Problems with upgrading from 3.02 to 3.1 [message #81652] |
Wed, 29 June 2005 08:29 |
Originally posted by: seba.rentapacs.de
I am using Eclipse 3.02 (with PHPEclipse) and would like to upgrade to
3.1. So I downloaded the full package, but cannot start it. The
following error stack occurs:
!SESSION 2005-06-29 10:23:35.625
eclipse.buildId=I20050627-1435
java.version=1.5.0_01
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2005-06-29 10:23:36.109
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:367)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Any idea?
thanx
Sebastian
Re: Problems with upgrading from 3.02 to 3.1 [message #81834 is a reply to message #81652] |
Wed, 29 June 2005 18:52 |
Originally posted by: wharley.bea.com
"Sebastian Galonska" <seba@rentapacs.de> wrote in message
news:d9tm0t$oic$1@news.eclipse.org...
> Hello,
> 3.1. So I downloaded the full package, but cannot start it. [...]
Is there any interesting information in the .metadata/.log file?
Also, did you unpack Eclipse 3.1 into a new directory, or on top of your
3.02 install?
Re: Problems with upgrading from 3.02 to 3.1 [message #81848 is a reply to message #81652] |
Wed, 29 June 2005 18:58 |
> Hello,
By the way, there also are some threads on this going on at
eclipse.platform. I haven't seen any answers posted yet, but you might keep
an eye out there.
Re: Problems with upgrading from 3.02 to 3.1 [message #81878 is a reply to message #81834] |
Wed, 29 June 2005 20:56 |
>> Hello,
> 3.02 install?
Are you suppose to unzip it on top of your 3.0.2 directory or into a new
directory? I always have done it in a new directory and had to copy over
the plugins and redo my configuration.
Re: Problems with upgrading from 3.02 to 3.1 [message #82140 is a reply to message #81891] |
Thu, 30 June 2005 07:45 |
Darin Swanson wrote:
> "Peter Costa" <pcosta02@yahoo.com> wrote in message
> news:0631b6a8d3356044ea4abac260562883$1@www.eclipse.org...
>>>>Hello,
>>>3.02 install?
> Good rule of thumb is to never install over top...always into a new
> directory
> HTH
> Darins
I installed it into a new directory, without touching the old one.
Re: Problems with upgrading from 3.02 to 3.1 [message #82375 is a reply to message #82140] |
Thu, 30 June 2005 18:16 |
Originally posted by: chaves-do-not-spam.inf.ufsc.br
It is often the case that people download the Eclipse RCP (SDK or
Runtime), which does not contain any applications, so it cannot be run.
The Eclipse SDK has more than 90 plugins. The Eclipse RCP SDK has less
than 20.
Re: Problems with upgrading from 3.02 to 3.1 [message #87196 is a reply to message #86599] |
Sun, 17 July 2005 21:58 |
Originally posted by: wrewing001.yahoo.com
Yep, many of us made the same mistake.
After downloading the wrong SDK, this is sort of an "other than that, how
did you like the play, Mrs. Lincoln" type of comment, but it seems the RCP
download does have a different/cool icon for eclipse.exe.
FUDForum. Page generated in 0.08649 seconds
