Re: Update resource [message #824153 is a reply to message #824146] |
Mon, 19 March 2012 10:14 |
Ed Merks Messages: 33218 Registered: July 2009 |
Comments below.
On 19/03/2012 11:09 AM, El Shorty wrote:
> Hey everybody,
> I have a little problem, or rather I don't know how to start solving
> it without what I think is a big work around.
> I'm using EMF and working with xml files. I'm trying to get an object
> out the file, edit it and save it back to the file. Wich is not really
> a big problem but right now I load the file, get the object, edit the
> object, delete the original object from the file and save the new one
> to it.
Why not modify the object itself?
> So instead of updating the object I create a new one everytime it edits.
Why? How are you doing this?
> This is no problem aslong as there are like 5-10 objects in the file,
> but I'm guessing that once this builds up, my performance won't be great.
I'd suggest you measure performance and not make assumption.
> Is there like an update method on resource?
No. If you think about it, there's nothing in Java that's lets you
easily write just part of a file. You need to write all the bytes for
the new version.
> I know there is a save and a delete method so I was wondering if there
> was some kind of update aswell.
No.
Ed Merks
Re: Update resource [message #824170 is a reply to message #824153] |
Mon, 19 March 2012 10:47 |
El Shorty Messages: 37 Registered: March 2012 |
Member |
That is what I think I'm doing but when I save it, I add it as a new object so I have to delete the old object, I don't know how to overwrite it. This is what I do:
This gets me the object I select in my tree from a viewer:
Person person = (Person) item;
GroupLabelProvider labelProvider = new GroupLabelProvider();
final IWorkbenchWindow window = PlatformUI.getWorkbench().getActiveWorkbenchWindow();;
IWorkbenchPage page = window.getActivePage();
PersonEditorInput input = new PersonEditorInput(person);
try {
page.openEditor(input, SecondPersonEditor.ID);
} catch (PartInitException e) {
e.printStackTrace();
So this opens my editor with all the properties from this person. Say I edit them than I save it again wich I do by calling the savemethod I worte, I'm guessing that there might be an easier way.
This is what I do in the savemethod:
loadResource = resourceSet.getResource(fileURI, true);
list = loadResource.getContents();
list.add(object);
resource = resourceSet.createResource(fileURI);
resource.getContents().addAll(list);
try {
final Map<Object, Object> saveOptions = new HashMap<Object, Object>();
saveOptions.put(Resource.OPTION_SAVE_ONLY_IF_CHANGED, Resource.OPTION_SAVE_ONLY_IF_CHANGED_MEMORY_BUFFER);
saveOptions.put(XMLResource.OPTION_KEEP_DEFAULT_CONTENT, true);
resource.save(saveOptions);
} catch (IOException e1) {
e1.printStackTrace();
Re: Update resource [message #824212 is a reply to message #824170] |
Mon, 19 March 2012 11:53 |
Comments below.
> overwrite it.
You just modify it and save the resource containing it and that will
write out your changes.
> This is what I do:
> try {
> list.add(object);
You should just save the resource you loaded in the first place.
> try {
> Object>();
Have a look at the generated editor. All it does is save the resources
in the resource set.
Ed Merks
Re: Update resource [message #824213 is a reply to message #824175] |
Yes, it's as easy as that.
On 19/03/2012 11:56 AM, El Shorty wrote:
> I found the solution by using this:
> bryanhunt.wordpress.com/2011/03/15/mongo-emf/
> I didn't know about the eResource option.. All I had to do was instead
> of calling my saveMethod use eResource().save(null)
> I want to thank you for the help ed, especially since that site is
> also made with your help.
Ed Merks
FUDForum. Page generated in 0.04441 seconds
