Home » Eclipse Projects » EclipseLink » NPE in registerObjectForMergeCloneIntoWorkingCopy
NPE in registerObjectForMergeCloneIntoWorkingCopy [message #786132] Mon, 30 January 2012 02:41 Go to next message
Geoff Capper is currently offline Geoff CapperFriend
I'm using GF 3.1.1 which contains EclipseLink 2.3.0.
When I attempt to perform a merge I'm getting a NullPointerException at line 900 in MergeManager.registerObjectForMergeCloneIntoWorkingCopy.
The line in the source is:
Object primaryKey = descriptor.getObjectBuilder().extractPrimaryKeyFromObject(clone, unitOfWork, true);
There is no further line in the stacktrace so I assume that descriptor is null. Descriptor is set on the previous line in the sources as:
ClassDescriptor descriptor = unitOfWork.getDescriptor(clone.getClass());
Is there any way to determine what is causing this? I'm guessing I might be missing an entity class. Is that so?
Geoff
Re: NPE in registerObjectForMergeCloneIntoWorkingCopy [message #786516 is a reply to message #786132] Mon, 30 January 2012 14:22 Go to previous messageGo to next message
Chris Delahunt is currently offline Chris DelahuntFriend
Can you upload the full stack trace? You should also turn on logging to see if there are any messages that might show what is causing the problem.
Best Regards,
Chris
Re: NPE in registerObjectForMergeCloneIntoWorkingCopy [message #786521 is a reply to message #786132] Mon, 30 January 2012 14:22 Go to previous messageGo to next message
Best Regards,
Chris
Re: NPE in registerObjectForMergeCloneIntoWorkingCopy [message #786889 is a reply to message #786516] Mon, 30 January 2012 23:18 Go to previous messageGo to next message
The full stack trace is below. The "api.exceptions.ExceptionProxy" class is a wrapper around an EJBException to facilitate transport by Hessian.
SEVERE: null
at com.sun.ejb.containers.BaseContainer.processSystemException(BaseContainer.java:5193)
at com.sun.ejb.containers.BaseContainer.completeNewTx(BaseContainer.java:5091)
at com.sun.ejb.containers.BaseContainer.postInvokeTx(BaseContainer.java:4879)
at com.sun.ejb.containers.BaseContainer.postInvoke(BaseContainer.java:2039)
at com.sun.ejb.containers.BaseContainer.postInvoke(BaseContainer.java:1990)
at com.sun.ejb.containers.EJBLocalObjectInvocationHandler.invoke(EJBLocalObjectInvocationHandler.java:222)
at com.sun.ejb.containers.EJBLocalObjectInvocationHandlerDelegate.invoke(EJBLocalObjectInvocationHandlerDelegate.java:88)
at $Proxy223.persist(Unknown Source)
at server.servlet.DAOServlet.persist(DAOServlet.java:49)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at com.caucho.hessian.server.HessianSkeleton.invoke(HessianSkeleton.java:306)
at com.caucho.hessian.server.HessianSkeleton.invoke(HessianSkeleton.java:202)
at com.caucho.hessian.server.HessianServlet.invoke(HessianServlet.java:389)
at com.caucho.hessian.server.HessianServlet.service(HessianServlet.java:369)
at org.apache.catalina.core.StandardWrapper.service(StandardWrapper.java:1539)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:281)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
at org.apache.catalina.core.StandardPipeline.doInvoke(StandardPipeline.java:655)
at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:595)
at com.sun.enterprise.web.WebPipeline.invoke(WebPipeline.java:98)
at com.sun.enterprise.web.PESessionLockingStandardPipeline.invoke(PESessionLockingStandardPipeline.java:91)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:162)
at org.apache.catalina.connector.CoyoteAdapter.doService(CoyoteAdapter.java:330)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:231)
at com.sun.enterprise.v3.services.impl.ContainerMapper.service(ContainerMapper.java:174)
at com.sun.grizzly.http.ProcessorTask.invokeAdapter(ProcessorTask.java:828)
at com.sun.grizzly.http.ProcessorTask.doProcess(ProcessorTask.java:725)
at com.sun.grizzly.http.ProcessorTask.process(ProcessorTask.java:1019)
at com.sun.grizzly.http.DefaultProtocolFilter.execute(DefaultProtocolFilter.java:225)
at com.sun.grizzly.DefaultProtocolChain.executeProtocolFilter(DefaultProtocolChain.java:137)
at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:104)
at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:90)
at com.sun.grizzly.http.HttpProtocolChain.execute(HttpProtocolChain.java:79)
at com.sun.grizzly.ProtocolChainContextTask.doCall(ProtocolChainContextTask.java:54)
at com.sun.grizzly.SelectionKeyContextTask.call(SelectionKeyContextTask.java:59)
at com.sun.grizzly.ContextTask.run(ContextTask.java:71)
at com.sun.grizzly.util.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:532)
at com.sun.grizzly.util.AbstractThreadPool$Worker.run(AbstractThreadPool.java:513)
at java.lang.Thread.run(Thread.java:619)
Caused by: api.exceptions.ExceptionProxy
at org.eclipse.persistence.internal.sessions.MergeManager.registerObjectForMergeCloneIntoWorkingCopy(MergeManager.java:900)
at org.eclipse.persistence.internal.sessions.MergeManager.mergeChangesOfCloneIntoWorkingCopy(MergeManager.java:500)
at org.eclipse.persistence.internal.sessions.MergeManager.mergeChanges(MergeManager.java:271)
at org.eclipse.persistence.mappings.ObjectReferenceMapping.mergeIntoObject(ObjectReferenceMapping.java:464)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.mergeIntoObject(ObjectBuilder.java:3444)
at org.eclipse.persistence.internal.sessions.MergeManager.mergeChangesOfCloneIntoWorkingCopy(MergeManager.java:533)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.mergeCloneWithReferences(UnitOfWorkImpl.java:3487)
at org.eclipse.persistence.internal.sessions.RepeatableWriteUnitOfWork.mergeCloneWithReferences(RepeatableWriteUnitOfWork.java:376)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.mergeCloneWithReferences(UnitOfWorkImpl.java:3447)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.mergeInternal(EntityManagerImpl.java:486)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.merge(EntityManagerImpl.java:463)
at com.sun.enterprise.container.common.impl.EntityManagerWrapper.merge(EntityManagerWrapper.java:286)
at server.ejb.DAOBean.persist(DAOBean.java:185)
at org.glassfish.ejb.security.application.EJBSecurityManager.runMethod(EJBSecurityManager.java:1052)
at org.glassfish.ejb.security.application.EJBSecurityManager.invoke(EJBSecurityManager.java:1124)
at com.sun.ejb.containers.BaseContainer.invokeBeanMethod(BaseContainer.java:5366)
at com.sun.ejb.EjbInvocation.invokeBeanMethod(EjbInvocation.java:619)
at com.sun.ejb.containers.interceptors.AroundInvokeChainImpl.invokeNext(InterceptorManager.java:800)
at com.sun.ejb.EjbInvocation.proceed(EjbInvocation.java:571)
at com.sun.ejb.containers.interceptors.SystemInterceptorProxy.doAround(SystemInterceptorProxy.java:162)
at com.sun.ejb.containers.interceptors.SystemInterceptorProxy.aroundInvoke(SystemInterceptorProxy.java:144)
at sun.reflect.GeneratedMethodAccessor598.invoke(Unknown Source)
at com.sun.ejb.containers.interceptors.AroundInvokeInterceptor.intercept(InterceptorManager.java:861)
at com.sun.ejb.containers.interceptors.InterceptorManager.intercept(InterceptorManager.java:370)
at com.sun.ejb.containers.BaseContainer.__intercept(BaseContainer.java:5338)
at com.sun.ejb.containers.BaseContainer.intercept(BaseContainer.java:5326)
at com.sun.ejb.containers.EJBLocalObjectInvocationHandler.invoke(EJBLocalObjectInvocationHandler.java:214)
... 36 more
Re: NPE in registerObjectForMergeCloneIntoWorkingCopy [message #786892 is a reply to message #786516] Mon, 30 January 2012 23:18 Go to previous messageGo to next message
SEVERE: null
... 36 more
Re: NPE in registerObjectForMergeCloneIntoWorkingCopy [message #787067 is a reply to message #786892] Tue, 31 January 2012 05:37 Go to previous message
Seems this is related to a deeper issue to do with passing null values into the system, so can be ignored... Thanks for looking anyhow!
Re: NPE in registerObjectForMergeCloneIntoWorkingCopy [message #787071 is a reply to message #786892] Tue, 31 January 2012 05:37 Go to previous message
Previous Topic:update in new transaction hangs program
Next Topic:EclipseLink weaving fragment require-bundle version
Current Time: Thu Dec 26 10:17:33 GMT 2024
Powered by FUDForum. Page generated in 0.03678 seconds
