Re: Birt Viewer Limits Results to 500 records [message #797788 is a reply to message #797738] |
Mon, 13 February 2012 22:13 |
In the deployed viewer there should be no limit unless you explicitly
set it with the:
<!-- Preview report rows limit. An empty value means no limit. -->
<context-param>
<param-name>BIRT_VIEWER_MAX_ROWS</param-name>
<param-value></param-value>
</context-param>
In web.xml
or if you add __maxrows=500 to the url that runs the report.
Jason
On 2/13/2012 4:21 PM, Shane Allred wrote:
> In my eclipse BIRT designer I have figured out how to show all the
> records. However, when I deploy the report to our BIRT viewer the
> results are truncated at 500 records. Is there some setting in the
> Tomcat Viewer to disable this limitation? I am running 3.7 of the
> designer and viewer.
> Thanks
Re: Birt Viewer Limits Results to 500 records [message #797789 is a reply to message #797785] |
Mon, 13 February 2012 22:14 |
If you leave this blank the default should be all rows.
On 2/13/2012 5:13 PM, Shane Allred wrote:
> I figured this one out. The web.xml needed to be changed:
> <context-param>
> <param-value>100000</param-value>
> </context-param>
FUDForum. Page generated in 0.02115 seconds
