Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] single ref table for many-to-many
Re: [Teneo] single ref table for many-to-many [message #79368 is a reply to message #79354] |
Wed, 11 April 2007 17:39 |
Mark Geib Messages: 432 Registered: July 2009 |
Martin,
Did this. But I see no difference in the mapping file after re-generating.
In the ecore file I find the following:
<eStructuralFeatures xsi:type="ecore:EReference" name="services"
upperBound="-1"
eType="#//Service" eOpposite="#//Service/contacts">
<eAnnotations source="teneo.jpa">
<details key="appinfo" value="@ManyToMany(indexed=false)"/>
</eAnnotations>
</eStructuralFeatures>
and...
<eStructuralFeatures xsi:type="ecore:EReference" name="contacts"
upperBound="-1"
eType="#//Contact" eOpposite="#//Contact/services">
</eAnnotations>
but the mapping file contains
<list name="services" lazy="true"
cascade="merge,persist,save-update,lock,refresh" table="`contact_service`">
<key update="true">
<column name="`contact_e_id`" not-null="true" unique="false"/>
</key>
<list-index column="`contact_services_idx`"/>
<many-to-many entity-name="Service" unique="false">
<column name="`service_e_id`" not-null="true" unique="false"/>
</many-to-many>
</list>
and ...
<list name="contacts" lazy="true"
cascade="merge,persist,save-update,lock,refresh" table="`service_contact`">
<key update="true">
</key>
<list-index column="`service_contacts_idx`"/>
<many-to-many entity-name="Contact" unique="false">
</many-to-many>
</list>
Which looks like two tables will be used as before.
Mark.
Re: [Teneo] single ref table for many-to-many [message #79383 is a reply to message #79368] |
Wed, 11 April 2007 17:48 |
Mark,
Did you regenerate the java source code? This is required after an ecore change (the ecore is not
read from the ecore file but from the runtime generated EPackage class).
gr. Martin
Mark wrote:
> Martin,
> upperBound="-1"
> </eAnnotations>
> and...
> upperBound="-1"
> </eAnnotations>
> <key update="true">
> unique="false"/>
> </key>
> unique="false"/>
> </many-to-many>
> </list>
> and ...
> <key update="true">
> unique="false"/>
> </key>
> unique="false"/>
> </many-to-many>
> </list>
> Mark.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] single ref table for many-to-many [message #604615 is a reply to message #79354] |
Martin,
upperBound="-1"
</eAnnotations>
and...
upperBound="-1"
</eAnnotations>
<key update="true">
</key>
</many-to-many>
</list>
and ...
<key update="true">
</key>
</many-to-many>
</list>
Mark.
Re: [Teneo] single ref table for many-to-many [message #604620 is a reply to message #79368] |
Mark,
gr. Martin
Mark wrote:
> Martin,
> upperBound="-1"
> </eAnnotations>
> and...
> upperBound="-1"
> </eAnnotations>
> <key update="true">
> unique="false"/>
> </key>
> unique="false"/>
> </many-to-many>
> </list>
> and ...
> <key update="true">
> unique="false"/>
> </key>
> unique="false"/>
> </many-to-many>
> </list>
> Mark.
The Netherlands
Current Time: Sat Nov 09 05:06:17 GMT 2024
Powered by FUDForum. Page generated in 0.05756 seconds
