Possible caching issue? [message #823575] |
Sun, 18 March 2012 14:46 |
Barbara Rosi-Schwartz Messages: 448 Registered: July 2009 |
Hello.
As everybody on this forum probably knows by now , I am running a desktop application that runs on top of a Virgo kernel that communicates with a remote Virgo provisioning server for the dynamic download of all bundles that are required by a specific piece of functionality that the user requests via the applications user interface. I invoke the kernel startup command with the "-clean" option.
I am facing a weird, sporadic and difficult to reproduce problem. Most of the time when the user makes her request, everything ticks along nicely. Very occasionally, however, the system downloads the required bundles to the user's PC but, when it tries to activate them, it falls over with a ClassNotFound exception, even though all required bundles (including the one containing the class that is not found) are present locally. If the user stops the application, removes the local kernel's work directory by hand and restarts the application, everything works fine.
When I look at the timestamp of the work directory, it is what I expect it to be, which seems to indicate that the -clean command line argument has worked correctly.
I think (although I am not completely certain) that the problem tends to occur after a new deployment of bundles to the provisioning server (regardless if they are new bundles, with a new version, or updates of existing bundles).
Any idea as to what this might be caused by?
TIA,
B.
Re: Possible caching issue? [message #824092 is a reply to message #823575] |
Mon, 19 March 2012 08:53 |
Glyn Normington Messages: 1222 Registered: July 2009 |
My suspicion is that the output stream of a newly downloaded artefact is not closed before (or strictly speaking, in the correct "happens before" relationship to) its use in the bundle class loader.
I assume you are using the normal Virgo mechanism for downloading and cacheing the remote repository contents. One of the key cache classes is StandardRepositoryCache (in the artefact repository git repo) which uses StandardSingleArtifactCache to cache a specific artefact and its hash. Note that only JARs have hashes computed for them and so only JARs are subject to cacheing. SSAC.refresh downloads the artefact and uses Downloader which in turn uses FileCopyUtils(InputStream, OutputStream) which has the following stream closing logic (apologies for the line numbers - courtesy of OpenGrok):
101 public static int copy(InputStream in, OutputStream out) throws IOException {
102 Assert.notNull(in, "No InputStream specified");
103 Assert.notNull(out, "No OutputStream specified");
104 try {
105 int byteCount = 0;
106 byte[] buffer = new byte[BUFFER_SIZE];
107 int bytesRead = -1;
108 while ((bytesRead = in.read(buffer)) != -1) {
109 out.write(buffer, 0, bytesRead);
110 byteCount += bytesRead;
111 }
112 out.flush();
113 return byteCount;
114 }
115 finally {
116 try {
117 in.close();
118 }
119 catch (IOException ex) {
120 }
121 try {
122 out.close();
123 }
124 catch (IOException ex) {
125 }
126 }
127 }
So if in.close throws an unchecked exception, out.close would not be called. I'm not sure what would cause an unchecked exception in in.close,but that might be an area to explore.
Re: Possible caching issue? [message #824402 is a reply to message #824390] |
Mon, 19 March 2012 16:20 |
What I have already done is I have taken a snapshot of the work directory at the time of a failure, I have then deleted it by hand and restarted the system, which of course has succedeed and created a new work directory. I have then binary compared the jars in the two work dirs, but everything appears to be the same.
Why would deleting the work dir by hand fix the problem anyway???
[Updated on: Mon, 19 March 2012 16:29] Report message to a moderator
FUDForum. Page generated in 0.04425 seconds
