Home » Newcomers » Newcomers » Problems with upgrading from 3.02 to 3.1
Problems with upgrading from 3.02 to 3.1 [message #81652] Wed, 29 June 2005 08:29 Go to next message
Originally posted by: seba.rentapacs.de
I am using Eclipse 3.02 (with PHPEclipse) and would like to upgrade to
3.1. So I downloaded the full package, but cannot start it. The
following error stack occurs:
!SESSION 2005-06-29 10:23:35.625
eclipse.buildId=I20050627-1435
java.version=1.5.0_01
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2005-06-29 10:23:36.109
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:367)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Any idea?
thanx
Sebastian
Re: Problems with upgrading from 3.02 to 3.1 [message #81834 is a reply to message #81652] Wed, 29 June 2005 18:52 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"Sebastian Galonska" <seba@rentapacs.de> wrote in message
news:d9tm0t$oic$1@news.eclipse.org...
> Hello,
> 3.1. So I downloaded the full package, but cannot start it. [...]
Is there any interesting information in the .metadata/.log file?
Also, did you unpack Eclipse 3.1 into a new directory, or on top of your
3.02 install?
Re: Problems with upgrading from 3.02 to 3.1 [message #81848 is a reply to message #81652] Wed, 29 June 2005 18:58 Go to previous messageGo to next message
> Hello,
By the way, there also are some threads on this going on at
eclipse.platform. I haven't seen any answers posted yet, but you might keep
an eye out there.
Re: Problems with upgrading from 3.02 to 3.1 [message #81878 is a reply to message #81834] Wed, 29 June 2005 20:56 Go to previous messageGo to next message
>> Hello,
> 3.02 install?
Are you suppose to unzip it on top of your 3.0.2 directory or into a new
directory? I always have done it in a new directory and had to copy over
the plugins and redo my configuration.
Re: Problems with upgrading from 3.02 to 3.1 [message #81891 is a reply to message #81878] Wed, 29 June 2005 21:17 Go to previous messageGo to next message
Darin Swanson is currently offline Darin SwansonFriend
"Peter Costa" <pcosta02@yahoo.com> wrote in message
news:0631b6a8d3356044ea4abac260562883$1@www.eclipse.org...
> >> Hello,
> > 3.02 install?
Good rule of thumb is to never install over top...always into a new
directory
HTH
Darins
Re: Problems with upgrading from 3.02 to 3.1 [message #82140 is a reply to message #81891] Thu, 30 June 2005 07:45 Go to previous messageGo to next message
>>>>Hello,
>>>3.02 install?
> directory
> HTH
> Darins
I installed it into a new directory, without touching the old one.
Re: Problems with upgrading from 3.02 to 3.1 [message #82375 is a reply to message #82140] Thu, 30 June 2005 18:16 Go to previous messageGo to next message
Originally posted by: chaves-do-not-spam.inf.ufsc.br
It is often the case that people download the Eclipse RCP (SDK or
Runtime), which does not contain any applications, so it cannot be run.
The Eclipse SDK has more than 90 plugins. The Eclipse RCP SDK has less
than 20.
Re: Problems with upgrading from 3.02 to 3.1 [message #86599 is a reply to message #82375] Thu, 14 July 2005 18:51 Go to previous messageGo to next message
Originally posted by: al.mantei.com
I can confirm that using the RCP-SDK rather than the full (100meg plus)
SDK will give you this exact error. Happened to me...
Re: Problems with upgrading from 3.02 to 3.1 [message #87196 is a reply to message #86599] Sun, 17 July 2005 21:58 Go to previous message
Originally posted by: wrewing001.yahoo.com
Yep, many of us made the same mistake.
After downloading the wrong SDK, this is sort of an "other than that, how
did you like the play, Mrs. Lincoln" type of comment, but it seems the RCP
download does have a different/cool icon for eclipse.exe.
Previous Topic:JDK 1.5
Next Topic:How to make a TableViewer with not Top-Down but Left-Right pattern?
Current Time: Fri Aug 30 08:20:28 GMT 2024
Powered by FUDForum. Page generated in 0.10123 seconds
