Home » Newcomers » Newcomers » Eclipse start: "The publisher could not be verified."(Unknown publisher on Eclipse Galileo start)
Eclipse start: "The publisher could not be verified." [message #780880] Thu, 19 January 2012 19:08 Go to next message
Chris Dueker is currently offline Chris DuekerFriend
I have Galileo installed on my Windows 7 system as of June 2010. The binary was eclipse-jee-galileo-win32.zip. The 'About Eclipse' dialog shows Build id: 20090621-0832.
For the past year or so, every time I start up Eclipse, I get a Windows security warning popup that says "The publisher could not be verified." with the publisher showing as "Unknown Publisher". Is there something I can do to get this popup removed upon Eclipse startup?
Thanks!
P.S. In addition (don't know if this is related, if not, please disregard), every time I get a "Java Update Available" and try to install, I get a "Failed to download required installation files." popup.
Re: Eclipse start: "The publisher could not be verified." [message #782485 is a reply to message #780880] Mon, 23 January 2012 20:09 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric RizzoFriend
> Thanks!
Both of those sound like Windows 7 getting in your way. Have you
searched the Eclipse bugzilla to see if anyone has reported the "unknown
publisher" issue? Maybe the Eclipse download packages can be signed in
some way to make Windoze happy...
Eric
Re: Eclipse start: "The publisher could not be verified." [message #902161 is a reply to message #782485] Thu, 16 August 2012 07:43 Go to previous messageGo to next message
David Riemens is currently offline David RiemensFriend
did you perhaps Unzip the package via the Windows Explorer, just by double=-click, and moving the 'eclipse' folder elsewhere ?
I have just found out that this was causing the same problem on my Win7 machine.
Please try to use eg 7-ZIP to extract the eclipse.
@moderator: something for a FAQ ?
gr, David
Re: Eclipse start: "The publisher could not be verified." [message #1780715 is a reply to message #902161] Fri, 26 January 2018 09:20 Go to previous message
Giles Robinson is currently offline Giles RobinsonFriend
I'm replying to an old post, but got here by searching for the warning message.
Yes, using 7-zip fixed the problem (I'd forgotten the instructions about this).
Thanks.
Previous Topic:Updating Eclipse Error after download and installation
Next Topic:Error Eclipse don't Open
Current Time: Wed Feb 05 09:52:05 GMT 2025
Powered by FUDForum. Page generated in 0.09535 seconds
