Re: PDT 1.0.5 release tag in CVS [message #82182 is a reply to message #82112] |
Fri, 17 October 2008 10:47 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: silver.zachara.gmail.com
Andrew Thompson napsal(a):
> As mentioned in another topic, I noticed there is a release tag of PDT
> version 1.0.5 in the CVS repository.
where can I find it ? I can't find any tags of PDT in /cvsroot/tools/or.eclipse.pdt
Re: PDT 1.0.5 release tag in CVS [message #82220 is a reply to message #82193] |
Fri, 17 October 2008 15:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
to Andrew Thompson:
I would like You ask a simple how to compile PDT 1.0.5. Suffice entireliy simple
instructions, I am apprehensive.
Or some instructions with some links how to do this, beacause uncle google is silent ;)
and Java isn't my soapbox.
Thank You for your advice.
Re: PDT 1.0.5 release tag in CVS [message #82271 is a reply to message #82230] |
Fri, 17 October 2008 21:28 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> Of course this guide wouldn't be necissary if Zend was to provide the
> compiled binaries on their download page and update site.
But Zend didn't provide this binaries, they are only in Zend studio for eclipse 6.1 as
org.zend.php.ui_6.1.0.v20080907, etc.....
I will compile PDT 1.0.5, but I want to ask you if don't have compiled PDT 1.0.5. It Would
save me a lot of time and work :(
If not never mind, but let me know pls. ;)
Re: PDT 1.0.5 release tag in CVS [message #82285 is a reply to message #82230] |
Sat, 18 October 2008 13:28 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> Sure,
> You will need to have the eclipse JDT and PDE loaded, along with PDT's
> build depedencies.
> eclipse JDT and PDE runtime binaries
> http://download.eclipse.org/eclipse/downloads/drops/R-3.4.1- 200809111700/index.php
> PDT dependencies
> http://www.eclipse.org/modeling/download.php?file=/modeling/ emf/emf/downloads/drops/2.4.1/R200808251517/emf-runtime-2.4. 1.zip
> http://www.eclipse.org/modeling/download.php?file=/modeling/ emf/emf/downloads/drops/2.4.1/R200808251517/sdo-runtime-2.4. 1.zip
> http://www.eclipse.org/modeling/download.php?file=/modeling/ emf/emf/downloads/drops/2.4.1/R200808251517/xsd-runtime-2.4. 1.zip
> http://www.eclipse.org/downloads/download.php?file=/datatool s/downloads/1.6/dtp_1.6.1.zip
> http://www.eclipse.org/gef/download.php?file=/tools/gef/down loads/drops/3.4.1/R200809101400/GEF-SDK-3.4.1.zip
> http://www.eclipse.org/downloads/download.php?file=/webtools /downloads/drops/R3.0/R-3.0.2-20080921203356/wtp-R-3.0.2-200 80921203356.zip
> These all need to be installed for PDT to compile and run.
> Import all of the CVS checkout's features and plugins as separate projects.
> Open the org.eclipse.php-feature project's feature.xml
> On that page, click the Export link, and give a directory to save the
> results in.
> It should compile all of the plugins for that feature, and you can copy
> them back into your eclipse installation.
I have done exactly what you wrote, but dependecies aren't in accordace with
org.eclipse.php-feature's feature.xml file, in this file is dependece on the
org.eclipse.wst 2.0.0 :
http://img222.imageshack.us/my.php?image=pdt1051gw7.jpg
I clicked "Export wizard", you wrote "Export link" is that right ?:
http://img232.imageshack.us/my.php?image=pdt1052an3.jpg
When I did Export, I got this errors:
http://img396.imageshack.us/my.php?image=pdt1054rg4.jpg
Should I something set up on the option tab on Export dialog ?
http://img147.imageshack.us/my.php?image=pdt1053pd4.jpg
Where am I doing mistake ? (Or what's wrong ?)
I would be very happy and grateful/thankful, if You help me, or if You would be able to
give me some advice.
Thank you
Re: PDT 1.0.5 release tag in CVS [message #82315 is a reply to message #82153] |
Sat, 18 October 2008 15:08 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: codeslave.ca.ibm.com
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=251304 and vote!
Matt Ward wrote:
> Nick Boldt wrote:
>> PDT 1.0.x requires Eclipse 3.3, not 3.4.
> Although this may technically be the official line, this just isn't true
> - 1.0.5 compiles and runs successfully under Ganymede (have been using
> it with no problems 8 hours a day for about a week - in fact I'm fairly
> sure it's more stable than 3.3/1.0.3), and even ignoring that, common
> sense would dictate that this is the version Zend are using for Zend
> Studio (as they must surely be using something?).
> So to repeat Andy's original question, when is, or is, PDT 1.0.5 going
> to be compiled into a download on the PDT download page?
Nick Boldt :: http://wiki.eclipse.org/index.php/User:Nickb
Re: PDT 1.0.5 release tag in CVS [message #82327 is a reply to message #82300] |
Sat, 18 October 2008 19:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> From your pictures I noticed the tag you checked out was
> "Root_R1_0_5_20080723".
> There is another one called "R1_0_5_20080723" which was the one I used.
> Try checking out that one.
I used tag and not branch :) But with R1_0_5_20080723 branch everything works fine and
wihtout problems.
I will trying build PDT 1.0.5 with stables Eclipse Ganymede, thus 3.4.0 and standard tools
in this release.
Im very very happy and glad, that you have helped me and I want very match thank You for
Your time.
Because I can't live to see/wait PDT 2.0.0 and this is also a little compensation.
Re: PDT 1.0.5 release tag in CVS [message #82535 is a reply to message #82327] |
Thu, 23 October 2008 18:49 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: dcarver.starstandard.org
Along these lines there is an effort underway by the community to try
and get an official PDT 1.0.5 maintenance out. Community or Adopter
input would be appreciated:
Dave
> wihtout problems.
> in this release.
> Your time.
FUDForum. Page generated in 0.05317 seconds
