASK);
To create a marker that has global scope (not associated with any specific
resource), you can use the
workspace root (IWorkspace.getRoot()) as the resource.
Marker deletion
The code for deleting a marker is straightforward.
try {
marker.delete();
} catch (CoreException e) {
// Something went wrong
When a marker is deleted, its marker object (handle) becomes "stale."
Plug-ins should use the
IMarker.exists() protocol to make sure a marker object is still valid.
Markers can be deleted in batch by asking a resource to delete its markers.
This method is useful when
removing many markers at once or if individual marker references or ids are
not available.
int depth = IResource.DEPTH_INFINITE;
try {
resource.deleteMarkers(IMarker.PROBLEM, true, depth);
// something went wrong
When deleting a group of markers, you specify a marker type to delete, such
as IMarker.PROBLEM, or
null to delete all markers. The second argument indicates whether you want
to delete subtype markers.
(We'll look a subtypes in a moment when we define new marker types.) The
depth argument controls the
depth of deletion.
You can also delete markers using deleteMarkers(IMarker []).
Marker attributes
Given a marker, you can ask for its associated resource, its id (unique
relative to that resource), and its type.
You can also access additional information via generic attributes.
Each type of marker has a specific set of attributes that are defined by the
creator of the marker type using
naming conventions. The IMarker interface defines a set of constants
containing the standard attribute
names (and some of the expected values) for the platform marker types. The
following method manipulates
attributes using the platform constants.
if (marker.exists()) {
try {
marker.setAttribute(IMarker.MESSAGE, "A sample marker message");
marker.setAttribute(IMarker.PRIORITY, IMarker.PRIORITY_HIGH);
// You need to handle the case where the resource doesn't exist
112
Attributes are maintained generically as name/value pairs, where the names
are strings and a value can be any
one of the supported value types (boolean, integer, string). The limitation
on value types allows the platform
to persist the markers quickly and simply.
Querying markers
Resources can be queried for their markers and the markers of their
children. For example, querying the
workspace root with infinite depth considers all of the markers in the
workspace.
IMarker[] problems = null;
try {
problems = resource.findMarkers(IMarker.PROBLEM, true, depth);
The result returned by findMarkers depends on the arguments passed. In the
snippet above, we are looking
for all markers of type PROBLEM that appear on the resource and all of its
direct and indirect descendants.
If you pass null as the marker type, you will get all the marker types
associated with the resource. The second
argument specifies whether you want to look at the resource's children. The
depth of the search when you are looking at the resource's children. The
depth can be DEPTH_ZERO (just
the given resource), DEPTH_ONE (the resource and all of its direct children)
or DEPTH_INFINITE (the
resource and all of its direct and indirect descendants).
Marker persistence
The platform standard markers (task, problem, and bookmark) are persistent.
This means that their state will
be saved across workbench shutdown and startup.
New marker types declared by plug-ins are not persistent unless they are
declared as such.
Extending the platform with new marker types
Plug-ins can declare their own marker types using the
org.eclipse.core.resources.markers extension point.
The standard marker types for problems, tasks and bookmarks are declared by
the platform in the resources
plug-in's markup.
<extension
id="problemmarker"
point="org.eclipse.core.resources.markers"
name="%problemName">
<super type="org.eclipse.core.resources.marker"/>
<persistent value="true"/>
<attribute name="severity"/>
<attribute name="message"/>
<attribute name="location"/>
</extension>
<extension
id="taskmarker"
name="%taskName">
<attribute name="priority"/>
113
<attribute name="done"/>
</extension>
<extension
id="bookmark"
name="%bookmarkName">
</extension>
New marker types are derived from existing ones using multiple inheritance.
New marker types inherit all of
the attributes from their super types and add any new attributes defined as
part of the declaration. They also
transitively inherit attributes from the super types of their super types.
The following markup defines a new
kind of marker in a hypothetical com.example.markers plug-in.
<extension
id="mymarker"
point="org.eclipse.core.resources.markers" />
<extension
id="myproblem"
point="org.eclipse.core.resources.markers">
<super type="org.eclipse.core.resources.problemmarker"/>
<super type="com.example.markers.mymarker"/>
<attribute name="myAttribute" />
<persistent value="true" />
</extension>
Note that the type org.eclipse.core.resources.problemmarker is actually one
of the pre-defined types (aka
IMarker.PROBLEM).
The only aspect of a marker super type that is not inherited is its
persistence flag. The default value for
persistence is false, so any marker type that should be persistent must
specify <persistent value="true"/>.
After declaring the new marker type in your plug-in manifest file, you can
create instances of
com.example.markers.myproblem marker type and freely set or get the
myAttribute attribute.
Declaring new attributes allows you to associate data with markers that you
plan to use elsewhere (in your
views and editors). Markers of a particular type do not have to have values
for all of the declared attributes.
The attribute declarations are more for solving naming convention problems
(so everyone uses "message" to
talk about a marker's description) than for constraining content.
public IMarker createMyMarker(IResource resource) {
try {
IMarker marker = resource.createMarker("com.example.markers.myproblem");
marker.setAttribute("myAttribute", "MYVALUE");
return marker;
// You need to handle the cases where attribute value is rejected
You can query your own marker types in the same way you query the platform
marker types. The method
below finds all mymarkers associated with the given target resource and all
of its descendents. Note that this
will also find all myproblems since true is passed for the includeSubtypes
argument.
114
public IMarker[] findMyMarkers(IResource target) {
String type = "com.example.markers.mymarker";
IMarker[] markers = target.findMarkers(type, true,
IResource.DEPTH_INFINITE);
Tracking resource changes
The resources plug-in includes an event mechanism for notifying interested
parties of changes to resources. If
you need to keep track of changes to the resource tree while your plug-in is
running, you can register an
IResourceChangeListener with the workspace. Your listener will be notified
of the changes via an
IResourceChangeEvent object, which describes the changes.
Resource change processing
To track changes to resources, you must register a resource change listener
with the workspace.
IResourceChangeListener listener = new MyResourceChangeReporter();
ResourcesPlugin.getWorkspace().addResourceChangeListener(
listener, IResourceChangeEvent.POST_CHANGE);
Your listener will be notified after modifications to the workspace
resources have been made. Resource API
methods that modify resources trigger these events as part of their
documented behavior. The method
comment for a resource API method explicitly states whether or not it
triggers a resource change event. For
example, the following is included in the IFile.createContents() comment:
This method changes resources; these changes will be reported in a
subsequent
resource change event, including an indication that this file's content have
been changed.
Methods that create, delete, or change a resource typically trigger these
events. Methods that read, but do not
write, resources typically do not trigger these events.
"Easwar" <easwaran2180@yahoo.co.in> wrote in message
news:bdp1hh$atl$1@rogue.oti.com...
> I do some modifications to the java file then the file is in dirty state.
> In this process i need to add an image (like a flag to state that the file
> is dirty). This is similar to adding an error image when the compilation
> fails.
Current Time: Wed Oct 02 14:52:27 GMT 2024
Powered by FUDForum. Page generated in 0.03493 seconds
