Home » Language IDEs » ServerTools (WTP) » Weblogic 7.0
Weblogic 7.0 [message #84664] Thu, 17 March 2005 14:31 Go to next message
Originally posted by: amol.forums.gmail.com
Is there any way to configure weblogic 7.0 as a server?
I am using WTPM2 but can upgrade to M3 if required.
Re: Weblogic 7.0 [message #85143 is a reply to message #84664] Sat, 19 March 2005 05:03 Go to previous messageGo to next message
Lawrence Mandel is currently offline Lawrence MandelFriend
As far as I know WebLogic 7.0 is not currently supported directly by WTP.
Can someone from the server team confirm this?
Lawrence
Re: Weblogic 7.0 [message #85229 is a reply to message #85143] Sun, 20 March 2005 23:07 Go to previous messageGo to next message
Tim deBoer is currently offline Tim deBoerFriend
Member
That is correct, only WebLogic 8.1 is currently supported (via the generic
server support).
BEA is now involved in WTP, so it will probably fall to them to decide
whether to provide further WebLogic support or keep this within their
product offerings.
Re: Weblogic 7.0 [message #85439 is a reply to message #84664] Mon, 21 March 2005 23:22 Go to previous messageGo to next message
Jeremy Whitlock is currently offline Jeremy WhitlockFriend
Amol,
As of now there is no built in support for Weblogic in the WTP. I
hope to contribute some help to that but until then, here is an Eclipse
plugin that I wrote that is currently on the BEA CodeShare Open Source
Portal:
https://eclipse-plugin.projects.dev2dev.bea.com/
The 1.x branch lets you run Weblogic inside of Eclipse and debug the
applications you have deployed to it. The 2.x branch will do the same but
allow you to do that with multiple servers and will also let you manage
your deployments and such. The 2.x branch will have a lot more features
but those are the main ones. Hope this helps, Jeremy
Re: Weblogic 7.0 [message #85780 is a reply to message #85439] Tue, 22 March 2005 18:14 Go to previous message
Originally posted by: amol.xx.xx
Thanks Jeremy.
I shall definitely try this out and post my experience on your mailing
list.
Previous Topic:javax/wsdl/factory/WSDLFactory not found
Next Topic:Question on Flexible Project Structures
Current Time: Fri Dec 13 00:54:01 GMT 2024
Powered by FUDForum. Page generated in 0.04062 seconds
