Home » Eclipse Projects » WindowBuilder » 2 performance problems with wb.
2 performance problems with wb. [message #827675] Fri, 23 March 2012 12:39 Go to next message
1. I've got a project with ~1000 Panels and ~3000 other java source files. All Panels are filled with custom Textfields. If I open one of the panels and do a right click, it takes around 5 seconds until the context menu shows up. If I move that Panel into its own project, the context menu opens immediately after a right click.
My problem is, that I need the context menu to open the customizer.
Related to that: Would you mind to make it possible to open the customizer with space? Right now, pressing space opens a text editor for the currently selected component so why not open a customizer if one has been defined?
I wanted to see if a new version of window builder fixes the slow context menu which brings me right to problem 2:
2. Loading Panels with a lot of components has become slower with the new version of window builder.
WindowBuilder Version		load time w 90 custom components	load time w 90 JTextFields
1.2.0.r36x201109270310		7s					3s
1.3.0.r36x201202052311		121s					22s
I had to copy my co-workers eclipse configuration to make the comparison because I found no way easy way to switch back to the older version but in both cases, eclipse was started with -Xmx8g and the same workspace.
Is there an update site for the old Version that we can use for now?
[Updated on: Fri, 23 March 2012 12:43] by Moderator
Re: 2 performance problems with wb. [message #827949 is a reply to message #827675] Fri, 23 March 2012 21:46 Go to previous messageGo to next message
Can you provide standalone test case please?
Re: 2 performance problems with wb. [message #827988 is a reply to message #827949] Fri, 23 March 2012 23:20 Go to previous messageGo to next message
Actually you are right, there is new bottleneck.
Fixed in trunk.
New timings for JPanel with 100 JTextFields, in milliseconds on Win7.
Parsing...done: 155
refresh: 138
palette: 13
[Updated on: Fri, 23 March 2012 23:21] by Moderator
Re: 2 performance problems with wb. [message #829535 is a reply to message #827988] Mon, 26 March 2012 08:25 Go to previous messageGo to next message
Thank you for the fast fix. I'll try to look at the trunk as soon as I can.
Re: 2 performance problems with wb. [message #835902 is a reply to message #829535] Tue, 03 April 2012 16:41 Go to previous messageGo to next message
Try the latest build.
Re: 2 performance problems with wb. [message #861586 is a reply to message #835902] Sat, 28 April 2012 12:44 Go to previous message
very good
Previous Topic:How to check is category created in "com.google.gdt.eclipse.designer.wbp-palette.xml"?
Next Topic:VB refugee seeks equivalent to application.doevents()
Current Time: Thu Mar 13 13:54:59 EDT 2025
Powered by FUDForum. Page generated in 0.03492 seconds
