Keyboard Cut, Copy & Paste [message #78585] |
Thu, 19 June 2003 18:19 |
Originally posted by: gino.--no-spam--filicetti.net
Hi All,
My plugin has a multi page editor which complex UI in each tab.. by complex
UI, I mean that each tab is pretty much a form with a host of text fields
that need to be filled out.
Now my problem... I can't seem to use Ctrl-C,X or V nor use the Edit menu to
cut copy and paste out of the textfields in my multi page editor. It DOES
allow me to right click and cut, copy, paste, but for some reason, the Edit
menu and its keyboard accelerators are disabled.
It feels like I'm missing a critical piece of plumbing that needs to be
hooked up... does anyone have ideas?
G - using Eclipse 2.0.2
PS.. I just noticed that the plugin.xml has the SAME problems as me... that
DOESN'T give me a good feeling ;-(
Re: Keyboard Cut, Copy & Paste [message #78738 is a reply to message #78585] |
Thu, 19 June 2003 21:37 |
Originally posted by: knut_radloff.oti.com
Try using 2.1. I'm using the 20030611 3.0 stream build and the keyboard shortcuts work for cut/paste in the plugin schema editor.
2.1 has a new key binding story which probably fixed this. See the (new) org.eclipse.ui.commands extension point for details.
Knut
"G. Filicetti" <gino@--no-spam--filicetti.net> wrote in message news:bcsusg$aio$1@rogue.oti.com...
> Hi All,
Re: Keyboard Cut, Copy & Paste [message #78913 is a reply to message #78738] |
Fri, 20 June 2003 02:24 |
See.... that's the problem... we're developing this plugin for use in the
new WSAD v5.. which is based on Eclipse 2.0.2, so don't have a choice as to
my version.
Was getting this working actually impossible in 2.0.2?
G
"Knut Radloff" <knut_radloff@oti.com> wrote in message
news:bctaf2$kcl$1@rogue.oti.com...
> Knut
> > Hi All,
complex
fields
menu to
DOES
Edit
that
FUDForum. Page generated in 0.03527 seconds
