Re: [ATL] Feature ... is not changeable [message #789126 is a reply to message #789116] |
Thu, 02 February 2012 16:22 |
Ed Willink Messages: 7665 Registered: July 2009 |
Cross-resource containment is a different issue. I think it's normally
disabled because it's expensive but you can enable it when you genmodel.
However the message may indicate something nastier like putting an input
element ion an output resource. I've never been able to understand ATL
so I cannot help you on ATL-specific subtleties.
Ed Willink
On 02/02/2012 16:12, st oehm wrote:
> Edward Willink wrote on Thu, 02 February 2012 04:52
>> Hi
>> The UML meta-model has a variety of subset properties and generally
>> you can only change one of them.
>> I suggest checking that you add to the container from which the
>> subsets are built.
>> Regards
>> Ed Willink
> Hi Ed,
> thanks for your answer. But i think i dont get it.
> Now i've tried it that way:
> rule Class2Class {
> from
> jClassDeclaration : JAVA!ClassDeclaration,
> jClassModifier : JAVA!Modifier (
> jClassDeclaration.modifier = jClassModifier
> to
> umlClass : UML!Class (
> name <- jClassDeclaration.name,
> package <- jClassDeclaration.package,
> visibility <- jClassModifier.getVisibility(),
> isAbstract <- jClassModifier.isAbstract(),
> isLeaf <- jClassModifier.isFinal(),
> -- isActive <-
> -- elementImport <- -- packageImport <-
> -- clientDependency <-
> -- nestedClassifier <- -- ownedOperation <-
> ownedAttribute <-
> jClassDeclaration.bodyDeclarations->select(e |
> e.oclIsKindOf(JAVA!FieldDeclaration))
> -- ownedConnector <- -- ownedPort <-
> -- generalization <-
> -- general <-
> -- interfaceRealization <-
> -- superClass <- jClassDeclaration.superClass.type
> -- _ <- jClassDeclaration.superInterfaces
> But I always get the warning "Cannot set feature ownedAttribute to
> value ... containment references cannot span across models."
> I don't know whats the Problem with that transformation. In an other
> transformation I do it that way: packagedElement <-
> jPackage.ownedElements and that works fine.
FUDForum. Page generated in 0.04257 seconds
