More Action Enablement [message #78049] |
Wed, 18 June 2003 19:15 |
Originally posted by: luis_benitez.us.ibm.com
Hi all,
I'm new to eclipse and I'm trying to figure out action enablement. I'm
contributing an action via the plug-in.xml as part of an ActionSet. The
class is set to be a implementation of IWorkbenchWindowActionDelegate. I
want to set the action enablement through code. I thought the best way to
do this was through IWorkbenchWindowActionDelegate.selectionChanged(IAction,
ISelection). When is that method called? What kind of selections trigger
this event? How can I trigger this event?
Ideally that method will look like:
public void selectionChanged(IAction, ISelection) {
if ( action.getId().equals("com.ibm.myaction") )
if ( ISelection instanceof IStructuredSelection )
if ( selection.isEmpty() )
action.setEnabled(false);
else
action.setEnabled(true);
In my case, I have a perspective that has a tree viewer. I want the action
enablement to be based on a selection of the tree viewer. How do I do this?
Do I have to register the action delegate as TreeSelectionChangedListener???
I've looked through the articles and the newsgroups and I haven't been able
to find any relevant info. Sorry if this is a duplicate.
-Luis
PS. I'm using Eclipse 2.1
Re: More Action Enablement [message #78095 is a reply to message #78049] |
Wed, 18 June 2003 21:53 |
--- Don't do getID test. It is not necessary. It will be for your action.
> else
First look up the help on ActionSet. It is better to try to do as much
of the enablement testing through the plugin.xml as possible. That way
your plugin won't get activated unless it actually needs to.
Look in Help->Platform Plugin Developer's Guide->Reference->Extension
Points->Workbench->org.eclipse.ui.actionSets
For example, the above test you wrote can be done in the plugin.xml by
using enablesFor="+" which means enable for one or more selected items.
Also important is <selection> element. This is used to determine whether
to be enabled for what kinds of selections. For example, if you only
want to be enabled when IProject's are selected, you would use
<action
<selection class="org.eclipse.core.resources.IProject"/>
</action>
You would use element <enablement> if it is more complicated than just
the type of the selection and the number selected.
However, after it loads your delegate once, then whenever is selection
is changed you will receive the selectionChanged notification and you
must set the enablement there if it is more complicated then what the
plugin.xml can give you.
However don't test the action.getId(). It will be for your action, that
is guarenteed.
Thanks, Rich Kulp
Re: More Action Enablement [message #78108 is a reply to message #78095] |
Wed, 18 June 2003 22:15 |
Hi Rich, thanks for the quick response.
When I added ' enablesFor="1" ' to my plugin.xml, the action is always
disabled. Here's the definition:
<action
label="%menu.selected.addEvent"
icon="icons/Toolbar/Enabled/AddEvent.bmp"
tooltip="%tooltip.addEvent"
class="com.myplugin.actions.SelectedActions"
menubarPath="selectedMenu/addEvent"
toolbarPath="addEvent"
disabledIcon="icons/Toolbar/Disabled/AddEvent.bmp"
id="com.myplugin.actions.AddEventAction"
enablesFor="1">
<selection class="org.eclipse.jface.viewers.IStructuredSelection"/>
</action>
</actionSet>
No matter what I select in my tree viewer, the action is always disabled.
Any ideas ?
-Luis
"Richard L. Kulp" <richkulp@NOSPAM.us.ibm.com> wrote in message
news:bcqn39$jpg$1@rogue.oti.com...
action.
> > else
> <action
> </action>
> is guarenteed.
> Thanks, Rich Kulp
Re: More Action Enablement [message #78784 is a reply to message #78108] |
Thu, 19 June 2003 22:16 |
Originally posted by: knut_radloff.oti.com
"Luis Benitez" <luis_benitez@us.ibm.com> wrote in message news:bcqoc8$kjv$1@rogue.oti.com...
> enablesFor="1">
selection class has to be an element class. E.g., IFile, IProject.
Or you can omit it if you don't care about the kind of selected element and just specify enablesFor.
Knut
FUDForum. Page generated in 0.03862 seconds
