Home » Eclipse Projects » GEF » Layout of figures in an editpart
Layout of figures in an editpart [message #78242] |
Wed, 07 May 2003 09:16 |
Originally posted by: j.verschoor.nefli.nl
Hello
I've create an editpart that has a number of child editparts.
The parent editpart creates a figure that extends from a rectanglefigure and
adds a label in top of the rectangle.
The child figures should be inside the parent, and aligned right, right
under the parentlabel:
| Label |
| child |
| child |
| child |
My problem is that I can't get the positioning / alignment done properly. I
get something that looks like:
| child |
| child |
| child |
| Label |
If somone could tell me where I should specify the layout, I'd appreciate
it.
Thanks.
Re: Layout of figures in an editpart [message #78352 is a reply to message #78242] |
Wed, 07 May 2003 15:43 |
The children cannot have other sibling figures like the label you describe.
You need to create a "contents pane" figure for containing the children:
| Label |
| | child| |
| | child| |
For the outer-most figure, use a ToolbarLayout
For the contents pane, use a ToolbarLayout, with
setMinorAlignment(ToolbarLayout.ALIGN_BOTTOMRIGHT)
"Joris Verschoor" <j.verschoor@nefli.nl> wrote in message
news:b9aiod$na9$1@rogue.oti.com...
> Hello
and
> | Label |
> | child |
> | child |
> | child |
I
> | child |
> | child |
> | child |
> | Label |
> it.
> Thanks.
Re: Layout of figures in an editpart [message #78446 is a reply to message #78431] |
Wed, 07 May 2003 19:33 |
see LabelAnchor
"Stefan Junsved" <stefan.junsved@comactivity.net> wrote in message
news:b9blvs$llb$1@rogue.oti.com...
> I have a question relating to figure use.
> I use a org.eclipse.draw2d.Label figure with a text on the top and an
> under it. I put source and target anchors on the figure but when the text
is
> wider than the image, the anchors don't reach all the way to the imgae.
> Instead they start and end at the width of the text. See attached file.
> Should I use some kind of decorator to solve the problem or is it possible
> to create one Label without an image and an ImageFigure and try to connect
> to two?
> Thanks.
> "Randy Hudson" <none@us.ibm.com> wrote in message
> news:b9b9ic$agq$1@rogue.oti.com...
> describe.
> > | Label |
> > | | child| |
> > | | child| |
> > > Hello
rectanglefigure
> > and
right
> > > | Label |
> > > | child |
> > > | child |
> > > | child |
> properly.
> > I
> > > | child |
> > > | child |
> > > | child |
> > > | Label |
> appreciate
> > > it.
> > > Thanks.
Re: Layout of figures in an editpart [message #78520 is a reply to message #78352] |
Thu, 08 May 2003 10:59 |
Hi, I think you misunderstand me.
I have two EditParts (the container and the children)
They both have figures. (they are editparts because I want to be able to
select a child and remove / rename it etc)
So I don't really have a LayoutManager for the editparts..
describe.
> | Label |
> | | child| |
> | | child| |
> > Hello
> and
> > | Label |
> > | child |
> > | child |
> > | child |
properly.
> I
> > | child |
> > | child |
> > | child |
> > | Label |
appreciate
> > it.
> > Thanks.
Re: Layout of figures in an editpart [message #78652 is a reply to message #78520] |
Thu, 08 May 2003 14:57 |
Actually, that is what I understood. The label is getting pushed down to
the bottom in refreshChildren because it is a sibling of the children
editparts' figures. Your container edipart must consist of 3 separate
figures, one for the editpart, one for the label, and one to contain the
children editparts.
+Figure in ToolbarLayout
|-Label
|-+ Figure in ToolbarLayout
| - figure from first child editpart
| - figure from second child editpart
news:b9dd63$m3f$1@rogue.oti.com...
> describe.
> > | Label |
> > | | child| |
> > | | child| |
> > > Hello
rectanglefigure
> > and
right
> > > | Label |
> > > | child |
> > > | child |
> > > | child |
> properly.
> > I
> > > | child |
> > > | child |
> > > | child |
> > > | Label |
> appreciate
> > > it.
> > > Thanks.
Re: Layout of figures in an editpart [message #78695 is a reply to message #78652] |
Thu, 08 May 2003 15:12 |
Ok I understand that, but what I don't understand is where and how I can
add() a child to the figure with toolbar layout
I create a figure in createFigure(), and gef does some magic, so there's no
way of adding the figure to another figure instead of the figure I return in
createFigure()
news:b9dr8d$2mt$1@rogue.oti.com...
> children editparts.
> |-Label
> > describe.
children:
> > > | Label |
> > > | | child| |
> > > | | child| |
> > > > Hello
> rectanglefigure
> > > and
> right
> > > > | Label |
> > > > | child |
> > > > | child |
> > > > | child |
> > properly.
> > > I
> > > > | child |
> > > > | child |
> > > > | child |
> > > > | Label |
> > appreciate
> > > > it.
> > > > Thanks.
Re: Layout of figures in an editpart [message #78769 is a reply to message #78695] |
Thu, 08 May 2003 16:12 |
create a field in your graphicaleditpart subclass called contentsPane. in
createFigure, hold onto the contentsPane. override getContentsPane to return
the contentsPane field.
news:b9ds1c$3je$1@rogue.oti.com...
no
in
> createFigure()
to
> > children editparts.
> > |-Label
to
> > > describe.
> children:
> > > > | Label |
> > > > | | child| |
> > > > | | child| |
> > > > > Hello
> > rectanglefigure
> > > > and
> > right
> > > > > | Label |
> > > > > | child |
> > > > > | child |
> > > > > | child |
> > > properly.
> > > > I
> > > > > | child |
> > > > > | child |
> > > > > | child |
> > > > > | Label |
> > > appreciate
> > > > > it.
> > > > > Thanks.
Re: Layout of figures in an editpart [message #79000 is a reply to message #78769] |
Mon, 12 May 2003 09:11 |
Ah thanks for explaining. I also found the same code in the logic example.
news:b9dvkt$6rc$1@rogue.oti.com...
return
> no
return
> in
> > createFigure()
> to
the
> > > children editparts.
> > > |-Label
able
> to
> > > > describe.
> > children:
> > > > > | Label |
> > > > > | | child| |
> > > > > | | child| |
> > > > > > Hello
> > > rectanglefigure
> > > > > and
right,
> > > right
> > > > > > | Label |
> > > > > > | child |
> > > > > > | child |
> > > > > > | child |
> > > > properly.
> > > > > I
> > > > > > | child |
> > > > > > | child |
> > > > > > | child |
> > > > > > | Label |
> > > > appreciate
> > > > > > it.
> > > > > > Thanks.
Current Time: Sun Oct 06 11:03:47 GMT 2024
Powered by FUDForum. Page generated in 0.04018 seconds
