Home » Eclipse Projects » GEF » Draw2D Resize Question
Re: Draw2D Resize Question [message #80719 is a reply to message #80656] |
Fri, 23 May 2003 14:31 |
"Eric Bordeau" <ebordeau@us.ibm.com> wrote in message
news:bal83v$itj$1@rogue.oti.com...
> You want the container figure to be its preferred size (not maximum size)
and
> this can be done by setting the container figure's size to -1, -1. This
By size, Eric means its constraint's size, not its bounds. You should never
call setBounds unless you are writing a layout manager.
So:
Figure container = new Figure();
container.setLayoutManager(new XYLayoutManager());
Figure childWithLabels = new Figure();
container.add(childWithLabels, new Rectangle (x, y, -1, -1));
> indicates to the layout manager that its preferred size should be used
(just big
> enough to fit all of its children, plus borders and insets). Not all
layout
> managers care about preferred size, though. If your container figure's
children
> are layed out using XYLayout, setting the container's size to -1, -1 will
do
> nothing. Some *only* care about preferred size. In the logic example, if
you
> place a flow figure inside of another flow figure, the inner figure will
> automatically be at its preferred size.
> Eric
> Justin Kilimnik wrote:
> > I might be missing something simple here but I want to be responsible
for
> > the location of Figure but I want that Figure to be as large as all of
the
> > figures placed inside it. For instance if I place 10 labels in vertical
flow
> > layout I want to be able to see all of the labels (ie the Figure is
large
> > enought to encapsulate all the label). How do I do this? The
functionality
> > doesn't seem to be there but I would expect the maximum size to be set
> > automatically to show all of the items I placed in...
> > Should use the DelegatingLayout? How?
> > Thanks
Re: Draw2D Resize Question [message #80855 is a reply to message #80719] |
Fri, 23 May 2003 15:29 |
Eric Bordeau Messages: 259 Registered: July 2009 |
> and
Sorry, I should've worded my reply better. Thanks, Randy.
> So:
> (just big
> layout
> children
> do
> you
>>Eric
> for
> the
> flow
> large
> functionality
>>>Thanks
Re: Draw2D Resize Question [message #80918 is a reply to message #80719] |
Tue, 27 May 2003 02:47 |
Justin Kilimnik Messages: 12 Registered: July 2009 |
Cannot seem to get it to work. What I have is a XYLayout (I want to pin the
X,Y coords but make the Figure grow to everything that is inside it). I add
the items to a figure inside a scroll pane by using:
getContentsFigure().add(item, new Rectangle(x, y, -1, -1));
The item is a Figure, with FlowLayout, and labels added one after another
using the standard add command.
The figure is only large enough to see the first label. How can I fix
this????
Thanks.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:balbbq$o17$1@rogue.oti.com...
size)
> and
never
> So:
> (just big
> layout
> children
will
> do
if
> you
> > Eric
> for
> the
vertical
> flow
> large
> functionality
> > > Thanks
Re: Draw2D Resize Question [message #80930 is a reply to message #80918] |
Tue, 27 May 2003 06:41 |
Have got it working now, the only problem now is now you cannot drag with
the mouse (ie set the bounds) of the figure when using XYLayout. Is there a
way around this.
Also, when drawing on the canvas like this, what is the best way to make the
ScollPane expand/contract the size of the Figure?
"Justin Kilimnik" <justink@au.ibm.com> wrote in message
news:baujkc$2i8$1@rogue.oti.com...
the
add
> this????
> Thanks.
> size)
> > and
This
> never
> > So:
> > (just big
> > layout
figure's
> > children
> will
> > do
example,
> if
> > you
will
> > > Eric
responsible
> > for
of
> > the
> vertical
> > flow
> > large
> > functionality
set
> > > > Thanks
Re: Draw2D Resize Question [message #80947 is a reply to message #80930] |
Tue, 27 May 2003 06:43 |
Got that working now! Just needed to change the Constraint information.
Sorry for your time.
news:bav1a1$9pa$1@rogue.oti.com...
a
> way around this.
the
> the
> add
another
> > this????
> > Thanks.
> > size)
> > > and
> This
> > never
> > > So:
used
> > > (just big
all
> > > layout
> figure's
> > > children
> > will
> > > do
> example,
> > if
> > > you
> will
> > > > Eric
> responsible
> > > for
all
> of
> > > the
> > vertical
> > > flow
is
> > > large
> > > functionality
> set
> > > > > Thanks
Re: Draw2D Resize Question [message #80990 is a reply to message #80947] |
Tue, 27 May 2003 11:09 |
Originally posted by: frankc.colconsulting.com
Can you tell us what you did to solve these things?
Appreciated,
Frank V. Castellucci
news:bav1f4$9s6$1@rogue.oti.com...
information.
with
there
> a
> > way around this.
make
> the
to pin
> > the
it). I
> > add
> another
fix
> > > this????
> > > Thanks.
maximum
> > > size)
> > > > and
to -1, -1.
> > This
should
> > > never
> > > > So:
be
> used
> > > > (just big
Not
> all
> > > > layout
> > figure's
> > > > children
to -1, -1
> > > will
> > > > do
> > example,
> > > if
> > > > you
figure
> > will
> > > > > Eric
> > responsible
> > > > for
as
> all
> > of
> > > > the
in
> > > vertical
> > > > flow
Figure
> is
> > > > large
> > > > functionality
to be
> > set
> > > > > > Thanks
Current Time: Sun Nov 03 12:04:22 GMT 2024
Powered by FUDForum. Page generated in 0.04022 seconds
